Old 10-11-2014, 03:36 AM   #295
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Here the addresses dump for B01D:
Code:
RaM_Fuel_Type                                   FFF8DC2A
RaM_LTFT                                        FFF8DB90
Ram_AFR_Sensor_Heating_Limit_Result             FFF88478
Ram_AF_Correction_3_32bit_ECU                   FFF8A900
Ram_AF_Learning3_Percentage                     FFF8DC10
Ram_AF_Learning_3                               FFF81640
Ram_AF_Sensor_1_Current                         FFF8932C
Ram_AF_Sensor_1_Resistance                      FFF89344
Ram_Accelerator_Angle?                          FFF8B5B8
Ram_Accelerator_Pedal_Angle                     FFF89230
Ram_Accelerator_Pedal_Angle_0                   FFF8DC14
Ram_Accelerator_Pedal_D                         FFF8DC00
Ram_Accelerator_Pedal_E                         FFF8DC04
Ram_Alternator_Duty                             FFF884A4
Ram_Ambient_Air_Temperature                     FFF8DBF8
Ram_Atmospheric_Pressure                        FFF8DBCC
Ram_Atmospheric_Pressure_1                      FFF89B94
Ram_Auxiliary_input_output_supported            FFF8DC2B
Ram_Base_Pulse_Width                            FFF89744
Ram_Base_Pulse_Width_times_100_0.84             FFF89CC0
Ram_Battery_Voltage                             FFF87C6C
Ram_Battery_Voltage_0                           FFF8DBD8
Ram_Brake_Switch                                FFF89393
Ram_CPC_Valve_Duty_Ratio                        FFF89CD0
Ram_CPC_Valve_Duty_Ratio_0                      FFF8BD28
Ram_Calculated_Base_Pulse_Width_                FFF8A058
Ram_Catalyst_Temperature_Bank_1_Sensor_1        FFF8DBD4
Ram_Clutch_Switch                               FFF893A7
Ram_Commanded_Secondary_Air_Status              FFF8DC29
Ram_CoolantTemperature                          FFF890A4
Ram_Coolant_Temperature???                      FFF87C74
Ram_Defogger_Switch                             FFF8939F
Ram_Distance_Traveled_since_DTCs_cleared        FFF81CBA
Ram_Distance_Traveled_with_MIL_On               FFF81CB8
Ram_EVAP_Commanded_Purge                        FFF8DBC4
Ram_EVAP_System_Vapor_Pressure_Absolute         FFF8DC0C
Ram_Engine_Load_Absolute                        FFF8DBDC
Ram_Engine_Load_Calculated                      FFF8DB84
Ram_Engine_Oil_Temperature                      FFF8DC20
Ram_Engine_Speed                                FFF89570
Ram_Exhaust_VVT_Retard_Angle_Left_              FFF8C148
Ram_Exhaust_VVT_Retard_Angle_Right_             FFF8C144
Ram_Fuel_Air_Commanded                          FFF8DBE8
Ram_Fuel_Injector_1_Pulse_Width                 FFF887D8
Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0
Ram_Fuel_Injector_2_Pulse_Width                 FFF887DC
Ram_Fuel_Injector_Pulse_Width?                  FFF88810
Ram_Fuel_Pressure_MPa                           FFF89378
Ram_Fuel_Pump_Duty                              FFF8B1B4
Ram_Fuel_Rail_Pressure_direct_inject            FFF8DBB8
Ram_GDI_Flow_Rate                               FFF88844
Ram_Gear                                        FFF895E5
Ram_High_Low_Load_0_L_1_H                       FFF8A0F8
Ram_Idle_Switch                                 FFF8B5C6
Ram_Ignition_Total_Timing                       FFF8AE0C
Ram_Intake_Air_Temperature                      FFF8DBA4
Ram_Intake_Air_Temperature_0                    FFF87C64
Ram_Intake_OCV_Current_Left                     FFF891B8
Ram_Intake_OCV_Current_Right                    FFF891AC
Ram_Intake_OCV_Duty_Left                        FFF8C20C
Ram_Intake_OCV_Duty_Right                       FFF8C218
Ram_Intake_Temp                                 FFF890B8
Ram_Intake_VVT_Advance_Angle_Left               FFF8C100
Ram_Intake_VVT_Advance_Angle_Right_             FFF8C0FC
Ram_Map                                         FFF8DB94
