Old 01-22-2015, 01:01 AM   #5965
sickmint79
Drives: bmw
that's what i'm wondering, how's the heat exchanger fit in? i have a zeek snorkel and i'm wondering if the togue factory brake ducting would also fit.
sickmint79 is offline   Reply With Quote
Old 01-22-2015, 01:51 AM   #5966
TemeCal
Drives: 86
I can only comment on my heat exchanger, which is different from the Innovate version. However, mine sits on the base/floor support of the bumper. Your Zeek snorkel would be above it, not interfering with it. Same goes with the brake ducting, which I assume are behind the fog lights? Neither would be in the way of the heat exchanger (at least I don't think so). Maybe someone can post a picture for you??
TemeCal is offline   Reply With Quote
Old 01-22-2015, 08:38 AM   #5967
sickmint79
Drives: bmw
indeed that is what i am hoping
TF ducting is in the same area as well -
Old 01-22-2015, 09:38 AM   #5968
TemeCal
Drives: 86
I thought they were behind the fog lights, but I guess not. Looking at your pictures, my heat exchanger would not fit with your ducts in that location. Someone else with the Innovate exchanger will need to chime in, since there's is different. I believe the Innovate version is a little smaller???
Old 01-22-2015, 01:43 PM   #5969
sickmint79
Drives: bmw
for reference, the zeek snorkel as well
Old 01-26-2015, 09:31 AM   #5970
mid_life_crisis
Drives: FR-S 10 #103 AT
Sorry guys, I'm sure it's posted but I'm not wading through 150 pages for this.
What is the crank horsepower for the smaller intercooled kit running 93 octane on an otherwise stock engine?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-26-2015, 09:35 AM   #5971
Vten
Drives: Too heavy
Intercooled on 93, stock everything should be around 230-250whp .... Add 20%, should be around 300 at the crank ....I believe.
Vten is offline   Reply With Quote
The Following 2 Users Say Thank You to Vten For This Useful Post:
mid_life_crisis (01-26-2015), Xero-Limit (01-28-2015)
Old 01-27-2015, 10:55 AM   #5972
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Can I tap into the evap solenoid line (the one that runs from rear of charger elbow to solenoid) for boost reading?
Fizz is offline   Reply With Quote
Old 01-27-2015, 08:07 PM   #5973
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
The lines on the rear charger elbow never see boost, they are pre-screws. You need a line off the manifold under the charger. There is one pre tapped and plugged on the rear passenger side, or tap a new one.
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
Fizz (01-27-2015)
Old 01-27-2015, 09:27 PM   #5974
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks, I think I'll try tapping the MAP sensor plate.
The small pre-tapped hole under the elbow is a PITA to get to...
Old 01-28-2015, 04:43 PM   #5975
Bonks86
Drives: Gt-86
Originally Posted by Jonesy86 View Post
@Ultramaroon I can show you this noise in person. Mine likes to make it during every couple of cold starts. It made the noise most of the way home tonight. Mostly under deceleration/steady speeds.
Also, that bigger sprintex blower sounds amazing. Maybe if I hit the lotto...And they don't all explode.
Mine started doing this as well lately. It squeaks on cold start and then goes away. As soon as I am driving it comes back just not as loud. When I engage the clutch it goes away.
I had a bad pulley a month ago making a squeaking and had to replace it, but this is new.
Not really sure where it is coming from. I will try out a different belt/pulleys and see what happens.
Bonks86 is offline   Reply With Quote
Old 01-28-2015, 04:51 PM   #5976
blown
Drives: ft86
who has replaced the bypass valve?
blown is offline   Reply With Quote
Old 01-28-2015, 08:06 PM   #5977
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Did yours fail? Just curious how I would tell if the bypass valve isn't working?
Old 01-28-2015, 09:54 PM   #5978
blown
Drives: ft86
broke in shipping..
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
