#2759 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Pulley noise, then. Typical for the system. Well at least on mine. With my N1 does not bother me that much. Just remember there will be additional noise vs. stock, no way around that.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
| The Following User Says Thank You to zoth For This Useful Post: | Derka (01-14-2015) |
#2760 |
Drives: 2015 frs
Yea I get that. But this is a really loud rattle. Not just added noise. It's hard to describe. But it's a rattle more than just pulley noise.
#2761 | |
Drives: The silvertrooper 10 series
-Thomas |
#2762 |
Drives: 2015 frs
What is your tension set up at now? Would you mind getting a measurement?
#2763 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Just the physics of how the impeller builds boost, the speeds involved, etc. The larger impeller running a lower speed to keep the power down in the 300whp range will result in the boost curve being less linear and more exponential (very slightly) think of the powerband difference between the vortech and the C30 at roughly the same peak power... This is a large part of why there are so many different sizes for superchargers. If you run a 900hp supercharger at 300hp, your powerband is smaller than the next guy who is running a 400hp supercharger at 300hp. The actual friction losses from the larger blower are not big enough to explain the powerband differences, and would likely be offset by the MUCH cooler charge air. You're also only moving 300hp worth of air, so the larger blower doesn't take more of your power aside from the very small friction difference, but the longer boost ramp up time would be painful in comparison
#2764 | |
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | CSG Mike (01-15-2015) |
#2765 | |
That Guy
Drives: 2013 asphalt FRS MT
#2766 | |
Mr. Cranky Pants
That turned out to be a bad example, and I do remember making a smartass comment about how the dyno chart from the larger head unit was not lower in power than the C30 anywhere on the dyno chart. But we were comparing a C38 running the power number you should be looking for from a C38, not a C38 that's hampered by a large pulley to keep the boost down so you can run ONLY 300 hp. And nobody is going to cut their rev limit down to less than stock just because they've got a low power goal. I would do it to avoid swapping pulleys between a pump and e-85 tune, but if you're only trying to hit 300whp on E85, you're going to be running a low boost pulley on the C38 to do so, which is exactly why the C30 will be a better choice. |
#2767 | |
Drives: WRB JR BRZED
| The Following User Says Thank You to enivid For This Useful Post: | CSG Mike (01-15-2015) |
#2768 |
Drives: 2013 WRB BRZ Sport Tech
add me to the owners list, just purchased my kit from @rickspecd
awesome guy to deal with. if anyone is looking for a good deal on this kit i suggest contacting him... now come on nicer weather!!!!!!! |
| The Following 6 Users Say Thank You to DAN_BRZ For This Useful Post: | Chad86 (01-15-2015), Freeman (01-15-2015), KraftWerks (01-15-2015), Rulin (01-15-2015), Scracho (01-17-2015), Triumphrider (01-16-2015) |
#2769 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Sellout (01-15-2015) |
#2770 | |
Drives: Kraftwerks BRZ
![]() This was our BRZ with header and exhaust. The only thing changed was the Head Unit itself between the C30-94 and C38-81. The same pulley combination was used for both chargers. The top shows the power/torque curve with the C38 above throughout the entire graph. The bottom shows what the boost was doing with reference to again, the C38 was producing more and each given RPM point which was to be expected. If you're ONLY looking for 275whp, then you should stick with the C30. Even then, you still have the option to upgrade the pulley size as well as add E85, etc. for more performance. If you're looking for 300 and beyond, easily, then the C38 is the better option of the two. Even with the base set of pulleys you will not be disappointed. Once you've become comfortable with that power, you always have the option to upgrade the pulley, fueling, etc. for even more. There are a few already above 400hp as of right now which is not pushing the C38s to their limit by any means. |
#2771 |
If I'm reading that correctly, I think it confirms what I was saying about power across the board being higher with the C38. If not, they would cross somewhere. I'm pretty sure that with the high boost pulley and e85 the differences would be even higher.
#2772 | |
-Thomas |
| The Following User Says Thank You to 86SPEED For This Useful Post: | Derka (01-15-2015) |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
