| Software Tuning Discuss all software tuning topics. |
#29 |
Erected Member
Drives: frs
Sorry, try the g one i meant. Hope it works for you, if not i hope the guys at oft can help you out, sorry to hear about your issues.
| The Following User Says Thank You to shif7i7down For This Useful Post: | Wise (12-08-2014) |
#30 | |
Drives: FT86
From this sceenshot your calid is A00G so the oft willonly let you load A00G tune files the tune files you need will be under G series then stage 1 if your stock then the A00G file. the files should have .bin extensions. |
| The Following User Says Thank You to steve99 For This Useful Post: | Shiv@Openflash (12-08-2014) |
#31 | |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm waiting on my UEL header to arrive and will be installing that in the next two weeks. I'm guessing in this case, to chang emy tune I'd just select G Folder, then Stage 2 UEL, then the AODG tune? |
#32 |
Drives: FT86
Yes for uel header Stage 2 UEL, then the AOOG tune unless you going to run E85 fuel then Stage 2 UEL E85, AODG tune
#33 |
Circle Work Clerk
#34 |
Drives: FT86
if your in oz have a read here
http://www.ft86club.com/forums/showthread.php?t=61820 our 98 ron is pretty crap and you can benefit from pulling a bit of base timing out of the map. |
| The Following User Says Thank You to steve99 For This Useful Post: | Wise (12-09-2014) |
#35 | |
Circle Work Clerk
| The Following User Says Thank You to Wise For This Useful Post: | steve99 (12-09-2014) |
| Possibility of Live Tuning | brn12345 | Software Tuning | 17 | 03-30-2020 05:39 PM |
| climate control swap possibility | Mrqb22 | Cosmetic Modification (Interior/Exterior/Lighting) | 143 | 03-15-2019 12:46 AM |
| Possibility of ripping paint off from debadging? | Pandanoid | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 10-23-2014 09:31 AM |
| Sorta related... | Skurj | Tracking / Autocross / HPDE / Drifting | 2 | 06-03-2014 10:46 PM |
| Possibility of Scion Sedan? | KidWonder | Other Vehicles & General Automotive Discussions | 6 | 12-16-2011 06:53 PM |
