Drives: .
Longer Gears
My car is FI but I feel like the gears arent long enough. What option are there for me since I hit 148 pretty often and it starts slowing down drastically there. I will be doing e85 so power isnt gonna be a problem. And if right now I just have 330 hp how much will it affect the speed of the car for the time being not e85.
#2 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Grab yourself an M85 differential out of a 02-05 IS300.
3.73 FD as opposed to the stock FT86 being 4.10. EDIT: Not terribly hard to find, but they aren't plentiful. I bought mine for $575 shipped. It is a *direct* swap. You need to pull the IS300 axle shafts out, and the rest is straight bolt in. |
#3 |
Drives: Scion FR-S
Agree with what slicktop is saying. Pulled my diff out of an IS300, but it was only $250 for mine. If you live in a big city (Houston for me), there are quite a few for sale if you call around.
M98 diff will work as well, but will have a 3.9 FD in it instead of the 3.73 tha the M85 has. |
#4 |
What is the stock gear ratio?
#5 |
Drives: '13 BRZ Limited, '95 BMW M3
Read post #2
#6 |
Junior
Drives: a car
#7 |
You rang!!! I've done the 3.73 diff swap. For forced induction it's almost a must do. Makes highway pulls a much less frantic experience lol, less shifting and more speed per gear.
#8 | |
Drives: .
#9 |
Its 4 bolts and two axles, you want an is300 diff tagged m85
#10 |
Drives: .
#11 |
I paid $600 for mine. It's a whole differential unit so u just pop the axles, remove the driveshaft and take the 4 mount bolts out and replace it with the is300 one.
#12 |
Drives: .
I dont get how any of this works but i have a guy that sells the diff for that car do i just say i need the m85 differntial and thats it?
#13 |
Drives: .
#14 |
It's literally bolt in. The transfer case/pumpkin is the exact same unit with different gearing inside.
Google "frs differential" and google "m85 differential". They're the same *exact* transfer case. On the M85, you will see the axle stubs where the axles go in. Those litereally pull out and you install it. I had questions and @Dipstik-sportech helped me out because I couldn't believe it was literally drop in. It was. I don't know how else to put it. EDIT: Look at my build thread, I have some pics there. |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 12:48 AM |
| You know what really grinds my gears...... | z3ro | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 10-10-2013 01:55 PM |
| Smoothing out 1st and 2nd gears | BRZerk | Engine, Exhaust, Transmission | 33 | 02-26-2013 05:30 PM |
| 2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 05:09 PM |
| Changing Gears | Naughty | AFRICA | 10 | 01-09-2013 12:30 PM |
