#15 |
Drives: 2014 BRZ Limited
#16 |
It's just the current state of car enthusiasts. It's all about highway pulls and stoplight-to-stoplight street "racing". Truth is, very few enthusiasts actually track their cars or seek out backroads.
Handling only matters to the extent you can brag about some lateral g number on paper. And balance and feedback are irrelevant - no numbers to brag about there. The FR-S/GT86/BRZ weren't really intended to cater to those folks, so it'll be hard to explain the appeal. So it's a good thing you don't have to. Enjoy your car!
2022 BRZ Build 2013 FR-S Build |
#17 | |
I have only had a couple of people ever say it was underpowered when I told the HP and since they nodded knowingly when I said "but it is rear wheel drive" (as if that fact made it faster somehow) then I was well aware they didn't know shit about cars anyway. The couple of guys at work that kept razzing me that it was "slow" changed their tune dramatically after I took them on a short ride on some secluded back roads. Pretty sure they both had to change their underwear after the first couple of turns.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkSunrise (01-19-2015), JARE_ee (01-19-2015) |
#18 |
Nobody beats the B[I|R]Z
Drives: shopping cart i stole from walmart
If you're going to use the SR20 for comparison at least use the most recent one (which is still 15 years old at this point). The S15 Silvia had 250hp and cost about the same as an FR-S. There was even a non-turbo version had about the same 200hp as the FR-S, again 15 years ago.
#19 | |
#20 |
Drives: '14 FRS, '98 JDM Forester, '95 s14
Compared to a lot of the newer cars out there 200hp isn't all that much, but it works for me and my skill level.
All my track friends are comfortable with the lower power levels, but all the stance and drift guys will never let my "rwd prius" live without making fun of it. |
#21 | |
Drives: Toyota Skyline Type-R
#22 |
Drives: 2014 Toyota GT86 Pearl White
I don't get asked these questions because I don't encounter a whole lot of "car people", but since you asked.
The base WRX is 30% more than the base GT86 (Evo might be around the same as the WRX, I can't be bothered checking), and I got the base 86 because the more expensive model didn't have anything I wanted. It was basically heavier, for more money. IMO the WRX is damn ugly, seems to be getting more so every year. Ditto for the Evo. Too many electronics too, I wanted a "driver's car". I dislike turbos too, I think of it as cheating, The engineering effort that went into the engine appealed to me. Although I hear the new WRX has a turboed FA20? And the Cayman isn't even an option in Australia, way too expensive. |
#23 | |
FRS $30K, WRX $44K, Evo $42K (Canadian prices)
#24 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#26 |
Dismember
Drives: 2013 Red Scion FR-S
I specifically bought the car to use on the street and track while still having enough backseat to transport my kids.
#27 | |
Drives: 2005 Toyota Camry
S13 vs S15 SR: higher boost, better turbo, larger injectors, different factory ECU tune. Same internals for all practical purposes S15 SR (Autech differences vs turbo): no turbo, smaller injectors, higher compression engine, better NA cams, different factory ECU tune, same internals for all practical purposes aside from compression/cam difference. Better header than the standard RWD S15 SR20DE version. A closer engine to compare would be the P11 SR20VE, with a factory 10.4:1 compression ratio and making ~187 crank HP. P12 SR20VE had 11:1 compression ratio and makes ~205 crank HP. The P11 SR20VE that I had in my G20 made almost 190FWHP with stock internals, Fujitsubo header, JWT ECU tune, intake, intake plenum spacer. The FA20 is similar in many respects, simple I/H/E mods + tune can get decent power to the wheels. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | DAEMANO (01-19-2015) |
#28 | |
Drives: fast
damn.. I agreed with you up until the "turbo is cheating" argument.. If forced induction is cheating, then do you not agree we shouldnt have fuel injection and go back to manual carbs? The carb camp may think that fuel injection is cheating as per your same argument. Do you think our ECUs are cheating because there are no requirement for electronics for a combustion engine to work? See where I'm goin with it? No offense but it seems you need to learn a bit more about what you're comparing. The WRX fa20 is the DIT version. yaaaawn. Fixed the racelands issue, but still boring. An EVO is definitely in the STI segment, price and performance wise. I own a bugeye wrx and have owned a hawkeye.. they are simply not the car a lot of people envision them to be. Very tempermental pieces of poop that are great most of the time.... but there is no "most of the time" when it comes to high performance |
| FS: New NRG Quick Tilt & As-Is NRG Quick Release | bear89103 | Interior Parts (Incl. Lighting) | 2 | 10-16-2014 02:11 AM |
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 06:59 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 05:50 PM |
| Just a quick rant | brianlo622 | Northern California | 10 | 10-12-2013 12:37 PM |
| Quick rant on dealerships | KaliKev | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-12-2012 02:52 PM |
