Sam Strano
Old 01-13-2015, 11:46 AM   #2059
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Originally Posted by qoncept View Post
I had a 1987 Cutlass Ciera that could lock up the brakes with $10 pads. Are you saying that's as good as brakes can possibly get?
Ha no not at all. I am saying at minimum, the friction provided by the brake pad should be able to overcome the friction provided by the tire.
Briankbot is offline   Reply With Quote
Old 01-13-2015, 12:30 PM   #2060
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
So you guys have actually experienced brake fade, in a CS twin, with stock pads, at an autocross? I'd like to see the course where this happened... I'm still on the OE pads, and I like 'em for AX + DD.
Autocross nut
AustinTX is offline   Reply With Quote
The Following User Says Thank You to AustinTX For This Useful Post:
tahdizzle (01-13-2015)
Old 01-13-2015, 01:27 PM   #2061
qoncept
qoncept's Avatar
Ain't happening here. The FT86 Speedfactory guys are always screeching without enough heat for whatever pads they're using at autox events. My tires are too hot way before brakes.
Edit: And I was on race tires last summer.
qoncept is offline   Reply With Quote
The Following User Says Thank You to qoncept For This Useful Post:
Old 01-13-2015, 02:02 PM   #2062
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
The only time I may have gotten close to that hot was during our enduro last season.
-Jack Burton
Old 01-13-2015, 02:09 PM   #2063
TrqlessWonder
Drives: 2014 FR-S
In CSR, yes. Local main venue is a go kart track. Getting around there quickly makes the brake action look very much like the bed-in procedure. 50-55ish to 15mph 6-8 times in under a minute, depending on configuration. And you grab third just before the finish. It is only just starting to fade when I brake for shut down though.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 01-13-2015, 03:21 PM   #2064
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
So your CS car does 50 to 15 to 50 in less than 10 seconds while turning and slaloming?
Can I see a video, I bet it is amazing.
bimmer635csi is offline   Reply With Quote
Old 01-13-2015, 03:22 PM   #2065
AustinTX
AustinTX's Avatar
Ouch, what a course - sorry to hear that
Autocross nut
Old 01-13-2015, 08:04 PM   #2066
jonesy
jonesy's Avatar
Drives: 2010 Corvette GS
So I was a couple minutes too late registering for the Prosolo bundle this morning and had to select spring nationals in Lincoln as my 3rd event instead of the 2nd Wilmington Pro as I preferred. Does anyone have an open seat for a codrive in Lincoln? Would like to run the Tour as well as the Pro.
Some background - ~5 years autox experience, trophied at NJ tour in an HS Mini and Wilmington tour in my BRZ last year. Let me know if you or anyone you know has an open CS seat (doesn't have to be a twin). Thanks...
Matt
#73 GS Focus ST/#82 STX BRZ
jonesy is offline   Reply With Quote
Old 01-13-2015, 09:50 PM   #2067
TrqlessWonder
Drives: 2014 FR-S
Take away all the slaloming, and most things resembling a transition element and more or less, yeah. I said it was like the brake bed-in procedure. Stomp on gas, then stomp on brakes. Repeatedly.
I forgot how boring the videos are from this place.
-Mike
#24 CS/CSR
Old 01-14-2015, 12:11 AM   #2068
bslate3
Drives: 2015 CWP BRZ
The Mav region BMW club sets up a crazy fast autocross at Mineral Wells. I hit the top of 3rd gear in my 11 WRX I. 2 spots on the course.
bslate3 is offline   Reply With Quote
Old 01-14-2015, 11:37 AM   #2069
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
That looked like a blast!!!
In like a super sketchy sort of way lol
VADERR is offline   Reply With Quote
Old 01-14-2015, 12:00 PM   #2070
CatDaddysBBQ
Drives: '13 FR-S
So that was 2xof the same bit of track? Looks really fun. Too bad the surface isn't better but d still have a good time at an old kart track. Thanks for sharing.
CatDaddysBBQ is offline   Reply With Quote
Old 01-14-2015, 12:57 PM   #2071
qoncept
qoncept's Avatar
Here's a video from our local go kart track, complete with out-of-sync and poorly calibrated telemetry. First 3/4 lap is untimed.
[ame="https://www.youtube.com/watch?v=iRjj0NYVdv4"]Iowa Region SCCA Autox - 9/14/2014 Run 2 - YouTube[/ame]
Old 01-15-2015, 09:32 AM   #2072
Jack Black
Drives: 2015 FR-S
I haven't experienced brake fade at an autocross, but I have noticed that stock pads require a LOT of pressure to stop at the end of a run and even then they don't engage ABS.
Jack Black is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
