Old 12-27-2014, 11:19 AM   #1
Kody
Drives: 2013 Subaru BRZ
OFT - The File Selected Is Not Compliant
Quick question for anyone who may have experienced this problem before...
I've been using the OFT for a little over a year now and love it, I've used both the 91 and 93 stage 1 tunes. I've flashed about 3 or 4 times and know the steps involved in the flashing process (or so I thought).
I'm moving to Atlanta soon and am wanting to flash to the 91 tune (currently at 93) just in case I need to fill up somewhere and they don't have 93 octane gas. However when I attempt to load the 91 tune for my car into the tablet it gives me the 'The file selected is not compliant' message. If I try to load the 93 tune it all works fine.
My CAL ID is: ZA1J900C (US 6MT). I am attempting to load the 'Stg 1 900C' tune onto the table. 93 loads fine, 91 gives me that message...
Anyone else ever have this issue/know how to fix?
Thanks!
Kody is offline   Reply With Quote
Old 12-27-2014, 11:34 AM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks!
I recall there being a problem in one of the older map releases were there was a mislabeled map file. Maybe that is what you are running into. What version map are you running?
Shiv@Openflash is offline   Reply With Quote
Old 12-27-2014, 12:42 PM   #3
Kody
Well, I deleted the map that was on there (the 93 tune) earlier just to see if that somehow was messing anything up ...so I'm not 100% sure. I do know that it was pretty much the first officially released 2.x map that had the 93 octane option for stage 1.
Old 08-14-2015, 01:50 PM   #4
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Was a solution ever found for this? I just installed my opt and im running whatever tunes came on the tablet. When I try to add v1.59 or v2.XX tunes to my tablet I get the message "the file selected is non compliant"
Does it matter what the default program is for the .bin files. My computer automatically chose vlc as default program. I'm new to all this and I have no idea what the problem is.
Edit: ok so I was able to write the 2.067 tune onto the opt. however its A00C when the files that came on the tablet are A01C. Does this matter? My CAL is A00C and it gave me the checksum good message so im guessing im good?
headlikeahole is offline   Reply With Quote
Old 08-14-2015, 03:49 PM   #5
Shiv@Openflash
Drives: 2013 FRS
The calibration ID typo in that particular tune file (Stage 1 900C) was fixed a long time ago. I'm not aware of any other similar issues. If you are getting that error, you are trying to upload a file with a mismatching calibration ID. For example, if your CAL ID Is ZA1JD00C, you will only be able to load D00C tune files.
Shiv
Old 08-14-2015, 03:55 PM   #6
headlikeahole
Shiv
Yeah I was able to upload the appropriate tune A00C for CAL ID A00C. My question now is that the preloaded tunes (and the one my OFT got me to flash my ECU with) was A01C. Does that matter?
Old 08-14-2015, 04:22 PM   #7
Shiv@Openflash
Drives: 2013 FRS
Nope it doesn't matter. Your native CAL ID was in face A00C. It just showed A01C because the OTS maps that were ran were A01C based.
Old 08-18-2015, 10:54 AM   #8
yunheng
***** Lurker
yunheng's Avatar
Drives: 2015 GT86 1990 AE92
Hi,
In regards to previous post, is it safe to say that i can upload a tune file of A01J to a ECU with native calibration A02J by changing the file name to A02J?
Sorry it might be a dumb question, but my car is a late 2014 model and it came with A02J calibration id.
yunheng is offline   Reply With Quote
Old 08-18-2015, 05:01 PM   #9
steve99
Drives: FT86
Originally Posted by yunheng View Post
Hi,
No don't do that you need correct rom type.
Selected gear indicator on dash for Manual transmissions. Rumbaar Cosmetic Modification (Interior/Exterior/Lighting) 18 02-14-2016 08:56 PM
WheelDude.com's Fall Clearance Sale 25% off selected wheels WheelDude.com Wheels and Tires 4 10-01-2014 02:36 PM
which OFT map file to use? BPB stg2 Corradooo Software Tuning 2 06-29-2014 04:09 PM
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 03:46 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 07:19 PM
