Old 01-01-2015, 11:47 PM   #1597
steve99
Drives: FT86
Originally Posted by coeurdencre View Post
I received my OFT this week and it worked without problem with OpenFlash Manager.
I got the "Cannot create a Tuning file." message after I read my ROM. I sent my stock ROM to Shiv and hope to get a quick reply
you guys are on G rom man and I rom auto same as here in australia
but openflash tablet wont auto generate for some g and i roms however if your A00I A01I A01G A00G D00G you are supported already, but you will have to download tunes v2.062 from openflash site unzip and upload tune via openflash manager software.
if you have an A02G rom or an I rom not supported i would like a copy of the rom thanks
coeurdencre (01-02-2015)
Old 01-02-2015, 12:18 AM   #1598
steve99
Drives: FT86
Originally Posted by rever5e View Post
Any idea what the solution was? I've tried on 3 PC's and i cannot get OpenFlash Tablet to connect to OpenFlash Manager
do you get the windows beep when you connect to usb and does screen on oft light up if nt might be hardware problem try new cable , does it work when connected to car
Old 01-02-2015, 12:20 AM   #1599
rever5e
No it's not an issue connecting. It does work while connected to the car.
rever5e is offline   Reply With Quote
Old 01-02-2015, 05:32 AM   #1600
coeurdencre
coeurdencre's Avatar
Drives: 2014 x ZC6 x 37J
My ROM is a ZA1J700G.
I can see the ROM Stg1 700G/A00G/A01G/D00G.bin in "OFT OTS v2.062\BINs\ZA1J___G ROMS (EU 6MT)\Stage 1" folder
700G ROM is the one I need to use with OpenFlash Manager ?
These ROM are for 91 or 93 ? We got 95/98/100 fuel here...
coeurdencre is offline   Reply With Quote
Old 01-02-2015, 06:11 AM   #1601
steve99
Drives: FT86
american 93 rated fuel is better than most 98 rom fuel. your 95 like ours should only be used in an emergency.
with the european and australian g roms its basicy the 91 tune only offered.
if your going to run 100 ron fuel all the time you could copy the base timing b table from a usa rom to your g rom.
but for now just load up the 700G tune and all will be ok have a read of the oft tips link below
Old 01-02-2015, 06:29 AM   #1602
coeurdencre
I only use 98 not less.
I'll try the 700G, I was not sure about it.
Thanks for information
Old 01-15-2015, 11:57 PM   #1603
mikltov
Drives: Toyota 86
stage 1 vs stage 2 oft
can someone please tell me the difference between stage 1 and stage 2 tunes?
thanks
mikltov is offline   Reply With Quote
Old 01-15-2015, 11:59 PM   #1604
D_Thissen
D_Thissen's Avatar
Stage 1 is stock header. Stage 2 is aftermarket catless header. If I'm not mistaken.
Old 01-16-2015, 12:03 AM   #1605
oliverc
Drives: Surbaru WRB BRZ
Hey guys,
I recently upgraded to the OF Header and the tune for it, but that removed my ability to choose to show what gear I'm in on the dash. Has anyone else had a similar problem and is there a way of easily rectifying it in an editor or something?
oliverc is offline   Reply With Quote
Old 01-16-2015, 12:06 AM   #1606
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Originally Posted by oliverc View Post
Hey guys,
That's turned on from the dash and unrelated to what you can change in an ECU map. The settings usually get lost if the battery is disconnected. Press the odo button multiple times while the car is completely off or in ACC and you should be able to get to G-off, change it to G-on.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Shiv@Openflash (02-18-2015)
Old 01-16-2015, 12:06 AM   #1607
Foobar
SLO NO MO
Foobar's Avatar
Hey guys,
Its not in the tune, its a stalk config option. Check your manual, or there's a few threads here on that as well.
It resets every battery disconnect.
Edit: zkv476 beat me to it.
Old 01-16-2015, 12:15 AM   #1608
mikltov
Drives: Toyota 86
so what tune should i run with my aftermarket EL catted headers?
Old 01-16-2015, 12:30 AM   #1609
steve99
Drives: FT86
Stage 1 tune is the safest one for EL catted header
If by chance you get the P0420 cel code for cat efficiency thrown (its not disabled in stage 1 tunes, just disable it using romraider.
If you get no knock on that tune you could try the stage 2 EL tune, but it runs more timing advance (and more fuel) than stage 1 tune, you will also need to monitor your AFR.
Its unlikely on our 98 ron fuel you will be able to run the stage 2 tune with a catted header without encountering considerable knock.
You could run the stage 2 EL E85 tune if you wanted to switch to E85 fuel and the E85 tune.
Old 01-16-2015, 12:59 AM   #1610
mikltov
Drives: Toyota 86
Thanks heaps man!!
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
