Old 01-04-2015, 11:30 PM   #1387
robr
Drives: 2013 FRS, with boost by ATS Racing
Originally Posted by jflogerzi View Post
Impressive tune for only 5 PSI. It must be aggressive or its the 3 inch exhaust.
I can assure you we don't tune aggressively, especially on pump fuel.
And our dyno reads a few horsepower less than other local dynos. I mean literally a few, like 3-4 usually.
robr is offline   Reply With Quote
Old 01-04-2015, 11:34 PM   #1388
jflogerzi
jflogerzi's Avatar
Then thats a really good tune considering the PSI. Nice job
Old 01-05-2015, 08:27 PM   #1389
Astroboy
Astroboy's Avatar
Drives: None
It's a 2.5" I bought from SRT. Catless
Astroboy is offline   Reply With Quote
Old 01-07-2015, 12:11 AM   #1390
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
Yeah fair enough, I just know I had be exact same issue and it looked exactly the same under the car. After redoing the cam plate 3 times, I eventually traced it back to the oil feed line. Oil would collect on top of the head and then "spill over" and drip down the side. Apparently it's a somewhat common issue and the fix is running 2 crush washers
So I took a look under their oil line Where you told me to look for and sadly I encountered dirty oil build up in that area, but not necessarily from the line... it seemed like it was coming from the the cylinder head. The silicone around it was dealing off like bubble gum... so now I have an oil leak at the scavenger pump at the camplate, top of the head, and oil pan! Have you encountered numerous oil leaks like me?
Old 01-07-2015, 12:22 AM   #1391
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
AVO Turbo Kit Owners Topic
Kind of. It started with very slight oil burning smell at the occasional red light and very small drips of oil on my garage floor. I thought it was the cam plate, but redoing it a few times left me with the same occasional oil drip. By fluke when I was replacing my injectors, I found a small oil deposit by the oil pickup line on top of the block. After Redoing the high temp Teflon on the threads and stacking 2 fresh crush washers, the problem was solved. The reason I mentioned it earlier was because I thought for sure it was a valve cover gasket too, but redoing that oil tap fixed it. Before storing the car a few months ago, I'm at about 10,000km with no leaks.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 01-09-2015, 09:05 PM   #1392
Astroboy
Astroboy's Avatar
Drives: None
Did yours look something like this basically?
Old 01-10-2015, 02:36 AM   #1393
protpibe
protpibe's Avatar
Yeah pretty much. At it's worst, a little pool would form in those ribbed areas where the 220 number is stamped. Under braking, cornering or acceleration it would trickle down the head and drip onto the exhaust. It literally burnt through the ceramic coating on top of my overpipe.
Old 01-18-2015, 08:26 AM   #1394
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Ok guys, I'm starting to get worried. I've been driving yesterday on the German Autobahn with around 200 km/h ( ~120 miles/h for the imperial guys) for an extended period of time. I wanted to check oil levels when I got home and noticed, that the intake pipe, is again a little bit oily.
I'm talking about this area. (old pic without breather tank)
So this is a picture I took after I've been tracking the car without the AVO breather kit. So this is rather extreme and it haven't been oiled up like this yesterday.
Is it normal to be a little bit oily/wet even though the breather tank is installed?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 01-19-2015, 03:44 PM   #1395
AVOturboworld
The breather tank is designed to catch the majority of the fumes, but if you are doing extended 120mph runs, there is probably so much oily fumes going through there that a bit of the oil is going to make it past.
Old 01-19-2015, 06:58 PM   #1396
GremlinGSP
Hey guys does anyone know the specs on the bolts used here?
GremlinGSP is offline   Reply With Quote
Old 01-21-2015, 12:56 AM   #1397
Revzyuu
Drives: GBP '15 STI
Does anyone happen to know the bolt size that bolts the oil case to the turbo? Mines seems to have fallen out at some point and is now caused an miniscule oil leak thats burned through a good bit of tubing for my boost controller and the hose that feeds the turbo directly. Sad to see its deteriorated the coat parts of the compressor housing as well
Blah.
Revzyuu is offline   Reply With Quote
Old 02-06-2015, 04:28 PM   #1398
Musickmixxer90
Drives: Whiteout FRS Monogram
Anyone have experience with intakes? Currently I have the TRD CAI, but I know this will not work with the AVO kit. I remember seeing a post that said with the Perrin intake it pushes the pipe too close to the pulley or something?
Any recommendations for a CAi or just a regular intake?
Musickmixxer90 is offline   Reply With Quote
Old 02-06-2015, 04:44 PM   #1399
protpibe
protpibe's Avatar
Functionally, the stock air box with a panel filter is good until 350whp iirc. I run the Perrin because the turbo sounds better. It sounds ricer but it's the truth haha
Old 02-06-2015, 05:04 PM   #1400
Musickmixxer90
the perrin Cai doesn't give you any fitment problems with the pulleys? idk why, but for some reason I worte that it had that problem when i was doing research on different intakes. maybe I just read somethign wrong
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