Ram_Map_Delta?                                  FFF8A234
Ram_Mass_Airflow                                FFF89118
Ram_Mass_Airflow_0                              FFF8DBA8
Ram_Number_of_warm_ups_since_DTCs_cleared       FFF826CE
Ram_O2_currrent                                 FFF8DBD0
Ram_O2_volt                                     FFF8DBC0
Ram_Per_Injector_Pulse_Width_Compensation_A     FFF8AB44
Ram_Per_Injector_Pulse_Width_Compensation_B     FFF8AB4C
Ram_Per_Injector_Pulse_Width_Compensation_C     FFF8AB54
Ram_Per_Injector_Pulse_Width_Compensation_D     FFF8AB5C
Ram_Per_Injector_Pulse_Width_Compensation_E     FFF8AB64
Ram_Per_Injector_Pulse_Width_Compensation_F     FFF8AB6C
Ram_Per_Injector_Pulse_Width_Compensation_G     FFF8AB74
Ram_Per_Injector_Pulse_Width_Compensation_H     FFF8AB7C
Ram_Rear_O2_Sensor                              FFF8DBB0
Ram_Roughness_Monitor_Cylinder_1                FFF8CEDD
Ram_Roughness_Monitor_Cylinder_2                FFF8CEDE
Ram_Roughness_Monitor_Cylinder_3                FFF8CEDF
Ram_Roughness_Monitor_Cylinder_4                FFF8CEE0
Ram_Run_Time_Since_Engine_Start                 FFF84DB4
Ram_SI_Drive_Mode_I3_S1_SSharp2_                FFF88999
Ram_STFT                                        FFF8DB8C
Ram_Throttle_Opening_Angle                      FFF8DBAC
Ram_Throttle_Opening_Commanded                  FFF8DC08
Ram_Throttle_Position_relative                  FFF8DBF0
Ram_Time_Run_since_DTCs_Cleared                 FFF81CBE
Ram_Time_Run_with_MIL_On                        FFF81CBC
Ram_Timing_Advance                              FFF8DBA0
Ram_Transient_Threshold_Testunk                 FFF89240
Ram_Vehicle_Speed                               FFF8DB9C
Ram_Vehicle_Speed_0                             FFF893D0
Ram_coolant_temp                                FFF8DB88
Ram_fuel_level                                  FFF8DBC8
Ram_lambda                                      FFF8DBBC
E_AF_Correction_1_4byteExt_E81                      FFF8A5EC
E_AF_Learning_1_4byteExt_E48                        FFF8A774
E_AF_Sensor_1_4byteExt_E91                          FFF89330
E_CLOL_FuelingExt_E33                               FFF8DC26
E_Closed_Loop_Fueling_Target_4byteExt_E121          FFF8A6D0
E_Engine_Load_4ByteExt_E32                          FFF8914C
E_Engine_Speed_Delta_E157                           FFF89408
E_Feedback_Knock_Correction_4byteExt_E39            FFF8B0C4
E_Final_Fueling_Base_4byteExt_E123                  FFF8A01C
E_Fine_Learning_Knock_Correction_4byteExt_E41_      FFF8B160
E_Fuel_Injector_1_Latency_4byteExt_E50              FFF8A05C
E_Fuel_Injector_1_Pulse_Width_4byteExt_E60          FFF887C8
E_IAM_4byteExt_E31                                  FFF816F0
E_Idle_Speed_Map_SelectionExt_E49                   FFF8B748
E_Ignition_Base_TimingExt_E53                       FFF8AE88
E_Knock_Correction_Advance_4byteExt_E43             FFF8B0C0
E_Knock_Correction_Advance_IAM_onlyExt_E40          FFF8B134
E_Knock_Correction_Advance_Max_PrimaryExt_E118      FFF8B12C
E_Manifold_Relative_Pressure_4byteExt_E113          FFF88F78
E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52 FFF88F74
E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84     FFF8A988
E_Requested_TorqueExt_E56                           FFF8B4A4
E_Target_Throttle_Plate_PositionExt_E57             FFF8B58C
E_Throttle_Plate_Opening_Angle_4byteExt_E38         FFF89030
E_Tipin_ThrottleExt_E54                             FFF89038
Td-d is offline   Reply With Quote
The Following 3 Users Say Thank You to Td-d For This Useful Post:
phrosty (10-11-2014), steve99 (10-11-2014), thambu19 (12-13-2015)
Old 10-11-2014, 10:40 PM   #296
phrosty
Right on
What data are you generating these from? I can infer some of the info from what others have posted, but is there a document that shows the data types and units of measure of each address?
