Old 01-19-2015, 08:34 AM   #1
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
Driver-side door not responding !
Hey there everyone !
I spent some time scroll through the previous threads but could not find an answer .
Recently my driver-side door stopped responding as I walk right next to it to unlock my car via handle (keyless lock/unlock) .
I find this very peculiar because my passenger-side still responds as I walk up to grab the handle with the fob in range .
Did I accidentally pressed something that caused this ?
Also my car recently has had some body work done , if I did not press anything I believe this may have caused the issue with the door not responding .
It is funny because to others it appears that I am a gentleman who likes to open doors for my passengers when in reality I am too lazy to press the button the fob that is in my pocket .
Please help !
Pish is offline   Reply With Quote
Old 01-19-2015, 10:20 AM   #2
If the body work involved the door it is very likely they did not hook the wires back up.
Old 01-19-2015, 12:05 PM   #3
Pish
#teamswagoi
Pish's Avatar
That is what I am thinking !
Although the door did not get damage in the hit and run accident it is on the same side .
I wanted to just figure out what had happened before heading back to my body shop to get it fixed .
Old 01-19-2015, 12:12 PM   #4
Did it work after the accident but before the repairs?
Old 01-19-2015, 01:02 PM   #5
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
I had the same happen after bodywork. I had the bodyshop check that the wires were hooked up, and they told me that the dealer would need to reprogram it. Only my trunk button still works. I havent bothered to go to the dealer to see though as I know they will charge me, and I forgot about it after I got used to pushing the button on the key. Mine did work after the accident, but before repair.
TheVoiceOfReason is offline   Reply With Quote
Old 01-19-2015, 04:07 PM   #6
Pish
#teamswagoi
Pish's Avatar
Thank you for your input !
It's funny because I just dropped my car off for service at the dealership ; should of asked them how much it would cost !
I'll see if they will charge for that .
Old 01-19-2015, 07:10 PM   #7
Raven604
Try holding down the window button for like 10s
Raven604 is offline   Reply With Quote
Old 01-19-2015, 08:22 PM   #8
TheVoiceOfReason
Drives: BRZ Limited
That is for a window reset I believe, which is not the issue here. This is the proximity door unlock in the door handles that the BRZ limited, and certain FRS models have.
Old 01-20-2015, 11:59 AM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
lol
try holding your brain for 10s and come back and re-read.
Old 01-21-2015, 12:42 AM   #10
mig86
Drives: MY15 86 GTS
Disconnecting the door handles wouldn't require anything to be re-programed. The sensors in the handles are just that, the smarts are within the central smart entry ECU.
I would bet that there is a harness connector loose or not connected. Probably in the foot well / cowl area.
Where was the accident damage?
mig86 is offline   Reply With Quote
Old 01-21-2015, 01:42 PM   #11
Pish
#teamswagoi
Pish's Avatar
The accident happened on the driver-side of the car right above the wheel well near the taillight .
Planning on dropping by my body shop anyway in the near future to pick up a check , I'll ask them to double check the connection before going to Toyota .
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 02:30 AM
WTB: Asphalt FRS Driver side Door qijian Want-To-Buy Requests 0 11-01-2013 02:17 AM
Rattle from driver's side door lock. Mandy Issues | Warranty | Recalls / TSB 0 07-10-2013 09:44 PM
Shoes Driver side door gr8scott Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 05-12-2013 10:22 PM
