Old 07-09-2014, 06:21 PM   #1
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
RPM hesitation on WOT?
Hey guys,
I'm still not sure if this is an ignition coil problem or a DI failure. No popping noises for me, had the P0351 code pop up a lot of times and cleared it a lot of times, it's just that it came up at high RPMs and didn't do any harm or show anything like the ignition coil is really faulty. But, now there's no CEL and whenever I go WOT I can feel the car hesitating like some sort of lag whenever under 5k RPM, and after 5k RPM the rpm goes up smoothly. Any idea?
My best bet is the ignition coil giving away, but can someone explain to me the symptoms of a direct injector failure as to relating that failure to my problem? did it cause any mis-fire or hesitation on WOT when your injector failed?
Yamajee is offline   Reply With Quote
Old 07-09-2014, 06:43 PM   #2
steve99
Drives: FT86
Originally Posted by Yamajee View Post
Hey guys,
definitely looks like coil 1 failed (last digit is coil number) , this coil seems to fail the most maybe due heat , when code returns leave it up ,should be done under warrante unless you have significant mods eg turbo.
you usually get firecracker/popping sounds with DI seal failure, often with no cel.
Old 07-09-2014, 06:46 PM   #3
Yamajee
Yamajee's Avatar
I've had this ignition coil issue for nearly a year now and the dealer is still convinced that it's out of their hands and ordering it from Japan will take over 45 days, (yaay Dubai), might replace it myself, no mods just an exhaust.
No sounds for me, just the usual sounds of engine mis-firing with no backfire or anything, that feeling when it wants to rev but it holds itself as if you're letting off the gas pedal and then back full and so on.
[ame="http://www.youtube.com/watch?v=VnFa2IvNs9g"]Frs popping noise when given throttle free revving or cruising, rolling on throttle to pass. - YouTube[/ame]
is this what DI failure sounds like?
Old 07-09-2014, 07:00 PM   #4
steve99
Drives: FT86
Hard to tell from video but does not sound good, definitly get dealer to check it out as it will cause further problems (often serious) if it is DI seal fail in progress.
its not a simple job
http://www.ft86club.com/forums/showt...t=di+seal+fail
Old 07-09-2014, 07:02 PM   #5
Yamajee
Yamajee's Avatar
That wasn't my car, found the video on youtube and thanks I'll check out the links.
Old 11-08-2014, 08:56 PM   #6
Astroboy
Astroboy's Avatar
Drives: None
Hey guys,
Did you ever solve the issue you were having? What as it?
Astroboy is offline   Reply With Quote
Old 11-10-2014, 11:50 AM   #7
Yamajee
Yamajee's Avatar
Had to clean out the injectors to resolve this issue, some had to replace them but cleaning them worked for me.
Old 01-06-2015, 10:24 PM   #8
fmsida
Drives: 2013 DGM BRZ
How did you clean them out or what process did you take? I am having similar issues, please PM me if you get a chance.
Thanks.
fmsida is offline   Reply With Quote
Old 01-10-2015, 12:43 PM   #9
Yamajee
Yamajee's Avatar
Thanks.
No clue, the dealership did that for me.. however, I do know that when injectors are cleaned, it's through a special machine made to clean them.
Something like this.
The Following User Says Thank You to Yamajee For This Useful Post:
fmsida (01-14-2015)
Hesitation right off idle D K Software Tuning 5 06-03-2014 04:41 AM
Hesitation/Cutting out in 5th and 6th gear WRBRZ Engine, Exhaust, Transmission 5 08-05-2013 12:21 AM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 05:21 PM
