Old 02-06-2015, 07:16 PM   #15
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
Originally Posted by Decay107 View Post
If you intend to keep it stock, go with later than March 2013 build date (its listed on the inside of the door). That way you get the factory tune that fixed (or mostly fixed) the DI seal issue.
Mine was built exactly in march 2013, should I be worried?
MikeyBatz is offline   Reply With Quote
Old 02-06-2015, 07:39 PM   #16
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
One way to find out, but a cheap OBD2 adaptor from amazon and check your ECU calibration ID.
Decay107 is offline   Reply With Quote
Old 02-06-2015, 09:23 PM   #17
You want a VIN higher than JF1ZNAA1#D#008792 to have the factory update
If before the update may have been done.
MikeyBatz (02-07-2015)
Old 02-06-2015, 10:00 PM   #18
torqdork
torqdork's Avatar
Drives: RV-7
For reference, what are they asking for each? It might be worthwhile to spend a little extra for a fresh car with the '15 enhancements a couple here said they can actually feel (driveshaft, suspension mounts, shock tuning, exhaust tips, shark fin, upgraded hpfp) and get lower new car finance rates.
http://autoweek.com/article/car-news...r-s-grows-2015
torqdork is offline   Reply With Quote
Old 02-07-2015, 03:14 AM   #19
pdhami
Drives: 2014 Argento FR-S
For the 2014 about 21,500 plus fees and the 2013 probably around the same maybe a bit less
pdhami is offline   Reply With Quote
TRD Carbon Fiber Fender Fins Scion FR-S 2013-2014 / Subaru BRZ 2013-2014 RallySport Direct Exterior Parts - Lighting 73 07-31-2015 12:39 PM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 11:10 AM
APR Front Bumper Canards Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Exterior Parts - The Rest 0 01-14-2014 12:17 PM
GTSpec Rear Subframe Reinforcement Panels Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Brakes, Suspension, Chassis 0 01-08-2014 01:32 PM
Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Engine, Exhaust, Bolt-Ons 0 01-07-2014 01:13 PM
