Southern California SoCal
Old 12-03-2014, 02:13 PM   #155
Koa
Originally Posted by Corner3garage View Post
Combine any item with spacers and the spacers are only $100 for the set!
http://corner3garage.3dcartstores.co...WRX_p_482.html
I can vouch for these spacers.. been running them on my stock tire setup. They're easily one of the best, if not the best spacer set out there, dollar for dollar. Simply great
The Following User Says Thank You to Koa For This Useful Post:
Corner3garage (12-03-2014)
Old 12-05-2014, 04:13 PM   #156
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Corner3garage is offline   Reply With Quote
Old 12-09-2014, 06:11 PM   #157
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 12-10-2014, 01:53 PM   #158
Corner3garage
Drives: FR-S & BRZ
Old 12-12-2014, 01:59 PM   #159
Corner3garage
Drives: FR-S & BRZ
http://www.corner3garage.com/Perrin-...ing_p_277.html
Rear shifter bushings are moving hot!
Old 12-13-2014, 01:48 PM   #160
Corner3garage
Drives: FR-S & BRZ
Perrin rear shifter bushings are hot right now!
Old 12-15-2014, 01:05 PM   #161
Corner3garage
Drives: FR-S & BRZ
Old 12-17-2014, 02:28 PM   #162
Corner3garage
Drives: FR-S & BRZ
To celebrate the Christmas season, use the coupon code "xmas" to receive and extra 10% discount on your orders until the end of the year!
Old 12-18-2014, 02:50 PM   #163
Corner3garage
Drives: FR-S & BRZ
Ohlins on special till the end of the year!
Old 12-19-2014, 01:18 PM   #164
Corner3garage
Drives: FR-S & BRZ
Old 03-07-2015, 01:11 PM   #165
Corner3garage
Drives: FR-S & BRZ
Old 03-07-2015, 09:59 PM   #166
tracerit
Drives: '13 SSM BRZ Limited 6MT
hey, i emailed you guys on the website about picking up some motul 300 75w90 fluid and the perrin rear shifter bushing this monday. best prices i've seen too. are those in stock?
i also got new wheels/tires (kept stock 17" diameter). not sure if i need an alignment but would like to minimize any abnormal wear on these new tires. is that free alignment only on both camber and rear lca? this is a daily driver for me, so i'm not sure rear lca are something that would benefit me at this point.
you guys are one exit right from my work too!
tracerit is offline   Reply With Quote
The Following User Says Thank You to tracerit For This Useful Post:
Corner3garage (03-09-2015)
Old 03-09-2015, 08:16 PM   #167
Corner3garage
Drives: FR-S & BRZ
Yes!
I believe John got back to you correct?
If you are completely stock and have not changed ride height, you don't have to do an alignment.
Once you lower or modify the suspension you will need an alignment.
Thanks,
Mike
The Following User Says Thank You to Corner3garage For This Useful Post:
tracerit (03-09-2015)
Old 03-09-2015, 08:27 PM   #168
tracerit
Yes!
Thanks,
Mike
Ah, haven't heard back yet. But I couldn't go in this morning, was in a rush. Is Saturday morning 830 a good time? Work graveyards and get off at 730am.
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 01:13 AM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
