#281 | |
Drives: Toyota 86 GTS
#282 | |
Drives: 86
#283 |
#284 |
Drives: 86
#285 |
You should adjust your tune in the worst fuel and conditions then worry about better fuel.
#286 |
Drives: 86
#287 |
#288 | |
Drives: FT86
Fuel trims high 10% check for intake exhaust leaks then a bit of maf scaling might be needed or cleaning maf if you have oiled filter. yes bit of knock top end , pull some timing for out crappy fuels as per @Wayno timing map. |
| The Following User Says Thank You to steve99 For This Useful Post: | Nardi330 (12-16-2014) |
#289 |
Drives: FT86
#290 |
Haha, right on.
#291 | |
Drives: 86
unfortunately too far from home/work. |
#292 |
Drives: FT86
Interesting read here on another type of knock control
Pre-emptive Feedback knock control PEKC http://www.romraider.com/forum/viewtopic.php?t=8509 If Unknown Value(Could be delta load or MAFV) Value is greater than 0.25 could also be a throttle % delta and rapid rise in IAT or If RPM is greater than 1700 or If RPM is less than 4400 or if load is greater than 0.799 or if load is less than 2.8 or if primary ol enrichment is less than 1 (AFR 14.7) or if coolant temp is greater than 78 degrees c then PEKC is active seems to be where we get "tip in knock" |
#293 | |
Drives: UK GT86
.: Stealth 86 :.
#294 |
Drives: 86
quick questions regarding rescaling MAF using the tool developed by Kodename47 (thanks for creating the tool).
this is my first time doing this so sorry with the noob questions. I have been reading the "usage" tab but i'm not sure how to use the tool. - what is the "new maximum desired voltage" and "new minimum voltage"? how should i determine what values to use for these? - "paste original MAF scale into the top table" means putting the value as the "MAF sensor scaling" inside the rom? thanks in advance. |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 11:00 AM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 09:19 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
