Old 01-14-2015, 03:15 PM   #1
rixter145
Sleep Chomper
rixter145's Avatar
Do Power Outlets still drain when car is not on?
Hi Everyone,
Been searching around google but had no answer - if you leave something plugged in the power outlets either in glove box or the center console, will the car battery still be discharged when the car is not running?
I know that things are off when the car is off but there was a recent case where my friend's porsche battery died due to him leaving something plugged in the power outlet.
Thanks!
rixter145 is offline   Reply With Quote
Old 01-14-2015, 03:23 PM   #2
Malt
Drives: 2015 WRX
Our power outlets are switched so no power is provided while the car is off (Like you noted). With no power provided to the outlet there is no current available for the device plugged into it to drain. So, no, Leaving something plugged in will not drain your battery.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
rixter145 (01-14-2015)
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
EZ oil drain same as Fumoto? wbradley CANADA 18 06-15-2015 04:40 PM
Drain STA-BIL gas after storing for winter? 1Cor10:23 CANADA 31 02-26-2015 03:17 PM
Re-wire Power outlets 2_slo DIY (Do-It-Yourself) Guides 11 10-04-2014 10:05 AM
Oil Drain Option Carolina Dyno Forced Induction 4 01-22-2014 09:57 PM
