Old 11-17-2014, 06:55 PM   #687
Snowblind
Originally Posted by babydriver View Post
Actually, the redline light now is back. It was only gone for a short time (half-hour of driving time?). I wonder if the electronic ignition controller had to relearn the power curve? Just a guess on my part.
You realize you can set the shift light to whatever RPM you want, right? It doesn't have anything to do with the engine's power output.
Old 11-17-2014, 08:05 PM   #688
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
There's no way the governor wasn't functioning either...
Old 01-02-2015, 03:33 AM   #689
Dr Speed
Drives: Red
Originally Posted by Teo View Post
Someone painted or dipped this part?
I'd like "stealth" engine bay and I wonder if is it possible to dip it (and if resist the paint)
+1, I wish this came in Black..curious if I can retrofit (cut) the perrin intake tube to fit in its place...
Dr Speed is offline   Reply With Quote
Old 04-06-2015, 12:01 PM   #690
cslntuee
Drives: Subaru BRZ Limited
Did the TRD intake need to do the maf-scaling?
Thanks.
cslntuee is offline   Reply With Quote
Old 04-06-2015, 12:03 PM   #691
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Thanks.
You will want to if you can. Sure it does run on the stock tune, but this intake has a lot more turbulence compared to the stock setup and the fact the box is just giant. It's doable though.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
cslntuee (04-06-2015)
Old 04-06-2015, 12:19 PM   #692
cslntuee
I have OFT stage1 tuning now.
Is that good enough to correct those turbulence or I need customize tuning?
Thanks again.
Old 04-06-2015, 12:20 PM   #693
2016 Camaro SS
Drives: Fast
Thanks again.
Might just need to scale the MAF with one of the files that's on this site. I think it's in Steve's thread for MAF scaling. Rest of it should be fine.
Right here: http://www.ft86club.com/forums/showthread.php?t=64790
Old 04-06-2015, 04:42 PM   #694
Kostamojen
Thanks again.
Shiv says the TRD doesn't need to be retuned. Im running mine with OFT stage 2 and zero issues.
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 04-06-2015, 04:57 PM   #695
Thorpedo
The SquadWhisperer
Thanks again.
I have seen it noted that it was really close to stock maf calibration and I have seen another say it was a ways off. Mine is in the "close enough" ballpark, but I'm going to rescale regardless. I'm running Stg 2 UEL with the OFH.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following User Says Thank You to Thorpedo For This Useful Post:
Old 04-06-2015, 04:59 PM   #696
cslntuee
How to do the "rescale"?
I cannot find the post.
Thanks.
Old 04-06-2015, 05:19 PM   #697
Thorpedo
The SquadWhisperer
Link in 2016 Camaro SS's post.
cslntuee (04-07-2015)
Old 05-26-2015, 05:36 AM   #698
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think you need any MAF rescaling. The ECU when it is in closed-loop mode, it takes additional measurements from the O2 sensor and adjusts the AFRs. These measurements are much more exact than the MAF measurements. This is because ECU expects to be able to deal with overly dirty fuel filters and reduced fuel flow issues. Then it also uses these corrections in the MAF readings in open-loop mode. In a sense, the ECU will somehow re-calibrate the MAF readings itself. It might not be perfect, but it will do the job. I would expect issues in the AFR, only if the MAF sensor needs a big re-calibration.
Old 05-26-2015, 06:25 AM   #699
steve99
Drives: FT86
Thanks.
TRD intake unlikely to need maf scaling it was designed to work with stock tune/maf scaling.
Have a look at your LTFT Long term fuel trims if they are over about 7% then maybe worth maf scaling.
If you on OFT Stage 1 tune then Commanded AFR and AFR (measured by 02 sensor) should follow each other fairly closely under load, on overun injectors turn off .
If both of those ok then maf scaling is ok .
like this
http://datazap.me/u/steve99/e85-maf-...zoom=5580-7148
have a read of maf scaling links below.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Chimera (07-01-2015), mgarcia707 (04-04-2019)
Old 01-12-2016, 12:28 PM   #700
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Any before and after dynos with stage 1 OFT? The biggest thing I like about this intake is the angle of the filter pointing air towards the "Inlet tube" while stock points air straight into a wall. Also that there is no curve for air to go through, logically I would think this intake is better designed then most I see out there but I'm probably wrong lol
jaorocks1 is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
