Old 01-11-2015, 09:27 PM   #1
Tenament05
Drives: fast
Exclamation [SOLVED] My AEM Strut Tower Bar is STUCK ON!
UPDATE: Solved by warming the entire engine bay up and pounding on it with a mallet. FFS.
Begin original post
Like the title says.. the TL;DR is that I mocked up (didn't bolt down) an AEM strut tower bar to check for fitment, noticed firewall bolt holes did not line up, and went to take off the strut bar and have now found it seemingly IMPOSSIBLE to remove. It's stuck on. I've tried jacking up the car to remove load from the suspension, beat on it with a mallet, punches, breaker bar.. open to any suggestions
Details below:
Got one off ebay for $190 (yes, I know, moron of the year).. noticed the piss poor shape/looked like it was used right out the box.
I said whatever though, not going to cry over some blemishes and a coat of dirt on a seemingly straight looking piece so I washed it up and went about putting it on the car.
I put the bar on to test fit (ignore the now-torqued nuts) and noticed that the two bolt holes did not line up like they should, leaned over the engine bay to get a closer look (hand on bar), and then determined I should remove the bar and inspect what was going on when..
it wouldn't budge. It just doesn't budge at all, I have no clue how, but in between me putting it on and leaning over to get a look at the bolt holes, the bar wedged itself into my strut towers.
I tried hitting the thing with mallets, leverage a breaker bar, tapped with specialty punches.. I'm not an auto wizard but I HAVE overhauled many things in my life, including a rusted out EJ205. I should be able to tackle this, yet, for fucks sake it just does. not. come off.
I really need to contact the seller but I'm afraid he's going to pull some shit like "you installed it wrong, therefore you messed it up". I am fearing that I may have to get a shop testify for me that it is indeed stuck on and will require professional removal. I've never paid a shop for anything non-bodywork related in my life..
Anyone have a similar occurance? Suggestions? Thoughts?
Tenament05 is offline   Reply With Quote
Old 01-11-2015, 09:30 PM   #2
Dezoris
Dezoris's Avatar
Jack up the car release load from front end and try again.
The Following User Says Thank You to Dezoris For This Useful Post:
Tenament05 (01-11-2015)
Old 01-11-2015, 09:31 PM   #3
De-bounce
Drives: 1
Jack up the car to release the tension. If that doesn't work lower it slowly and try to remove it when the suspension is semi loaded. It will pop out.
De-bounce is offline   Reply With Quote
The Following User Says Thank You to De-bounce For This Useful Post:
Old 01-11-2015, 09:32 PM   #4
Tenament05
Drives: fast
I should add that I've tried that as well.. same result. I will try again tonight to play around with it. Regardless it looks to not fit right at all.. is this normal that the firewall bolts don't align right away and to that extent? It's a pretty significant difference
Thanks for the advice so far guys
Old 01-11-2015, 10:10 PM   #5
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Skillsaw
Glad I found this. Was considering AEM but with your alignment problems and those absolutely nasty welds forget it. That thing is junk.
Originally Posted by paulca View Post
Has anyone mentioned Hitler yet?
Hot Lava is offline   Reply With Quote
Old 01-11-2015, 10:48 PM   #6
Racer-X
Drives: 2016 FR-S
Is it stuck because it is too short or too long? If it's too short, try heating it up.
Racer-X is offline   Reply With Quote
The Following User Says Thank You to Racer-X For This Useful Post:
Old 01-11-2015, 11:21 PM   #7
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
NWFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to NWFRS For This Useful Post:
Bergen23 (01-11-2015), Tenament05 (01-11-2015)
Old 01-11-2015, 11:29 PM   #8
Tenament05
Drives: fast
too short, the bar's strut tower points are pushing into the bolts/studs. Will try heating the whole thing up
Old 01-12-2015, 03:25 AM   #9
Tromatic
The car that came off of was in an accident.
Old 01-12-2015, 10:43 AM   #10
Tenament05
Drives: fast
The seller had a shit ton of them.. it wouldn't surprise me, but it showed 12 available. I'm having a hard time believing he'll sell it at near new price, advertise as new, and have that many defective ones. Confidence in Ebay parts are plummeting lately, damn.
Old 01-12-2015, 11:21 AM   #11
The bolt holes in the pics look way to pristine to have been used/damaged in an accident so my guess is just crappy workmanship from the start.
Ultramaroon (01-12-2015)
Old 01-12-2015, 12:25 PM   #12
Tenament05
Drives: fast
So depressed over this AEM. It's such a sexy bar, too. And I love the brake brace.
Old 01-12-2015, 12:31 PM   #13
Tenament05
Drives: fast
I meant making it not installing it!
yep I gotcha! As soon as I get this thing off I'm sending it back. If I can get it off..
Old 01-12-2015, 01:28 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm assuming you've contacted AEM to start, right?
Used or not, they should be made aware of these things. A braced and triangulated 1-piece strut bar like this should not have that much deflection or be that far off.
-alex
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 11:31 PM
Do I need a Strut Tower Bar? muffinz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 10-11-2014 02:53 PM
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 10:06 AM
Swift Strut Tower Bar tonystewart Brakes, Suspension, Chassis 4 09-18-2013 03:34 PM
FS: Tanabe Strut Tower Bar whataboutbob Brakes, Suspension, Chassis 1 11-20-2012 01:53 PM
