#1009 |
Drives: 2013 Whiteout FR-S
Meaty Tire Thread
I have 18x10 +40 ZE40s and running 285/30/18 tires -2 camber up front and -2.5 camber in the rear.. Running KWV3 coilovers, whiteline adjustable toe arms, camber bolts and LCAs, HVT Camber Plates
I just lowered the car back down last night after installing the stoptechs.. So the springs haven't settled in yet, but the rears poke out like crazy.. As far as tire to spring clearance it seems to be ok, until I put some load on it.. Wanted to ask before I hit the road and cause some damage to my wheels and/or springs... Anyone have any rubbing issues? @Jive Turkey @OmarGC @AutoRnD Passenger rear ![]() ![]() Passenger front ![]()
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread Last edited by pleong; 11-26-2014 at 10:41 AM. |
#1010 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Man that is a lot of rear poke, mine are no where near that and I'm currently -1.7ish out back.
As far as rubbing I personally have no issues, but am also only on 265/35's both front and rear. I cant recall the username at the moment but there is someone rubbing under full lock up front on the inner brake line bracket/mount...
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#1011 |
Rear camber doesn't look like -2.5 if front was -2.
Front should always poke more on a square setup as the back has extra ~10-15mm.
#1012 |
Drives: BRZ Limited
Something meaty for Thanksgiving!
![]() ![]() ![]() ![]() 255/40/17 R-S3s, 17x9+42 Rota Titans, front 10mm spacers, RCE Yellow springs, -1.8° rear and -3.1° front camber. |
| The Following 3 Users Say Thank You to fstlane For This Useful Post: |
#1013 |
Drives: 2013 FRS Whiteout
| The Following 7 Users Say Thank You to Pure Automotive For This Useful Post: | Flow (11-30-2014), Koa (12-24-2014), Lorico (03-24-2016), Norville Rogers (08-28-2016), OmarGC (11-30-2014), texasbound972 (12-21-2014), ultra (01-10-2015) |
#1014 |
Drives: '24 GR86
![]() ![]() ![]() More pics. Still need something better to take pictures with
| The Following 5 Users Say Thank You to TylerLieberman For This Useful Post: | boucher (12-07-2014), Guff (11-30-2014), MisterSheep (11-12-2015), OmarGC (11-30-2014), Xuningshen (12-11-2014) |
#1015 | ||
![]() Quote:
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
#1016 | |
My FR-S has 5 gears
Thank you for making me struggle again :'(
Omar GC
#1017 | |
Drives: '24 GR86
The front is about the same as the rear now as far as width goes. Think of it like an s14 running stock rear quarters and origin 20mm fronts.
#1018 |
Drives: Evolution IX, 13' FR-S White Out
I just purchased some Enkei RS05-RR 18x9.5 +43 square wheels for my wife's FRS. She has TRD springs. What is the max width I can go with before I hit the spring perch?
#1019 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
probably a 245, you sure those will clear as is without spacers up front?
#1020 | ||
Drives: '24 GR86
Yeah, as Jive said. You NEED a slip on spacer up front to clear the perch with that wheel. I know people here have run it without and it rubs. I think a 3mm slip on is what people are using.
#1021 |
#1022 |
the tuna, no crust.
you won't fit a 255. hell some meaty 245's won't even fit.
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 06:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
