Old 02-07-2015, 12:59 AM   #1
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
Need That Tire Advice
I'm planning on getting some wheels. The specs on them are 18x9.5 +38. Doing that on all fours. If I plan on lowering my car soon and i don't want to roll or pull my fenders. What would be the best set of tires for my situation?
WhiteChocolate is offline   Reply With Quote
Old 02-07-2015, 11:52 PM   #2
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
Ha! You beat me to it.. I was gonna ask same question.
From what ive read so far, 245 35 is issue free, no rubbing, but depends on how much u lower.
rickpalace is offline   Reply With Quote
Old 02-09-2015, 12:12 PM   #3
WhiteChocolate
you think i can maybe do 245 40?
Old 02-09-2015, 01:08 PM   #4
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
As per 1010tires.com (tire size calculator) they are a little bit over sized.
Despite that, that's probably what im gonna go with, just because the difference in size is small, and there is so much more choice or rubber out there compared to 245/35.
Old 02-09-2015, 04:18 PM   #5
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I would say a 245/35 if you're wanting to stay away from rolling/pulling fenders.
How low you're going and the type of camber you'd run is also a factor. I'm going to assume not very much camber.
255/35 would be ideal and 265/35 would be on the meaty side of things.
Old 02-09-2015, 05:00 PM   #6
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
why would 255/35 be ideal?
Old 02-09-2015, 05:04 PM   #7
TylerLieberman
Drives: '24 GR86
It's more of a "proper" sized tire.
I personally don't have any issues against stretched tires. Most others on this forum do though so I'm just going based off that fact.
a 255/35 would be a "better" sized tire for that wheel, but loads of people have run 245/35 without any issues.
a 245/40 is a pretty good sized sidewall and will take up more room than the 35 series.
The Following User Says Thank You to TylerLieberman For This Useful Post:
WhiteChocolate (02-10-2015)
Old 02-09-2015, 05:17 PM   #8
guslucatero
guslucatero's Avatar
Drives: 2014 WhiteOut
I have that same set up...and currently I am running 225/40 all around. but you can run a bit wider.
guslucatero is offline   Reply With Quote
The Following User Says Thank You to guslucatero For This Useful Post:
Old 02-10-2015, 01:47 AM   #9
WhiteChocolate
What do you mean by a bit lol. Sorry I'm not so hot with this tire stuff
Old 02-11-2015, 12:33 AM   #10
guslucatero
If i can do it again I would run 235/45 all the way around...or you can run beefer on the rear and smaller on the front
Old 02-11-2015, 11:27 AM   #11
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
You must have a crazy stretched tire
Old 02-11-2015, 11:33 AM   #12
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
Old 02-11-2015, 11:45 AM   #13
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
i was running 255/35 on my car with no rubbing. didnt have to roll fenders or pull fenders at all.
ExxelDistributions is offline   Reply With Quote
Old 02-11-2015, 12:00 PM   #14
xero404
Ran 255/35/18 on 18x9.5 +40 no issues even on track (see pic). 235/45/18 is a bit too tall and i'm hitting the Fender liner in the front at full lock inwards and have a bit of rub in the rear and might roll fenders. Name:  ImageUploadedByTapatalk1423670307.116522.jpg
xero404 is offline   Reply With Quote
Tire size advice Lost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-28-2016 07:42 PM
Tire advice dtrop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 12-03-2014 06:36 PM
tire advice kosoku Tracking / Autocross / HPDE / Drifting 24 12-17-2013 12:51 PM
Need daily driver tire advice bear89103 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-26-2013 02:15 PM
Wheel/Tire Advice mrjester Tracking / Autocross / HPDE / Drifting 1 05-19-2013 12:48 AM
