#15 |
Drives: GT86
#16 |
Drives: 2JZ FRS
This car does the same thing. Haven't figured it out yet
#17 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Lol, I like how this issue crops up everywhere. The AC in these cars is just terrible unfortunately. As near as I can tell you might as well use a box fan if it's above 90 degrees.
Questions for OP: What all has been done to the fuel system? I noticed you're on the stock pump How is the AEM meth kit? What are you running in it and how do you have it set up? What turbo is this specifically? Or is it the same one on the stock Ptuning kit? What are you making on 93? Have you done e85? Are you running a tune that controls for octane rating? Any other supporting mods? (accumulator, oil cooler, failsafe, that kind of thing) Someone else asked this, but what's the deal with Motec? My other questions are more about wear (8k redline/boost vs longevity stuff) and probably aren't things you could comment on yet. |
#18 |
Drives: GT86
1) Stock fuel system
only changed port injectors with the 770cc that came with the kit. 2) meth kit has been performing flawlessly. i connected the pump to the windshield water container and use that as the water/meth container. this helps tell me when the water level is low.. 3) completely stock Ptunning kit 4) I dont expect the numbers to chance much on 93 oct bacause of the meth kit. My numbers seem on par with what people are running with the 93 +meth kit. But without the meth kit i never really tried. I just make sure i always have water/meth in the tank. NO E85...the only E85 we have here is VPracefuels c85 and it is very expensive. 5) what do you want to know about motec. i just got sick of remote tuning. and having to wait for someone else to have time for me plus got a good deal on it.... 6) Aem tru boost boost controller, no oil cooler, I have tried to keep it as simple as possible. on longevity we will see there is no way of knowing yet but if its well tuned there should be no Issues. but we will see...... I have givven a few freinds a ride and still no issues. ill try and get some pull videos on the street so you can see it in action Alf |
#19 |
in orbe terrum non visi
Drives: violent
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#20 |
Junior
Drives: a car
This will be the death of the engine, calling it.
#21 |
Drives: 2013 Black FR-S
If you are curious about how this kit performs with E85 this is what we have seen here between my buddy @mkivsoopra and I who both have the same setup:
On ~E80 6 psi = 280 whp 9 psi = 340 whp 15 psi 450 whp, 360 ft lbs haven't tested beyond that. On 91 pump: 8-9 psi = 270 - 280 whp (with no benefit seen with upping the boost due to timing needing to be pulled)
| The Following 3 Users Say Thank You to sw20kosh For This Useful Post: |
#22 | |
Drives: 2014 Subaru BRZ Limited 6smt
#23 |
Drives: 2013 FR-S Argento
Hah, all depends on how you drive the thing. For street driving and the occasional fun pull you can probably get by just fine. If you're easy and not launching it the drivetrain will probably survive ok as well. I think that AEM controller/failsafe is a really good idea - tune can be great until something goes out of wack, that's where high boost cars really go south very quickly. Keep us posted
#24 | |
Junior
Drives: a car
Theres evidence to suggest otherwise.
#25 | |
Drives: violent
| The Following User Says Thank You to Reaper For This Useful Post: | Calum (11-24-2014) |
#26 |
Junior
Drives: a car
Well that's why!! Your engine doesn't produce enough heat to heat up that amount of oil.
#27 |
Drives: S1000RR
DO NOT attempt to run 500whp (dyno dynamics) on the stock block. The stock connecting rod's will snap at the small end. Speaking from experience
Stay at 450whp or below if you're not ready for a built motor.
#28 |
Drives: GT86
thanks thats where it has stayed.... still running strong.
| PTUNING Turbo Kit Owners Topic | kanundrum | Forced Induction | 1238 | 12-11-2021 09:22 PM |
| PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System | ptuning | Forced Induction | 47 | 06-16-2014 03:52 PM |
| Revworks turbo 10k update | jamesm | Forced Induction | 88 | 02-13-2014 11:54 AM |
| PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 | Events@Ptuning | Tracking / Autocross / HPDE / Drifting | 12 | 01-13-2014 10:22 AM |
| Ptuning turbo kirlt | bjun | Forced Induction | 9 | 11-16-2013 02:14 PM |
