#2115 |
Drives: 2013 Scion FR-S Raven
The tunes ability to enhance the exhaust pulse (huge performance improvement) with a long tube equal length header also brings with it a sound, a different sound.
Does your OP/DP have a catalytic converter, a Helmholtz Resonator? On my daughters car, I sold the following to forum members..at a huge loss $$$ Perrin Catted Down Pipe Perrin Cat Back exhaust Current system is FA20club EL catted exhaust header, Perrin Overpipe, Nameless Catted Downpipe with Helmholtz Resonator, Stock catback exhaust with Perrin Tips It's not obnoxious anymore and the datalogs are excellent
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#2116 | |
Builder
Drives: 2014 BRZ - World Rally Blue
#2117 |
Her, like new, Perrin CBE was resonated as well, it was obnoxious, I sat in the back once, couldn't hear myself fart
#2118 |
SLO NO MO
I'm going to have to offer a different opinion than tony - I've got UEL headers (OFH), Perrin 2.5" catted/resonated headerback. I can hear my farts fine in the back
![]() Seriously though, I'm pretty sensitive to noise (I had the Evo3 catback before and had to sell it as it was obnoxiously loud to me, even with silencers). The Perrin system I have is pretty damned tame, the OFH gives it more bite, and you can tell the damned thing has aftermarket headers, but it's still nothing I would consider obnoxious. I could actually go for a bit more if I thought I could without going overboard. |
| The Following User Says Thank You to Foobar For This Useful Post: | Jman1759 (12-04-2014) |
#2119 |
Jman, you have two opinions, get the OFT and adjust accordingly, I hope you fall in the direction of Foobar, saving money is always a good thing
| The Following User Says Thank You to tonystewart For This Useful Post: | Jman1759 (12-04-2014) |
#2120 |
Builder
Thank you both, if hearing is my worst concern then I am happy with my starting point at least! Expecting my OFT in the mail tomorrow and will let you know how it goes, thanks again.
| The Following User Says Thank You to Jman1759 For This Useful Post: | Shiv@Openflash (12-05-2014) |
#2121 |
Builder
@tonystewart @Foobar I installed the OFT today, no problems worked first time. I used the Stage 2 EL tune that came right on the OFT. For me the volume does not sound much louder than it was before the flash. It is definitely not too loud or annoying. My wife said she couldn't tell the difference in sound. I know the flash worked because it is clearly more powerfull in the bottom end and "pulls" at 3800ish rpm which it never did before. My question: is there a more aggressive/newer stage 2 tune that I should be downloading and putting on the OFT to flash?
#2122 | |
SLO NO MO
Sent from my Nexus 5 using Tapatalk |
#2123 |
Drives: None
Quick questions.
Currently running 93Oct Grimmspeed stage 1 If I add headers to my car What do I switch to (still using 93) And what if I switch to E85 after headers?
#2124 |
Drives: GT86 (Auto)
After some messing around (mainly as I run a mac, not windows) - I have flashed, and running the Stage 2, UEL and its going fine.
I have powerblocks, Ultrex headers, catback. Wondered if someone could point me in the direction of dedicated Auto Trans tunes? I spotted a few threads vs google, but havent pin-pointed a specific page yet. Power bands feel better in current set up, but she doesnt like running at low revs, 1,5-2.5 seems muddy.. if that makes sense! |
#2125 |
Drives: JAWS
Stage 2, EL or UEL depending which headers you get. Then stage 2 E85 EL or UEL. When going e85 make sure to follow the correct steps when flashing, there's info on this forum from steve99.
| The Following User Says Thank You to JB86'd For This Useful Post: | VakaGT (12-08-2014) |
#2126 |
Drives: None
alrighty
thank you.
#2127 | |
Drives: Toyota 86 GTS
| The Following User Says Thank You to Wayno For This Useful Post: | Perth-86 (12-09-2014) |
#2128 | |
Drives: GT86 (Auto)
Ill have to invest some time and read up on the 'knock effect' - I am a total nonce when it comes to most IT stuff, so generally look to my mates to assist me, with the car however, not so much. I am running the 1st of the UEL ultrex headers, MULE car! They are sounding mint! I am conscious of not running the wrong tune, the ST2 UEL seems ok so far, but finding others with my Cal code seems limited (running an auto gt) |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
