Old 08-01-2014, 02:33 PM   #1
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
2014 Bespoke head unit no longer sees USB port
Title should read "2013 Bespoke..."
Today while making a stop, not out of the car for 10 minutes, all the sudden the USB port was no longer detected. Working great, turn off the car, turn the car back on and no USB. Tried multiple restarts of the car but the USB never came back. It does not appear that any of the external sources work, Bluetooth, 1/8" jack nothing but AM and FM are listed. I really haven't used any of the other connections. Very odd and very annoying.
Anyone seen this before? Is there a factory reset or something I can try to get the headunit to see the USB port again?
Last edited by 5hairpins; 08-01-2014 at 03:27 PM. Reason: Wrong info in title - Dope
5hairpins is offline   Reply With Quote
Old 11-16-2014, 02:17 AM   #2
zeal86
zeal86's Avatar
Drives:
This just happened to me yesterday... although a little differently. I just reinstalled my headunit after a backup camera install; after turning on my 86 to check the function of the BU camera I noticed the usb selection was grayed out.
I'm pretty sure I reconnected all connectors on the back of the head unit. Tried turning the car off then back on again as you did but that did not work. I'll troubleshoot tomorrow and post what I find out.
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
Old 11-16-2014, 02:36 AM   #3
zeal86
zeal86's Avatar
Drives:
Searching around on the net I found this:
To FIX the problem...the gray cable (for USB/AUX) that would plug into the back of head unit, actually gets plugged into the EXTENSION box (Navi/Bespoke) that gets mounted under head unit.....its the port right next to where the GPS Antenna goes.
This might be my fix but not sure about you. This would make sense if you had recently removed your head unit but you wrote you just turned off your car. Have you recently removed your headunit?
Old 11-16-2014, 03:10 PM   #4
G.I.Choe
Drives: 2013 Scion FRS Argento
Let's start with the least invasive solution: have you tried using another USB cable?
G.I.Choe is offline   Reply With Quote
Old 11-16-2014, 03:19 PM   #5
zeal86
zeal86's Avatar
Drives:
In my case yes...actually another thumb drive...that did not work.
@5hairpins what else have you tried? At some point today I'll take another shot at troubleshooting. I'll post what I come up with.
Old 11-16-2014, 04:09 PM   #6
zeal86
zeal86's Avatar
Drives:
@5hairpins, I would verify the connection at the Harman Automotive extension box and at the USB/aux connector. I read on another forum where the problem you are having was due to a unsecure connection. The post stated they realized that was the case when they tapped the area near the USB/aux plug and the signal would return intermittently.
My issue is due to me reconnecting the USB connector into the wrong port.
Old 11-16-2014, 04:38 PM   #7
zeal86
zeal86's Avatar
Drives:
Verified my issue...I had plugged the USB connector into the wrong port.
I did notice that the harness that connects from the extension box to the USB/aux has a loose feel... meaning it isn't rigid as some of the other wire harnesses and bundles... it moves around easily. Worth looking into the connectors at both sides of that harness.
2014 New Head Unit Bluetooth Question (w/ Bespoke Featuring Aha + NAV) applekash Electronics | Audio | NAV | Infotainment 22 09-15-2016 05:19 PM
