| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | YukiHachiRoku (02-06-2015) |
#16 | |
If you put the same wing and similar lip on those two cars, I can guarantee that they will pick up seconds. Not tenths, but seconds. In the BRZ's case, upgrading the tires to something similar to the GTR or Z06's compounds would not yield much time, but dropping the GTR and Z06 to similar tires as the BRZ would hurt the GTR and Z06 a lot. FWIW, I think the BRZ with fresh tires and a ballsier driver is a 1:27 car in the state it was in when the video was taken. I was taking a very conservative approach as I did not want to risk an off with the car at WSIR. Randy drives the cars in a similar manner; to someone familiar with WSIR, you can see where he leaves time on the table to guarantee that there will not be an incident with the cars. This is also why he has such a huge amount of respect, and why he is offered these types of opportunities. |
#17 |
Drives: 2013 Firestorm FRS
wait, I thought the GTR doesn't need a driver? Doesnt a human just interfere with the GTR's abilities?
| The Following 2 Users Say Thank You to continuecrushing For This Useful Post: | Dimman (02-06-2015), YukiHachiRoku (02-06-2015) |
#18 | |
Drives: '24 GR86
A full two days of constant driving? I suppose I could believe that a bit more.
#19 |
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton |
| The Following User Says Thank You to tahdizzle For This Useful Post: | YukiHachiRoku (02-06-2015) |
#20 | |
$200-400 (2 days entry) $1450 - Set of tires (RS3) $2000 - Set of tires (OEM) $700 - Set of front brake pads $1200 - 130 gallons of 100 octane at $9/gal $1400 - Pre-trackday, Post-trackday inspections, and full fluid changes at the dealership (This allows you to keep your warranty!) Other expenses: $2100 - Set of OEM front rotors, typically 5 weekends $1800 - Set of AP Racing front rotors $450 - Set of rear brake pads, typically 3 weekends Most of the GTR owners I coach will cord their tires in 1 weekend (2 days) of driving. It's just a function of the car being so damn heavy... 3x the HP of a FRS (assuming GTR has minor bolt-ons and a tune) means approximately 3x the fuel consumption. I have no problem burning 4-5 gallons in 20 minutes at the track; the GTRs I coach usually run through a tank (~13 gal), and run 100 octane to protect the engine. Just how the FRS's brakes are a bit undersized for track duty (but way oversized for street tury), the GTR's brakes are also a bit undersized... You get the idea. There are several GTR owners/former GTR owners on this board that can verify this... they bought a FRS/BRZ to have a cheaper track toy. If you think a GTR is expensive to track, you should see the cost of tracking a 458 Challenge.... 3x the car cost, but a weekend can easily run 25k. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | juliog (02-07-2015), strat61caster (02-09-2015) |
#21 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
No thanks. I'd rather have this.
[ame="https://www.youtube.com/watch?v=3ttCavbTJO0"]"DREAMCRUSHER" JUN 9 second R32 GTR - YouTube[/ame] |
#22 | |
Drives: '13 Denali, '15 Volt, soon a BRZ?
And for certain the car isn't build to win races. It is still just a cushy street car relatively speaking! Both of them are actually. Big power and carbon brakes does not a racecar make! I also have to wonder how much the handling balance hurt the Z06 performance in the comparo... Maybe play with tire pressures and shock settings until power-down isn't terrible like it seems in that video?? The Nissan is in deficit of power, torque, weight, brakes, aero, tires, cg and probably more. The only thing I can think of off hand in Nissan's favor is 4WD. I guess 4WD is magic. |
#23 | |
Drives: '24 GR86
My knowledge and experience is very limited on the GTR so I won't argue or question anything you've said regarding costs. I know the costs are substantially higher to maintain and track a GTR as opposed to an FRS. Looking at the costs you've listed though, the only thing I can tell is accurate is the track day price ($200). I know he didn't use 130 gallons worth of fuel and the rest of the costs don't apply as he did it was his first event in the GTR. I'm sure as he continues, he'll end up racking up more costs. I do know he's about to get a set of wheels with Toyo R888s though for track duty.
#24 |
Drives: '24 GR86
@CSG Mike
Just asked my Dad and this is what he told me: "Here's what we're seeing: Most people use stock Dunlops $2100/set or Toyo R888s $1550/set installed In both cases, they last two full track days for most people. After four track days, oil change time. With ECU/TCM tuning, we set clutch contact points at "2." No one driving a 2013-up model is going in for fluid changes beyond oil after tracking. We all do it at 18,000 miles. Front rotors $1100. You get about six full track days out of them. Brake pads are $375. They last at least six track days."
#25 | |
#26 | |
As far as the fluid changes go, basically the pre/post inspections themselves are free. The ECU logs how hot everything got, and if you hit level 5, then a fluid change is mandated to keep the factory warranty. You need to be a fairly experienced driver to be hitting level 5 consistently, but once you're there.... you can't reduce the heat without investing some serious money into cooling. A transmission cooler is virtually mandatory for tracking the car in automatic, even with a novice driver if the driver is getting any sort of coaching. |
#27 | |
Hotlink Terrorist
#28 |
Drives: 91 Toyota Supra 16 Nissan Versa
MT? the people who have a massive bias towards GM?
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
| $105 Saturday Night Event @ Willow Springs Streets of Willow august 16-17 | Louie | Southern California | 10 | 08-16-2014 01:02 AM |
| Night Event at Willow Springs-Streets of Willow -August 24-25 SoCal | Louie | Southern California | 9 | 08-21-2013 02:42 AM |
| $90 Track day at Willow Springs- Streets of Willow- August 12th Socal | Louie | Southern California | 2 | 08-10-2012 01:13 AM |
| Night Event at Willow Springs-Streets of Willow -July-7-8 SoCal | Louie | Southern California | 3 | 07-03-2012 02:16 AM |
| $95 Track Day@Willow Springs-Street of Willow- Dec31 SoCal | Louie | Southern California | 0 | 12-25-2011 04:45 PM |
