Sam Strano
Old 01-30-2015, 06:29 PM   #2143
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
There seems to be some confusion here.
The 2.0L has 155hp.
The 1.5L has 131hp.
The Twins have a slightly better power:weight than the 2.0L.
More detailed specs are available here: http://jalopnik.com/2016-mazda-miata...-to-1682771004
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-30-2015, 06:46 PM   #2144
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by CatDaddysBBQ View Post
I think so far the press has only had the chance to drive the Japan market base model 1.5 motor though - they haven't released numbers on the 2.0 that the US and Europe gets, so even though it's doubtful to make 200hp, I'd wager that it will make enough to beat the twins in power:weight. It only needs like, 155hp to tie.
The 2.0L has 155hp.
The 1.5L has 131hp.
Let's not forget about torque. Peak torque is almost the same as our cars. I'm just wondering what that torque curve looks like and what the gearing will be in ND.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
Shark_Bait88 (01-31-2015)
Old 01-30-2015, 07:35 PM   #2145
renfield90
The Stig's German cousin
Originally Posted by renfield90 View Post
$100 says no torque dip and 60+ MPH in second gear.
Old 01-30-2015, 07:38 PM   #2146
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
All the automotive publications are stating 155HP and 148FT/LB. The 1.5 did 61MPH in 2nd gear at 7500RPM. With only 155hp, I do not see this car going to BS. It looks to me like it will be a solid fit in CS for solo and T4 for club road racing.
I am surprised that Mazda did not try to squeeze more HP out of it for the MX-5 but at the same time impressed with them sticking to the original intent of the car.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 2 Users Say Thank You to Rampage For This Useful Post:
renfield90 (01-30-2015), Shark_Bait88 (01-31-2015)
Old 01-31-2015, 05:49 AM   #2147
G_Ride
G_Ride's Avatar
Maybe. The only way we'll know for sure is when they're released and dyno graphs start showing up.
You're probably right. With what we know, the ND really does sound like a CS car.
Old 01-31-2015, 08:14 AM   #2148
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
They may have used the old insurance trick. Leave the "rated" horsepower low, but let the real horsepower fly off unbridled (pun intended).
bimmer635csi is offline   Reply With Quote
Old 01-31-2015, 09:25 AM   #2149
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
SCCA Solo C Street Discussion
Unlikely. Insurance isn't going to give a crap if it is rated for 155 or 180hp. These days, they only care about the safety ratings, how often it is wrecked, and how much it costs to fix. They may look at the Hellcat and immediately assume that it will be wrecked often and spectacularly, but not the Miata.
Sent from Tandy 400
Quentin is offline   Reply With Quote
Old 02-01-2015, 10:05 AM   #2150
CatDaddysBBQ
Drives: '13 FR-S
Absolutely. I'll bet it's right about the same if side by side, but will likely feel faster than the twins from the drivers seat.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
Shark_Bait88 (02-02-2015)
Old 02-01-2015, 12:34 PM   #2151
bslate3
Drives: 2015 CWP BRZ
I'm trying figure out what front sway bar to get.
I thought the Strano bar would be best, but I hear of people selling them all the time.
Is it just too big?
The 20mm Whiteline adjustable bar with adjustable end links looks like the best deal. I might just get that.
I don't have Koni shocks and I don't plan to get any for a while so I want to make sure I get the best bar for the stock shocks. I don't want to create too much understeer.
I know a lot of it comes down to driving style.
bslate3 is offline   Reply With Quote
Old 02-02-2015, 10:27 AM   #2152
Shark_Bait88
Is it just too big?
I'm going to be re-evaluating which option I'm going with after my first event on some new tires, but I will likely go with the adjustable Whiteline 20mm. From what I can tell it seems like the best solution/deal.
Old 02-02-2015, 11:42 PM   #2153
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I went with a Perrin FSB. I'm not sure it is the best bar for the class/my driving style, but I was chatting with vroom4 about some used parts and he was able to hook a good deal on a new one. It might be worth PMing him to see if he can do it again...
Briankbot is offline   Reply With Quote
The Following 2 Users Say Thank You to Briankbot For This Useful Post:
Shark_Bait88 (02-03-2015), vroom4 (02-03-2015)
Old 02-03-2015, 11:21 AM   #2154
qoncept
qoncept's Avatar
I was running the Whiteline 22mm front bar last year and it was definitely too stiff, and I was on race tires. I ran a couple events with it this year on street tires and then switched to Strano with I'd say mild understeer. If I had it to do over again I'd stick with the stock bar for a while, but I sure as hell don't want to replace it again.
qoncept is offline   Reply With Quote
The Following User Says Thank You to qoncept For This Useful Post:
G_Ride (02-03-2015)
Old 02-03-2015, 12:39 PM   #2155
G_Ride
G_Ride's Avatar
I'm with you about the pain of replacing the sway bar. I remember thinking it should be an easy and quick job. It wasn't fun changing it by myself with the car on jack stands. I'm not a thin guy...
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
qoncept (02-03-2015), Shark_Bait88 (02-03-2015)
Old 02-05-2015, 09:39 AM   #2156
travisb
travisb's Avatar
Drives: N/A
I'm getting ready to order some new tires and wheels. The car is currently stock except for front camber bolts.
I'm leaning towards 215/45 ZII and 17x7 Kosei K4R wheels. I plan on leaving these wheels and tires on Spring-Fall and switching back to stock during winter.
I drive about 15k miles per year and live near Richmond, VA (hot summers and occasional heavy rain, warm Spring and Fall). I plan on doing about 10 autox events per year - each one with 5-6 runs of less than 60 seconds each. The asphalt is usually rough and not a ton of grip on normal tires.
Does this sound like a good plan? What kind of life expectancy can I expect from the tires? Is it worth going wider tires/wheels? I'm not going for FTD, I just want a lot less sliding than last year.
travisb is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
