Old 05-08-2012, 04:47 PM   #15
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I think the TRD supercharger, albeit sacreligious on a BRZ, is the way to go with this car.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-08-2012, 04:52 PM   #16
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
http://www.ft86club.com/forums/showt...370#post204370
- The Ancient BRZ Sacrament
by Zaku
Old 05-08-2012, 04:52 PM   #17
OrbitalEllipses
Drives: Attitude
I think you're on the right track. A supercharger is likely going to be the way to go. Can't wait to experience the OTHER boost.
Old 05-08-2012, 05:05 PM   #18
dsgerbc
Drives: BRZ(sold), STI
Given that it's mated to CVT it's probably a pretty peaky engine and won't be a good match for MT sports car.
Old 05-08-2012, 05:06 PM   #19
SkullWorks
Drives: SSM LT MT BRZ
ummm....not the same motor....
besides that, if you are still fixated on SC's you haven't been paying attention to the latest Turbos...for instance this is my 2.0L SR20
notice it makes 8psi by 3000rmp and that's without using the top wastegate port to assist spool up...
also makes 260whp on 6psi wastegate pressure
Old 05-08-2012, 05:11 PM   #20
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
soooooo engine swap anyone?
Exhaust is offline   Reply With Quote
Old 05-08-2012, 05:12 PM   #21
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Maybe Subaru will Twin Charge it!
Old 05-08-2012, 05:17 PM   #22
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Prob won't work w/o stand alone... Due to different DI
Old 05-08-2012, 05:17 PM   #23
nibor33
nibor33's Avatar
Drives: SSM BRZ-L 6MT (gone)
It's not about the torque curve... Turbos typically have poorer throttle response. The actual spool up time can make throttle modulation difficult. Enought to possibly upset the balance while navigating a corner (at the limits, on a track). I know there are some methods to reduce this response time, but I don't think they will be appearing in daily drivers any time soon. You'll never see throttle response on a dyno graph, since it's floored the whole time.
nibor33 is offline   Reply With Quote
Old 05-08-2012, 05:21 PM   #24
SkullWorks
correct, but I drove it. and while it isn't NA with ITB's quick it will melt tires before the pedal hits the floor and you can get back out...in 3rd gear.
low end boost helps to represent what the throttle response will look like.
Old 05-08-2012, 05:32 PM   #25
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
curse youuuuuu minor oversight!!
Old 05-08-2012, 05:39 PM   #26
arghx7
Drives: car
It's likely this is a downsized and "downspeeded" engine. It probably hits peak torque ostensibly at 1700-2000rpm and falls on its face by 5000-5500. That's how these types of engines are. It may employ heavy use of external EGR, possibly cooled EGR like a diesel.
It's not going to use the D-4S system because there's really no point in doing so. The D-4S system, as currently implemented, is expensive and only makes sense for n/a engines. I suspect this new engine will have one solenoid-type multi-hole injector positioned between the intake valves.
The CVT is a wild card here. The calibration of the CVT and the electronic throttle will affect the driving feel greatly. If you've ever driven a Juke with CVT (1.6 direct injected turbo), they technically heat peak torque at very low rpm but you can't feel it due to the CVT calibration.
Old 05-08-2012, 05:55 PM   #27
Sasquachulator
Pavement Grey
Well the D4-S system is Toyota property.....they probably dont want to share that tech with Subaru on a motor that is seeing Non-Toyota applications.
And doesnt the current new Impreza use a CVT also? I would say that would be a good indication of how the CVT would be calibrated in this new Legacy.
Old 05-08-2012, 05:59 PM   #28
SkullWorks
Negative Charlie.
DI and FI are highly compatible, "as currently implemented" doesn't mean a whole lot, the hardware is there...tune it for turbo...control strategy changes for everything lets not make it out like different shape injectors are needed for turbo, the hardware can go unchanged (except potentially flow rate)
Charge cooling is one of the largest benefits of DI systems and they are all but lost on a N/A motor....FI loves DI
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 01:58 AM
Legacy low-mounted turbo oil pump aspera Engine, Exhaust, Transmission 0 06-16-2010 04:41 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
