#85 | ||
I also figured there is less chance of spillage if the main port is plugged before moving it. Quote:
#86 |
Drives: JAWS
So a thought I had while performing this mod, was concerning the bolt that connects the banjo fitting to the cylinder. It has a hole running through the threads which presumably needs to line up perfectly once tightened down. Do the threads on the bolt itself ensure this? What if you were to over-torque the bolt? Or am I wrong in assuming it needs to line up perfectly?
| The Following User Says Thank You to JB86'd For This Useful Post: | Ultramaroon (12-24-2014) |
#87 | |
Drives: old
| The Following 2 Users Say Thank You to Ozzman For This Useful Post: | JB86'd (12-24-2014), Ultramaroon (12-24-2014) |
#88 |
That was a good question so I dug up an example. Sometimes the groove is cut into the bolt. I haven't seen much of that. Most fittings are like this, where there's a cavity cut inside the fitting.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | JB86'd (12-24-2014) |
#89 |
I want to do this mod but my car is an auto. Do I need any special parts?
#90 |
That depends. You should be ok if your car is at the stock ride height. If you're lowered and you drive on bad roads you will need special parts.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | acetothermus (04-30-2015) |
#91 |
Drives: '13 Lava FR-S 6MT
Thanks for the guide, this was super easy to follow - I think the trip to Autozone to pick up the part took longer than the actual swap did. I took out the clutch return spring a little while ago but I got used to the additional stiffness from that within a day. I'm super pleased with how the pedal feels with both mods done.
| The Following 3 Users Say Thank You to Marx For This Useful Post: |
#92 |
Drives: innovate sc frs
All the Thanks goes to @Ultramaroon, for helping me do this to my car! The clutch is much more to my liking!
| The Following User Says Thank You to Jonesy86 For This Useful Post: | Koa (01-22-2015) |
#93 |
Junior
Drives: a car
what, no short guy tips? pft. some DIY thread. mods lets get this shut down, bein all tall-people biased n crap.
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | Koa (01-27-2015), Ultramaroon (01-27-2015) |
#94 |
Drives: JAWS
I was thinking today, and when bleeding the clutch, the first couple releases clearly spit out some air that I could hear and see. After that, the next few releases were smooth and just solid fluid coming out. Does that mean there is no air left in the system, or is it possible for there to be air further down the line? Clutch operation feels fine but just want to be sure I bled it all the way.
#95 | |
| The Following 2 Users Say Thank You to Koa For This Useful Post: | JB86'd (01-27-2015), Ultramaroon (01-27-2015) |
#96 |
+1^ although it doesn't hurt to keep going as long as you watch the fluid level in the reservoir.
When we did @Jonesy86's last Tuesday I was amazed at how long it took to work out all the air. Definitely more than a few cycles but his clutch fluid looked contaminated. There may have been something else going on with his. I'll be checking it again this weekend.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Koa (01-27-2015) |
#97 | |
http://www.target.com/p/fantasy-fiel...prodSlot=_1_24
#98 |
Drives: JAWS
@Ultramaroon @Koa I wasn't sure so I actually bled it on two seperate days and the fluid was solid the second time around, probly did 6 cycles the first day then 4 more to be sure a few days later. Thanks for the reassurance!
| The Following 2 Users Say Thank You to JB86'd For This Useful Post: | Koa (01-28-2015), Ultramaroon (01-27-2015) |
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 07:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 09:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 11:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 02:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 06:32 PM |
