Old 01-01-2015, 12:44 PM   #1
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
7443 led switchback -- do they hyperblink?
I want to get 7443 switchback LED .. but does this cause a hyperblink?
HotLavaChick is offline   Reply With Quote
Old 01-01-2015, 01:15 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Unless you get a resistor or new flasher box yes it will.
Old 01-01-2015, 01:15 PM   #3
Koa
yes.
Old 01-01-2015, 03:13 PM   #4
KI_ZN6
KI_ZN6's Avatar
When you upgrade to LEDs for the turn signal lights, you will need to upgrade the flasher unit under the driver's side dashboard or add in-line resistors to address the hyperblink issue. The flasher unit is the way to go, given that it's a simple upgrade and it will also allow you to revert back to OEM if you had to in the future. The flasher unit upgrade is plug and play and all you have to do is to remove the old flasher unit and install the new flasher unit.
Our newest flasher unit also has a blinking speed adjustment feature to allow you to fine tune the speed of your turn signal LEDs (added bonus).
Feel free to contact us if you have any questions.
KI_ZN6 is offline   Reply With Quote
The Following User Says Thank You to KI_ZN6 For This Useful Post:
HotLavaChick (01-02-2015)
eBay Switchback 7443 LEDs fitment issues in turn signal housing dracullus DIY (Do-It-Yourself) Guides 0 08-27-2014 10:28 PM
PSA: Flipped Connectors on Some VLED 7443 LED Bulbs BagOfArms Cosmetic Modification (Interior/Exterior/Lighting) 0 07-19-2013 02:31 PM
Brightest 7440/7443 LED? V-LEDs worth it? cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-24-2013 05:28 PM
7443/7444 chrome bulbs lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 11 08-05-2012 11:16 AM
