Drives: 2013 Whiteout FR-S MT
Basically zero toe...
So i got an alignment, since i haven't had one done since i bought the car 2 years ago. The front toe .01 and .02 L/R.
The rear is .07 and .1, so toed out. I've read that most autocrossers prefer a toe-in in the rear. My question is is the rear to essentially zero rear toe? or would it be better to zero and possibly get it toed in a bit. Use: street with ~monthly autocrossing. Thanks EDIT: NM figured it out, toed in just a touch, feels better.... Last edited by iaclimber4; 11-15-2014 at 09:16 PM. |
#2 |
The Stig's German cousin
Find a different alignment shop next time. .01/.02 in the front is a little sloppy, they should be able to hit 0. If you know any local autocrossers they can probably point you in the right direction.
#3 |
Drives: Subaru
Toe-in on the rear is good. It gives the car stability under braking.
#4 |
Nothing wrong with 0 toe if you can handle it.
#5 |
I tried 0 toe on basically stock suspension for my last track weekend. I'm also running slightly more front camber than rear:
Front: -1.4L, -1.5R Rear: -1.0L, -1.4R The balance felt good. I still got some understeer, but at least it's pretty stable on turn-in and trail-braking, and you can provoke the rear under power.
2022 BRZ Build 2013 FR-S Build |
#6 | |
Get some more front camber! |
#7 |
Haha I know. Working on it. There's not much clearance at the strut, so I may need camber plates or coilovers.
#8 |
Overthinking it
Drives: BRZ in CS
It's a little hard to get super precise on an alignment rack. It may read at 0.0000" toe, but there is enough play in suspension bushings, etc that you might be good for 0.0x" toe. Same with camber.
Measure with a ruler, mark with chalk, cut with an axe. |
#9 | |
I also feel a shop that will take the time to get exactly 0 is a shop that takes pride in doing it right, and they're a lot less likely to fail in tightening something properly leading to the alignment staying true for longer. Since we're sharing proverbs...an ounce of prevention beats a pound of cure.
#10 |
A skilled tech can get it dead on, every time. This is what sets aside someone with a "good enough" mentality and a "perfect" mentality. The amount of time it takes to get "perfect" is the same as "good enough", if the tech is talented and cares enough.
#11 |
Drives: '13 Denali, '15 Volt, soon a BRZ?
Or you could set the toe like F1 and NASCAR teams do, with string.
http://i.imgur.com/3WXBmc5.jpg Let's be honest, a second or third significant digit past the decimal isn't so significant... |
#12 |
oh hell, i thought this was a dead thread, didn't realize people posted. thanks!
So i ran it the other sunday at an autocross event that was on a track. Even with minimal toe-in on the rear, the car felt better than it ever has. Really planted and much less oversteer. Still a little bit of oversteer on the sweepers, but under slight power. Actually thinking about increasing the stiffness of the front sway (20mm whiteline). I've only been autocrossing about a year, so wanted to play around with the settings now that i have a little bit of seat time... |
| SOLD: OEM Tail Lights (basically brand new) | swift996 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 05-05-2014 09:04 AM |
| Hyper Rev magazine - basically a massive parts catalogue. | diss7 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-18-2014 12:26 PM |
| Import Tuner Meet (they're basically looking for a feature car) | Giccin | Southern California | 43 | 04-01-2013 02:06 AM |
| So basically I got to go to Japan to build my own BRZ? | mike@vossen | BRZ First-Gen (2012+) — General Topics | 40 | 10-31-2012 02:29 PM |
