Old 01-19-2015, 11:38 PM   #15
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by fika84 View Post
Sorry I assumed since you are on a car forum and you put Engineer that you are either Mechanical or Automotive.. Are you going to school at ETS? I've been to Montreal once and we were there visiting ETS and their formula student team and facilities (which was amazing!). They definitely had a great robotics/computer science/engineering setup!
Horsepower is created by an explosion that takes place in the combustion chamber, watch this and you will understand the explosion I'm talking about. When you up horsepower you make this explosion stronger. Visually seeing this you will understand why you want the connecting rod stronger too..
Short answer: No
Long Answer: We recently had a car show in Montreal, the ETS student had their work there haha. I wish I could join their group to learn more about cars.. it is why I have so many question that may sound like I am trolling, however I am not. I am still learning about cars, taking few classes on the sides =p. The only reason I am on this forum, is because I have an FRS =p. I will send you witch University I'm in by PM.
Thank you so much for the input , I will check the link. Sorry for the whole confusion.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-19-2015, 11:56 PM   #16
FirestormFRS
The stuff I have from Group A is top quality stuff. I'd buy them if I were building an engine.
FirestormFRS is offline   Reply With Quote
Old 03-08-2017, 11:52 AM   #17
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Anyone else decide to give these a shot? Feedback? HP Levels?
NotSoJDM is offline   Reply With Quote
Old 03-08-2017, 07:02 PM   #18
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Not worth testing and finding out the hard way. Although anything seems better than factory toilet paper rods. Im going Pauter personally.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-08-2017, 07:42 PM   #19
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Carrillo or bust.
No pun intended.
Originally Posted by humfrz
I'm old and lazy
Old 03-09-2017, 01:30 PM   #20
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
we have a supercharged car on a set. no installation issues and zero problems so far. the car is not making a ton of power though
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 6 Users Say Thank You to spitfire481 For This Useful Post:
8686 (03-28-2017), Bfranklyn86 (03-09-2017), D_Thissen (03-14-2017), Irace86.2.0 (01-05-2021), NotSoJDM (03-10-2017), Teseo (03-09-2017)
Old 03-09-2017, 04:02 PM   #21
Bfranklyn86
Drives: GT86 Harrop S/C
Roughly what kind of power are we talking?
Saving 1k just on the rods could be the difference between an engine build being good value for money or not.
Bfranklyn86 is offline   Reply With Quote
Old 03-09-2017, 08:43 PM   #22
spitfire481
Drives: 2JZ FRS
I want to say around 350whp. I don't remember exactly we have done a bunch of cars since then. Stock motor randomly let go so he decided to build the next with Pistons/Rods/kings bearings/valve springs/head studs
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Bfranklyn86 (03-21-2017), D_Thissen (03-14-2017)
Old 03-10-2017, 02:56 PM   #23
NotSoJDM
NotSoJDM's Avatar
Thanks for your feedback. They looked to be the same alloy as all the other rods on the market, and h-beams will be more than suitable for my horsepower levels. So actual installation feedback is what I was looking for, thank you.
The Following User Says Thank You to NotSoJDM For This Useful Post:
Old 03-21-2017, 03:28 PM   #24
Andew727
Drives: Scion FR-S
I would have used them about a year ago but coulnt get my hands on them and went with BC I beam extremes. i dont see an issue with them at all...
Andew727 is offline   Reply With Quote
Old 03-22-2017, 10:26 PM   #25
stevo585
Drives: White 2014 BRZ
Isnt safe to say that *any* forged rod will be better than oem by far? Why all the worry?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
Andew727 (03-23-2017)
Old 01-04-2021, 02:36 PM   #26
Brandon.w
Drives: 2013 brz
Originally Posted by sam69 View Post
I asked the same question here .... http://www.ft86club.com/forums/showthread.php?t=78643 ... and have decided to give them a go.
Sorry I know this thread is old but if you did go with them how did they turn out? Would they be worth buying for someone looking at the 350- 400 whp range? Thanks.
Brandon.w is offline   Reply With Quote
Old 01-05-2021, 09:57 AM   #27
sam69
Drives: GT 86
Yep built the motor with them but unfortunately it's still not running
The wifey reckons after 3 years I need to get it happening but seems I'm building a custom laminova core for the Sprintex charger I only work on it when I get time or the inclination
sam69 is offline   Reply With Quote
Old 01-05-2021, 12:16 PM   #28
ZDan
ZDan's Avatar
Drives: '23 BRZ
Worth noting that up to some level of boost, the greatest stresses on the rods are due to snap-through acceleration at top dead center between exhaust and intake strokes, not from power stroke. Increasing revs is way harder on rods than adding FI up to maybe 10 psi or so.
Recommended Forged Con Rods? ChrisD Engine, Exhaust, Transmission 25 01-22-2015 03:48 AM
Which Forged Rods and Pistons sam69 Forced Induction 19 01-13-2015 09:13 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 08:11 PM
FBM 1000Hp Forged Connecting Rods FullBlown Forced Induction 75 10-08-2013 10:45 AM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 10:55 PM
