#15 |
#16 |
Drives: 2013 WhiteOut FR-S
Option 1 Cup in Tw!!!! Thanks for sharing, Im just contemplating trying RC1 out instead of NT01, only problem is i like 215/45/17 which RC1 do hv ....
Good Luck next season!!
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
| The Following User Says Thank You to RehabJeff86 For This Useful Post: | Doozer (02-02-2015) |
#17 | |
Drives: gt86...among others
With the increase in speed were starting to notice the grip levels in the heavy breaking zones more. I can't think of a better tire for the money, but they sure ain't no Michelin Slick when you gotta stop Anytime you find yourself over here let us know. I think we may be able to find a ride for ya
racing gods live deep in corners
| The Following 2 Users Say Thank You to Doozer For This Useful Post: | CSG Mike (02-02-2015), RehabJeff86 (02-02-2015) |
#18 | |
Im indeed going back in March!! Would love to tour ur shop and hitch a ride! Sent from my iPhone using TapatalkfQ
#19 |
Drives: 2004 Toyota RAV-4 5M
I'm back from my first track event with the Maxxis tires and thought I'd go ahead and post up some data comparing them to when I ran Hoosier R6's.
To be fair, this is not a straightforward tire comparison, as I made a number of other modifications that I'm sure helped out with the grip for the RC-1's. Mods for Hoosier R6: Essex AP Racing Sprint BBK Ohlins Road and Track Coilovers Hoosier R6 225/45R17 Delcious Stage 1 Pump Gas tune ACT Prolite Clutch/Flywheel Drive Shaft Shop CF Drive Shaft Perrin Motor Mounts Whiteline Diff Cradle Whiteline Positive Shift Kit K&N Drop In Filter Crawford Performance Air/Oil Separator Enkei RPF-1 17x8 -2.7 camber front -1.8 camber rear New Mods for Maxxis RC-1: 225/45R17 Maxxis RC-1 Custom valved Ohlins Road and Track (650lbs front, 750 rear) Whiteline Rear Subframe lockout bushings Cusco RS LSD JDL EL Header, Over pipe, and high flow cat front pipe GrimmSpeed Intake Delicious Tuning Stage 2 tune -3 camber front -2 camber rear Red Line: Maxxis RC-1 (relatively normal conditions) Black Line: Hoosier R6's (perfect conditions cool air, warmed up track) Blue Line: Hoosier R6's (relatively normal conditions) Lap Times: ![]() G-Force: ![]() So, just to be clear the black line was with absolutely perfect track conditions. Nearly everyone dropped 2 seconds that session, so I was hesitant to even include it in this comparison. The blue line was from an afternoon session that same day. Here's my impression of the data and this weekend: With the extra mods that I had for the Maxxis tires I could pretty much match the grip levels I was getting from the Hoosiers last year. There are a few areas that were a bit lacking, namely turn 3 (turn 2 in the data) and turns 16-17 (turn 9 in the data). For turn 3, I had some better speed through that in other sessions (as you can see from the video I had a bit of a drift going through there on my fast lap), but I was consistenly 4-5 mph slower through there than with the Hoosiers. For turns 16-17 the car just didn't feel ready to turn in at the same speed with the Hoosiers and I was consistently 4-6 mph slower through there as well. I think I can pick up some of this time back with just some more experience with the tires and new setup and maybe tweaking a few settings. For a more general feedback, the tires and suspension setup really felt great this weekend. While it has more to do with the suspension and diff setup than the tires, I had so much more confidence in the car when getting on the gas and was able to get on the gas much earlier, especially in the slow turns. The only criticisms I have for the tires was that they didn't seem to handle trail braking quite as well as the Hoosiers and the fronts would typically give up and result in some understeer under heavy trail braking conditions (turn 1, Oak tree). Through some fiddling with tire pressures (ended up with about 36psi hot all around) and adjusting rebound on the suspension I was able to minimize this, but it still wasn't as good as the Hoosiers. That being said, I will probably end up running the Maxxis RC-1's for most of the year thanks to their rather generous contingency plan for NASA's TT program. But when it comes time for the East Coast Nationals in September I'm probably going to be running on the Hoosier R7's (assuming the dyno reclass I'm going to submit works out the way I think it will). Fastest Lap with Hoosier R6: [ame="https://www.youtube.com/watch?v=B0dyiAhTbHM"]Fastest Lap @ VIR - 2:12.550 - YouTube[/ame] Fastest Lap with Maxxis RC-1: [ame="https://www.youtube.com/watch?v=Y5T6qtQAjaw"]Fastest Lap @ VIR - 2:14.503 - YouTube[/ame] |
#20 |
Drives: 2013 Raven Scion FR-S
Good summary, Josh. My feeling last weekend at Road Atlanta on 225 RC1s was quite similar compared to my usual set of 235 Toyo RRs. Overall, the grip levels weren't too far off, but I found significant amounts of understeer with the front end washing out on me in 2 corners (T1 and T7 - both left turns). I'm confident the understeer can be dialed out with setup. I was having some brake issues, and decided not to push the car too much, so I didn't focus on collecting meaningful data.
I plan to reverse the testing process this weekend at Roebling Road. 225 RC1 (5hc) vs 245 RS3 (5k miles) vs 235 RR(15 hc). I know exactly where the RRs sit compared to R6. If the RC1 can be tweaked to match or outperform the Toyos given the points savings, then just like you it's a no brainer.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
#21 |
Drives: GR86
I know this is a tire thread but how are you guys adjusting rear camber without LCAs? Are you using bolts or just adjusting ride height?
#22 | |
Quite frankly, getting this kind of work done will likely cost you more than just getting arms and a regular alignment. The only situation where you do something like this is when you have no options, or need to do it for classing purposes. |
#23 |
Yup. I would have gotten rear LCA's a long time ago if it didn't cost me 4 points in NASA's TT system. Managed to get -2 degrees in the rear just by lowering it, and not that much really. My car certainly isn't slammed or anything and I don't ever scrape.
#25 |
We will be using these on our Spec86 Cup car July 4th weekend at LRP. Will update with feedback after the race weekend.
-mike |
#26 |
You going to be running in TT as well that weekend? I'll be there for Saturday only, but I had a fun time competing against you and Rick at NJMP Lightning in April.
| The Following User Says Thank You to ja1217 For This Useful Post: | AZP Installs (06-11-2015) |
| Tags |
| csg mike, essex |
| NASA Maxxis Contingency and Konig Wheel discount | DaDr00 | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2014 12:25 PM |
| FS: (4) Maxxis RC-1's 255/40/17 | BeltedBiscuit | Wheels and Tires | 5 | 09-08-2014 09:38 AM |
| CSG BRZ, Maxxis Victra RC-1 Racer Testimonial Video and microsite | CSG Mike | BRZ Photos, Videos, Wallpapers, Gallery Forum | 11 | 05-28-2013 02:32 PM |
| Snow wheel / tire install notes | Ingen | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-21-2012 02:43 PM |
| new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
