Old 12-29-2014, 07:45 PM   #1
acro
Drives: GT-86
10w 30 from the dealer
Ok so i carry my FRS to the dealer and i see boxes of 10w 30 motor oil being carried to put in my car. I was told when asked that it is perfectly fine for the car, which surprised me
The car is a DD with occasional track days. I live in the tropics so ambient temps are 75 to 95
What do you guys think is it fine. Should i just wait 5000k till the next service and change to 0w 20.
acro is offline   Reply With Quote
Old 12-29-2014, 07:55 PM   #2
Tell them it's not in accordance with any of your documentation. Ask for a copy of theirs.
Old 12-30-2014, 09:46 AM   #3
BRZnut
Drives: BRZ DGM Limited
You know, if you put the wrong oil in on your own and then came to the dealer with a motor issue, they would be quick to blame you for the issue telling you that you were using the wrong oil.
If the receipt shows they used the wrong oil, I would go back with your manual and ask them to change it to the correct viscosity. The 10W-30 may not have even been synthetic! Doubt it would "hurt" the engine, but who knows! Make them do it right!
Old 12-30-2014, 10:04 AM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
Yep, I'm sure it will ruin it.
That's Ford, for instance, takes the exact same engine in the GT Mustang's and runs it on 5w-20, but in the Track Pack (now Performance Pack) cars they run 5w-50.
In the Subaru manual it even says thicker oil is appropriate for high performance use. Where he lives, he's never going to have to worry about the cold pour point of 10w-30.
Old 12-31-2014, 02:28 PM   #5
acro
Drives: GT-86
I will assume this is sarcasm?
I spoke to a senior person at the dealership and they will change the oil at no charge
Old 12-31-2014, 02:52 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
0W-20 is really only there to improve gas mileage and to work in all climate ranges.
You can run a thicker oil for the correct ambient temperature range with no harm to the engine.
-alex
humfrz (01-04-2015)
Old 01-03-2015, 01:21 PM   #7
Amir Ghadiri
Amir Ghadiri's Avatar
It will run just fine. I'm assuming you're NA but most FI guys are running 5w30 or higher, myself included. If you're not comfortable with it then change it out, but as long as it's synthetic I wouldn't worry about it.
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
Chad86 (11-08-2015)
Old 01-03-2015, 02:44 PM   #8
jflogerzi
jflogerzi's Avatar
Running 5w30 in my NA FRS. I do see a 2-3 MPG hit from 0w20.
The Following User Says Thank You to jflogerzi For This Useful Post:
Chad86 (11-08-2015)
Old 01-04-2015, 01:13 PM   #9
acro
Drives: GT-86
Gonna run the 0 20w. What i have noticed with the 10w 30 is that warmup times are much longer. That is a problem as my daily route is about 10 - 15 min. So the car wont be warm till the end of the journey.
hope to change it by next week
The Following User Says Thank You to acro For This Useful Post:
Ultramaroon (01-04-2015)
Error code dealer or no dealer acro Software Tuning 4 11-19-2014 06:29 PM
Quick question about a dealer trading another dealer for the BRZ I want Prog BRZ First-Gen (2012+) — General Topics 17 09-15-2013 04:03 PM
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 04:37 PM
Servicing my FR-S at Subaru dealer rather than Scion dealer dnL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 08-28-2012 08:25 AM
help with dealer wallace03 BRZ First-Gen (2012+) — General Topics 4 06-12-2012 01:53 AM
