Drives: 03' NSX & 13' BRZ 6spd Ltd white
Put on new rear tires, now my car handles terrible! WTF?
So after 1.5 years of running with Continental ExtremeContact DW tires, my rears go bald. I change the rears only(with identical tires), and kept the fronts still had nearly 50% of tread left. Now my car handles like total crap with the rear end floating around like crazy causing the traction control to kick in all the time now.
Has anyone else ever experienced this? I've been driving for over 100 miles on the new rear tires, and they are still causing the traction control to activate all the time on fast corners. On freeway interchanges where I normally can drive 50mph, I can't drive more than 35mph without traction control flashing non-stop. I already took it back to my shop to confirm they had the wheels balanced properly. Is it relatively common for new tires to require a long break-in period, or is there anything particular with the BRZ/FRS balance when just changing rear tires? I should add that I'm running a staggered wheel setup on Work Emotion Kiwami's 245/35-18 rears & 225/40-18 fronts, & KWv3 coilovers. (My BRZ basically looks exactly like this Chargespeed car) Thanks for any advice.
#2 |
Same tires as on it before?
#3 |
Drives: 2017 Toyota 86
I personally would have went with 4 identical tires, but I dunno if that would have helped you in your case. Sure the balance all is in check right?
#4 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Your back tires are taller than your front. Were your last set of rear tires that way too?
#5 |
Shriveled Old Member
Drives: 14 Hot Lava FR-S
Ummm... what kind of tires did you buy? If you got some all-season radials with a 60,000 mile wear rating they're not going to stick like a good UHP tire.
#6 | |
idn how far out f&r have to be from each other to confuse the system though http://www.1010tires.com/Tools/Tire-Size-Calculator <- could enter the sizes there to see how far out they are exactly |
#7 |
Give the rears time to lose the grease from the newness then try again. I had the same problem with a new set of S04's but after a few weeks they started holding like I expected.
| The Following User Says Thank You to FirestormFRS For This Useful Post: | FRiSson (12-04-2014) |
#8 |
Thanks for all the input. I should clarify that I replaced the rear tires with the identical brand & size tires as before.
Sorry, I stated the incorrect profile for the fronts... they are actually: Front - 18x8.5 +38 with 225/40 tires Rear - 18x9.5 +38 with 245/35 tires (corrected original post) These tires are Max Performance Summer Tires: http://www.tirerack.com/tires/tires....remeContact+DW Since I've double checked everything, I'm crossing my fingers that it just has a very long break-in period before the new tires start gripping like the worn-in fronts do. Maybe it's time to start doing burnouts! |
#9 |
Drives: None
well its winter now...
#10 |
#11 |
Drives: 2013 BRZ Sport-tech WRB
I found it took nearly 1000 km of driving on my Xi3's before they gripped the way I expected. ABS kicked in stopping normally for a crosswalk on the way home from the tire shop it was so bad at first.
#12 |
Grip>Drift
Drives: FRS
New tires don't stick well. And it's never winter in California!
#13 |
Drives: '13 FR-S Whiteout
Go burn some tire
#14 |
Drives: 2014 FR-S Monogram, Whiteout 6MT
50% in the front? Either you're forgetting to rotate or you're having way too much fun...
2007 Honda CBR600RR-Pearl White/Silver - Totaled ![]() 2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build) φφκα |
| Roof handles anyone? | Ds3ire | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-18-2014 08:42 PM |
| Terrible sound under braking... help? | PoWn3d_0704 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-07-2014 10:53 PM |
| My FRS is Terrible! | TheEradicator | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 08-16-2013 11:08 PM |
| Rear Parking Brake Guard Rub (Meaty Rear Tires) | console_cowboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-13-2013 02:39 PM |
| WTB Door Handles!!!!! | jazztennor | Interior Parts (Incl. Lighting) | 0 | 12-29-2012 07:52 PM |
