#141 |
Now w/ over 400 womprats!
Drives: BRZ LZR
This is fantastic! Sub'd for sure!
- The Ancient BRZ Sacrament by Zaku |
#142 |
Drives: 2013 Subaru BRZ
looking for a cage and I found this
![]() cusco / safety21 makes a weld-in chromoly FIA-approved rally / GT cage... the price is surprisingly not that bad relative to having local shops cage the car, and the design is definitely above and beyond what most of them could do
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
| The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post: | GT86_PRAGUE (12-18-2014) |
#143 |
Drives: GT86
Forgive my ignorance, but if you are getting new motot, new chasis/case, new everything, so what will you use from original car? Registration number?
Anyway, I wish you a success in your dream.
#144 | ||
Drives: 2015 Scion FR-S
Not trying to be a ****, but I doubt anyone would want to use that engine since the fire was located at/on the motor. Quote:
| The Following User Says Thank You to Travisty75 For This Useful Post: | GT86_PRAGUE (12-18-2014) |
#145 |
@GT86_PRAGUE the picture is confusing because everything is painted white, the cusco product is just the roll cage tubing and gussets inside. I'm using the chassis that was in the fire, the rear diff + subframe + suspension, and I suppose that's about it.
You got it though, the registration number is still valid, so after I go through an inspection process, because it's listed as repairable salvage currently, I can actually register it and put it back on the road eventually.
#146 |
@Travisty75 I guess I'll probably wind up tearing the motor down to the shortblock and cleaning that up, and parting the shortblock / head castings / transmission, but that's a lot more work than I had wanted to bother with on a motor I'm not even using. oh well.
#147 | |
Drives: GT86
Good luck.
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | SomeoneWhoIsntMe (12-18-2014) |
#148 | |
| The Following User Says Thank You to Travisty75 For This Useful Post: | SomeoneWhoIsntMe (12-18-2014) |
#149 |
#151 |
so, motoiq is occasionally useful:
from http://www.motoiq.com/MagazineArticl...ubaru-BRZ.aspx "Since the stock electric power steering does not have enough oomph and fades in hard use, a Camry steering rack was used because it had the same mounting bolt span as the stock FR-S rack. To reduce bump steer and to increase rack travel, outer tie rod spacers were made to allow more rack movement and provide a solid steering stop to prevent rack overtravel. The spacers put the outer tie rod joints in line with the lower control arm pivot. Solid rack bushings were machined to get rid of excess slop." They don't explicitly say what camry that steering rack is from, but I'm pretty sure it has to be rack #26-2630. Looking that number up in cardone's catalog lead to me finding that there's another rack that uses the same mounting centers, #26-2632, from the Toyota Avalon. The Avalon rack looks to be about the same ratio, with a slightly longer throw, or at least a little wider. Ordered a reman rack from Detroit Axle on ebay for $120 shipped.
| The Following 3 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post: |
#152 | |
#153 |
my SSR gartmaiers showed up from japan finally.
![]() ![]() I think I'm going to build just one single rear wheel first to make sure the lips and barrels I want to use actually fit, I'm going to do 18x10.5 -32 in the rear to hopefully get me pretty close to good fitment without having to run a huge spacer.
#154 |
Drives: Rocket Bunny'd GT86
@SmsAlSuwaidi you gotta see this thread.
| Dreams | Priapus | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 08-04-2014 11:57 PM |
| Front pipe choices, resonated vs straight pipe | jflogerzi | Engine, Exhaust, Transmission | 4 | 12-29-2013 10:14 PM |
| Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
| BRZ/FR-S Dreams? | MrBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 03-22-2012 08:55 AM |
| Dreams about the BRZ | 86'd | BRZ First-Gen (2012+) — General Topics | 20 | 02-25-2012 10:58 PM |