phrosty is offline   Reply With Quote
Old 10-11-2014, 10:59 PM   #297
steve99
Drives: FT86
Originally Posted by phrosty View Post
Right on
have a look at some of the logcfg.txt files and substitute in the ram addresses from your rom the scaling datatype should be same its generally just the ram address that changes. the names of ram address location may not be eaxactly the same sometimes it a bit of trial and error
unfortunatly no doco, if you find some post it up
Old 10-12-2014, 01:47 AM   #298
Td-d
Right on
That's why we need to get these into standard notation sooner rather than later - your best bet is the logger.xml file from the Romraider Logger, combined with a look through the other logcfg.txt files users have put out there.
Old 10-28-2014, 07:39 AM   #299
steve99
Drives: FT86
Old 11-03-2014, 03:32 PM   #300
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I have version 1.59 OTS maps for OFT with the latest rom file listed as B01C. That means that all files are B01C calID? Also has anyone tried to log a ECUTEK tune with OP2?
Toyota John is offline   Reply With Quote
Old 11-03-2014, 04:29 PM   #301
steve99
Drives: FT86
NO !!! it does not you have to check with hex editor. or check table integrity. see first post.
It should work if you match the RAM addresses with the tune calid, have not done it though. I believe they just change seed keys to prevent reading/writing of rom but RAM addresses for log parameters are likely the same.
Old 11-11-2014, 08:53 PM   #302
Toyota John
Calle Atun
I am getting close to figuring out logging with the tactrix OP2 but I keep getting a logcfg.out file and red with flashing green lights. Any ideas?
Old 11-11-2014, 09:17 PM   #303
Toyota John
Calle Atun
Ha I got it. It was the Triggers. I remove the defrost trigger and it work. Steve99 also said he had a problem with the defrost trigger. Any one else have a trigger that works well I could use.
Old 11-11-2014, 09:24 PM   #304
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I couldn't get any triggers to work so I just plug mine in when I want to log and pull it out when I'm done (lol). Much easier with an obd2 extension cable.
B-R-Z is offline   Reply With Quote
Old 11-12-2014, 10:46 AM   #305
Toyota John
Calle Atun
Originally Posted by vgi View Post
i'm using the defrost trigger occasionally, the down side - it shuts off in about 20mins.
it's also kinda hard to get it working. I thought that the cfg file must be in asc order (which is how my file is done, that is numeric asc order - not string asc order, based on hex memory address which is a number) but then someone said it didn't work for him (although i donno if he sorted by string or number).
Can you post the order you used to get the triggers to work. I am not sure i follow the numeric order.
Old 11-12-2014, 02:55 PM   #306
vgi
Drives: frs
Again, I'm not sure if this will work all the time, maybe it just happened to work for me.
so let's say you have:
paramname = Manifold_Relative_Pressure
paramid = 0xFFF88F78
isfloat = 1
paramname = Direct_Ijector_PW
paramid = 0xFFF887E8
isfloat = 1
paramname = Direct_Injector_PW_Ram
paramid = 0xFFF887F0
isfloat = 1
The memory addresses above in bold are numbers, so sorted numerically in asc order would be:
isfloat = 1
isfloat = 1
isfloat = 1
vgi is offline   Reply With Quote
Old 11-12-2014, 04:26 PM   #307
Toyota John
Calle Atun
Did you mix the triggers in with the rest or leave them at the bottom?
Old 11-12-2014, 10:56 PM   #308
vgi
Drives: frs
pmed
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
