Old 12-03-2014, 05:19 PM   #15
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Originally Posted by cdrazic93 View Post
I dont think it makes sense either, think about it this way, you have a latter with the rungs spaced 5 feet apart. Its going to take more work to go the distance* than if the rungs were spaced 2 feet apart. QED, the engine needs less work to move one tooth from the higher FD than from stock. This would explain why you tend to accelerate faster with a higher FD.
*song from disney's hercules which has no effect on this conversation at all
Its physics.
W=f*d
Where f is Force and D is Distance.
Where the wheel spin is the W.
More teeth = less force but more distance traveled to produce the same amount of Work.
To go the same speed, your engine needs to spin faster with a gear that has more teeth......
I really don't understand the confusion. Your wheels are not bolted on your crankshaft.....
-Jack Burton
Old 12-03-2014, 05:29 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by tahdizzle View Post
Its physics.
W=f*d
I was talking about from tooth to tooth of the 4.667 FD vs the stock 4.1 FD, not total work done. W not Wnet lol. work is more complicated than just F*D
Its all miniscule though in retrospect.
4.1-4.667 = .567
.567/4.100= .138
so a 13.8% increase over stock. So every RPM you cruise at, add 13.8% to it. Im assuming subtract 13.8% from the normal MPG, given all conditions are the same.
Old 12-03-2014, 08:21 PM   #17
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
4.1-4.667 = .567
.567/4.100= .138
But it's a 13.8% increase in thrust at a given speed, which means faster acceleration. Also depending on the course/track it could put you in a better rpm range, like say instead of constantly shifting between 1st and 2nd, you can stay in second and still be where you want in terms of rpms. That increase can make a big difference on a track. As far as cost mpg wise it's not as simple as taking off 13.8% and there's too many variables to really say with any certainty. As far as top speed that's a really simple problem assuming you have enough power to top out sixth gear.
Amaya is offline   Reply With Quote
Old 12-03-2014, 08:25 PM   #18
86drift
86drift's Avatar
Drives: Toyota 86 GT
Gear display on the dash can be out. I know it was with the 5.1. It can be fixed via a tune. Everything else is fine.
86drift is offline   Reply With Quote
Old 12-03-2014, 08:27 PM   #19
whataboutbob
AutoX-10/10ths every run
BTW, driving from California to the SCCA Nationals in NE with a full set of race tires and wheels in the car as well as tools, jacks, luggage, popup, etc...I got at least 30MPG on the highway at 70MPH on cruse control, supercharged with the 4.556 final drive.
Build thread:Here
Old 12-04-2014, 12:07 AM   #20
s2d4
s2d4's Avatar
Which part of it doesn't make sense?
The affect of increasing the teeth on the final drive?
Or the tire diameter affect on the speedometer?
Neither, other than what wparsons had stated, the following part is completely false. 1 revolution is 1 revolution, the speedometer won't change, but the actual distance travelled and consequently the actual speed is different due to the circumference.
Larger diameter wheels spin slower and smaller diameter wheels spin faster, which is why they have an affect on your speedometer.
Old 12-04-2014, 01:00 AM   #21
phrosty
I assume he meant that at a given speed, small wheels will be rotating faster, so it sounds like you're both on the same page.
phrosty is offline   Reply With Quote
Old 12-04-2014, 03:05 AM   #22
s2d4
s2d4's Avatar
Yeah OK.
Totally makes sense, he was absolutely right.
Old 12-04-2014, 06:19 AM   #23
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i have a 4.56 i thought i would have affected my speedo but it didnt, still accurate to my gps. so im assuming speed isnt taken from the driveshaft. fuel econ isnt a noticeable difference, 6th gear at 70 is like a 600 rpm difference i think.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-04-2014, 05:30 PM   #24
37
degrees
37's Avatar
Drives: 6MT BRZ
I have a 4.67. GPS is dead-on against the speedo at a +1MPH delta at 60MPH with stock tires at 32F/35R PSI (61MPH indicated / 60MPH GPS). That number didn't change with the FD, only after changing wheels/tires.
37 is offline   Reply With Quote
Old 12-05-2014, 04:51 AM   #25
PantsDants
Drives: Scion FR-S A/T, Whiteout
FWIW, there is a table for gear determination thresholds in the map; I'm assuming that's specifically dealing with the gear indicator on the dash for manual cars, because it doesn't seem to do anything on my A/T.
Theoretically you could just calculate the percent increase between your new final drive ratio and the stock 4.1, then increase the values by that percentage. Someone with a manual should test that out to see if it actually works that way.
PantsDants is offline   Reply With Quote
Old 12-05-2014, 04:53 AM   #26
s2d4
s2d4's Avatar
It does.
Visconti Tuning: EcuTek STG1 Pumpgas + E85 + RaceGas Calibrations Visconti Engine, Exhaust, Bolt-Ons 177 12-24-2013 01:29 AM
GT300 BRZ Onboard knoxviue BRZ Photos, Videos, Wallpapers, Gallery Forum 7 08-06-2013 10:51 AM
Drift-Office : EcuTek Calibrations Drift-Office Engine, Exhaust, Bolt-Ons 24 05-21-2013 04:33 AM
Visconti Tuning: EcuTek STG1 Pumpgas + E85 Calibrations Visconti Engine, Exhaust, Bolt-Ons 40 10-26-2012 06:49 PM
Upcoming Shows?? Events?? Food Drives?? Toy Drives?? ESC POD Northwest 6 10-01-2012 12:56 PM
