Old 01-31-2015, 01:09 AM   #939
Originally Posted by pdhami View Post
Oh ok sounds good thanks, I'm close to buying a used FRS but it has the condensation issue, so I was making sure theres a way for the dealership to find the TSB if I take it in
It was a pretty common issue at first so there shouldn't be a problem. If they give you a hard time just holler and I can get the number from my dealer (we are on very good terms)
Old 02-01-2015, 12:10 AM   #940
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Print this and shove it under his nose!
It very clearly says to replace the whole light.
http://www.ft86club.com/forums/attac...1&d=1358748967
Not sure if this will work as it is for Scion and I have a BRZ???
Jmonty is offline   Reply With Quote
Old 02-01-2015, 12:18 AM   #941
Here ya go! They have one as well.
http://www.ft86club.com/forums/attac...2&d=1352490977
Old 02-01-2015, 12:27 AM   #942
Jmonty
Thanks, doesn't seem to be as clear cut replacement as the FRS?
Old 02-01-2015, 12:33 AM   #943
They must figure the Subaru techs are a little smarter and don't need their hand held through each step.
The parts list at the top shows that whole new housings are required and give the new part number.
Old 02-01-2015, 12:57 AM   #944
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Just went to a toyota dealer because I am having this issue on my '13 FR-S that I bought last weekend, from what I can gather, they said they were going to replace the gasket and the lens. Is this correct? Isn't the whole assembly supposed to be replaced?
BDotG is offline   Reply With Quote
Old 02-01-2015, 12:57 AM   #945
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
washed n detailed my car this evening....saw some small amount of condensation on the drivers side tail light....geez, my car is only 3 months old WTF!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-02-2015, 04:44 PM   #946
Be one of the very, very rare occurrences for anything beyond the early 13s!
Old 02-03-2015, 08:39 AM   #947
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
As someone who makes and sells aftermarket gaskets, I'll say that's not true. While my customer base is MORE 2013, it's not an overwhelming majority. Still lots of 2014 and 2015 models. Until the design of the trunk channel and tail light housing is changed, water will continuously assault the gasket. Depending on your area's weather or how you store your car makes you varyingly susceptible.
If you're buying a newer model year, or have an older one and haven't had any condensation yet, your best bet to prevent it is to put waterproof tape over the gap between the trunk channel and the housing so the water flows over/past it instead of down into the gap and directly onto the gasket.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 02-22-2015, 12:42 PM   #948
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
My 2014 Monogram that is almost one year old has started to get condensation in the passenger side tail light. Is this just a basic warranty repair that I can just ask them to replace the tail light assembly? I had the same problem on my 2003 Celica within 3 months of purchase and I had them replace tail lights and headlights due to condensation. I might just wait to the driver's side starts to fog as well and get them replaced at the same time. I assume I would just ask them to replace.
Chad86 is offline   Reply With Quote
Old 02-22-2015, 01:17 PM   #949
Ya just show them the TSB above if they give you a hard time.
Old 02-22-2015, 02:55 PM   #950
BRZnut
Drives: BRZ DGM Limited
Good suggestion. I did this with my '13 but used black caulk. Since the car is DGM, can't even notice.
Old 02-22-2015, 05:10 PM   #951
Jmonty
Thanks for the advice, I bought your gaskets worked for while guess it is just too wet in the PNW.Had the car back at the dealer a few weeks ago, they wouldn't replace the tails until they try one more torquing sequence? Guess they are in contact with SOA on this?
Old 02-23-2015, 04:14 PM   #952
wdninja
wdninja's Avatar
Thanks for buying them. If they failed for you, shoot me a PM and I'll get it worked out for you.
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
