Old 01-28-2015, 02:27 AM   #1
Bluetail
STI Wheels
I would like to get a set of STI Wheels for my Brz who can you order them from ?
Bluetail is offline   Reply With Quote
Old 01-28-2015, 04:38 AM   #2
btoast
Are you talking STI Japan wheels or STI USA wheels?
You can get the US version from your local Sub. dealer or online: https://www.subarugenuineparts.com/p...feff8d1e4f6c06
The Japan version can be ordered from Japanparts.com : https://www.japanparts.com/parts/detail/41618
The US set will cost you around $1400-1500.
The Japan set will set you back around $2,000.
The US set is 17x7, whereas the Japanese set is 18x7.5.
Alternatively you can keep an eye on the marketplace as a few Series.Blue owners unload their US sets there at a discount.
btoast is offline   Reply With Quote
Old 01-28-2015, 04:46 AM   #3
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Maybe he wants the 2004 WRX STi wheels. MMmmmm.. If I ever find another reasonable priced set I will not let them get by.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 01-28-2015, 12:05 PM   #4
Akari
Drives: 2013 DGM BRZ
Honestly after having that generation STi wheels I'd never purposefully put them on anything. They're not the lightest and really aren't that strong, I've been able to bend multiples from just aggressive off-level cornering in my STi.
Akari is offline   Reply With Quote
Old 01-28-2015, 01:44 PM   #5
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Originally Posted by Akari View Post
Honestly after having that generation STi wheels I'd never purposefully put them on anything. They're far from light and really not that strong, I've been able to bend multiples from just aggressive off-level cornering in my STi.
The '04 STi BBS is 17x7.5, 5x100 and 15.7 lbs? How is that far from light?!?! It's half an inch wider than stock and 5 lbs lighter...
Old 01-28-2015, 02:13 PM   #6
Akari
The '04 STi BBS is 17x7.5, 5x100 and 15.7 lbs? How is that far from light?!?! It's hald an inch wider than stock and 5 lbs lighter...
I stand corrected, that's not bad. I guess it just seemed like a lot compared to the RFP1s I switched to.
Old 01-28-2015, 02:25 PM   #7
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Which RPF-1s did you switch too? lol 15.7lbs is pretty light.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Hyper4mance2k (01-28-2015)
Old 01-28-2015, 03:07 PM   #8
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Well if he's making a direct comparison on the exact same 17x7.5 RPF1, those are 15.25 lbs. Anything larger than that is heavier than the STI BBS...
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
tahdizzle (01-28-2015)
Old 01-28-2015, 03:29 PM   #9
Akari
I actually had a 05 STi so OEM STi wheels were 19.2lbs and same size RPF1s were 15.6. After bending the lip on my second OEM wheel I gave up and decided to try something else.
I never realized there was such a huge weight difference between 04 and 05 from an extra 1/2" and larger bolt pattern.
Old 01-28-2015, 03:34 PM   #10
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Yuuuuuuup
Old 01-30-2015, 03:14 PM   #11
dmarkey
For what it's worth, I'm currently running a set of 2005 17x8 et53 STi wheels with 25mm ISC adapters. Final offset is et27, and I've just swapped out the worn out 245/40 tires that came on the set I got for 225/45 so that I could remove a little negative camber. Personally, I love the look, and will be running these as my primary wheels on this car.
dmarkey is offline   Reply With Quote
The Following User Says Thank You to dmarkey For This Useful Post:
NWFRS (01-30-2015)
Old 01-30-2015, 03:21 PM   #12
dmarkey
Also, I was hoping the 15mm ISC adapters would work, and tried bolting them up that way at first. The image above was using the 15mm adapter with a 5mm spacer behind it for test fitting purposes. Once I realized I could make it work with the 25mm adapter I bought those and that's what the car is on now. I'll try to get some decent photos with the new tires and 25mm adapters soon.
If you're willing to shave 5mm off of the factory studs you can run the 15mm adapters. I have another set of wheels with a thick enough mounting face that I wasn't comfortable shortening the studs.
*** VORDOVEN Forme 9 Wheels - New Lower Pricing for 2015! - Wheels IN STOCK *** Sonic Motor Wheels and Tires 218 03-24-2016 07:23 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
