Old 08-13-2012, 08:59 PM   #71
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by sho220 View Post
Soooooo dreamy!!!!
LOL
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-13-2012, 09:41 PM   #72
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
The FRS/BRZ handles so good there's nothing to worry about in general. Just don't go too fast too soon. Get to know the car first then start to push it to it's limits.
Try driving a pickup with no weight in the bed or w/weight & no chains on a lightly snowy, icy road, that's when it gets dicey & fun.
Grateful Dave is offline   Reply With Quote
Old 08-13-2012, 09:45 PM   #73
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
haha...Toyota X-Runner + Light rain = Sit and spin...
sho220 is offline   Reply With Quote
Old 08-13-2012, 10:01 PM   #74
onthemove
Drives: ...
Just drive like a normal person on the roads, and drive like a racecar driver on the track... PROBLEM SOLVED!!!
Sent from my DROID BIONIC using Tapatalk 2
onthemove is offline   Reply With Quote
The Following User Says Thank You to onthemove For This Useful Post:
bestwheelbase (08-14-2012)
Old 08-13-2012, 11:47 PM   #75
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Allch Chcar View Post
Don't stomp the accelerator, ever. Even at relatively low speeds it can snap oversteer. And it will snap oversteer if you stomp the gas while turning. Always smoothly accelerate/decelerate.
that's not what snap oversteer is, that is power oversteer.
snap oversteer comes from lifting off the accelerator and the weight transfers to the front of the car, causing the rear to lose traction
Originally Posted by Turdinator View Post
Is RWD that scary? I find FWDs far scarier, the car stops steering when you lose traction.
hell yeah! I remember two winters ago when I was driving my Civic (first FWD car I ever owned) and I hit a small patch of ice. I tried to turn and the car just went straight!
dori. is offline   Reply With Quote
Old 01-31-2015, 04:55 AM   #76
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
So.... Let's say there's a C shape highway merge, would it be generally okay to accelerate hard from first to second while taking the turn not initiating breaks or anything, would this still cause snap oversteer due to the slight delay in gear change from first to second? Or would it cause power oversteer?Just curious for funs sake and safety sake.
jaorocks1 is offline   Reply With Quote
Old 01-31-2015, 09:01 AM   #77
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Do:
Burnouts
Drifts
Powerslides
Don't:
Be a little bitch or a *****.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 01-31-2015, 09:12 AM   #78
D88
D88's Avatar
Drives: 2014 Scion FRS
Originally Posted by GenkiElite View Post
"Don't" use the internet to learn to drive your car.
"Don't" only use the internet to learn to drive your car.
There are good resources on the internet. Just make sure to apply the skills you've read about to your car in a safe place to see how they work in a real world setting!
D88 is offline   Reply With Quote
The Following User Says Thank You to D88 For This Useful Post:
Tcoat (01-31-2015)
Old 01-31-2015, 04:25 PM   #79
zooki
Drives: waiting on a 2021...
...or a 450+HP Mustang with a Detroit Locker and ET Street tires home from the drag strip in the rain....talk about "Jesus take the wheel!".... (:
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 01-31-2015, 05:54 PM   #80
airjonny
airjonny's Avatar
Drives: Nissan Murano
This. When I learned stick, the youtube videos made the learning curve so much easier.
airjonny is offline   Reply With Quote
Old 01-31-2015, 06:34 PM   #81
Same as this for three Canadian winters on bias ply summer tires (at least this dude is rockn radials)!
zooki (02-01-2015)
Old 02-01-2015, 05:14 AM   #82
For the new folks this is required viewing regardless of driving intent. If you watch only one performance driving video in your lifetime, this should be it.
Liftoff and power oversteer are demonstrated at 17:49
[ame]http://youtu.be/xQRmYMlmdqM[/ame]
Old 02-01-2015, 08:52 AM   #83
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by TuxedoCartman View Post
The one day I forgot and left the TC on, I nearly curbed my wheel.
Yea, that ones a bitch. Did it yesterday, took a wrong turn, needed to do a 180, figured I would use the "rear wheel steering" forgot to turn the nannies off, nearly kerbed the front wheel.
A few general driving things that especially apply to RWD... if the car slides.
LOOK WHERE YOU WANT TO GO!
It's in caps for a reason, it is the singly most important thing you will do in a slide or out-of-control situation. Put another way:
Do NOT look where you think you will end up, because you will.
So do NOT stare at that big tree you could hit as you will hit it. Ever heard of "Magnetic Kerb/Curb"? Exactly this phenomenon. You notice you are close to a kerb, it attracts you attention, you focus on it and seemingly, no matter how hard you try you keep getting closer to it. The trick is to look away, look down the road where you want to be.
Studies have shown, time and time again, that while "we" think it is the conscious part of our brain - the part that thinks (I think therefore I am) - that controls the car, walks, runs, flies a hand glider, it is NOT. The part of the brain that does the actual driving is a much older and simplier part of the brain. The same part as motor-memory et al. Where it drives/walks/runs is almost entirely controlled by where you look. It does not understand English, or American for that matter, it only understands what it has learnt to do and where you are looking at. Also it doesn't understand "DON'T" it has no concept of negative stimulus.
So even though you are screaming "Not the tree! Not the tree! Please god not the tree", if you are looking at the tree the part of your brain driving the car WILL drive you into the tree.
As a paraglider pilot I have stood and watched people fly straight into the only tree in a square mile landing field. The instructor repeating on the radio, "Do not look at the tree. Do not look at the tree. Do not look at the tree."... they look at the tree, fixate on it as a threat and fly straight into it.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 02-01-2015, 08:57 AM   #84
paulca
The FRS has an anti-liftoff oversteer mechanism BTW. Most modern cars have it, including FWD (where lift off oversteer is worse).
It nicely doubles as an up shift helper to.
How do you tell it's there? Rev the engine up to 3k and lift your foot off the acclerator quickly. You should note that the revs hover for a second or so before falling. This is pre-programmed into the electronic throttle to help prevent lift off oversteer and to make upshifts easier (the revs don't drop as fast, so if you shift at an average speed the revs are already matched for the next gear).
The first car I bought didn't have this. If you drive an old manual car like that, made before electronic throttles, you will notice gear shifts are a lot harder to get smooth and the throttle/clutch timing is much more delicate. Basically if you lift the throttle even a few milliseconds before you slip the clutch you get a lurch forward of engine braking. Then as you select the next gear and lift the clutch before appling throttle you get another lurch forward as the revs have fallen way too low. Modern car, no issue, the throttle release delay covers this off nicely and also helps prevent lift oversteer.
The Following User Says Thank You to paulca For This Useful Post:
Ultramaroon (02-01-2015)
