Old 10-31-2014, 05:29 PM   #113
cawith
Drives: Toyota GT86 6M/T
Hi guys,
Got my OFT a couple of weeks ago but just made the first log today. The car is running smoothly, so I'm not looking for any faults. Just trying to learn what all these figures show.
Would you look at my log and tell me, if everything is as it should be? My car is almost stock, only mod is a HKS dropin filter. I'm planning on a FT86SF UEL header next year, but right now only running stage 1. I'm always on Shell V-Power, which is 99 RON in my country, and the only fuel with a minimum of 98 RON as stated in the manual.
I must say the car is running so much better after the stage 1 file has been flashed!
http://www.datazap.me/u/cawith/ots-s...7-8-9-10-11-12
One more question: In OFM my car's CAL is ***A00G, but the files loaded are A01G. How come? Those are the files which came with the OFT, and was no problem flashing it...?
cawith is offline   Reply With Quote
Old 11-02-2014, 03:43 PM   #114
zeppy
Drives: subaru brz-limited
Originally Posted by phrosty View Post
Looks like you let up on the throttle after 6400?
But yea, looks a bit lean. Next time you do a WOT pull, include Commanded AFR in your logs -- it'll let you easily see what AFR it wants you to be at.
New log, 91 tune running 93 oct. Looks much better
http://datazap.me/u/zeppy/91oct-stg1...a=1-9-12-13-14
zeppy is offline   Reply With Quote
Old 11-05-2014, 02:31 PM   #115
Hungrr
Drives: 2014 Subaru BRZ
I have two third gear pull logs. Both have knock correction at low rpm. Thoughts?
http://www.datazap.me/u/hungrr/3rd-g...ata=5-28-33-39
93 octane
Fbm basekit
Hungrr is offline   Reply With Quote
Old 11-05-2014, 03:01 PM   #116
phrosty
93 octane
Fbm basekit
Is such a rich AFR normal for turbos?
phrosty is offline   Reply With Quote
Old 11-05-2014, 09:54 PM   #117
JMoody
Drives: 2016 FR-S
Did my first data log with OFT just to see what it's like. This is using the 93oct tune. The car is stock with K&N filter. Just waiting to run the 93 out so I can fill with e85. The log is kind of long with random driving and a couple 2nd and 3rd pulls. I somewhat understand what I'm looking at here. Would you add or remove any of the things it's logging?
http://www.datazap.me/u/jmoody/first...g?log=0&data=1
JMoody is offline   Reply With Quote
Old 11-07-2014, 06:27 AM   #118
steve99
Drives: FT86
Originally Posted by cawith View Post
Hi guys,
have a read of oft tips link below the calid change is normal means your actually running an A01G based map. you log link not working.
Old 11-07-2014, 12:25 PM   #119
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I'm sorry if I missed it but is there a link or something to show ranges that your car should have on the data logs?
Kelbyat07 is offline   Reply With Quote
Old 11-07-2014, 01:46 PM   #120
cawith
Sorry, the chart should be visible now.
I have already read the thread with all the tips in it, was just not sure if I'd understood it correctly.
Still trying to figure all this technical stuff out, that the OFT can show.
Old 11-07-2014, 05:13 PM   #121
steve99
Drives: FT86
have a read of logging links below
Old 11-07-2014, 05:16 PM   #122
steve99
Drives: FT86
log look fine
Old 11-09-2014, 10:17 AM   #123
cawith
log look fine
Thank you very much!
Old 11-17-2014, 09:34 PM   #124
underpowered
Drives: brz
Can you guys please look at this log for me. This is my first log with the oft. I am running the stage 1 map. I just put on the grimspeed intake and logged it to see what it looks like. The beginning of the log is a third gear pull and then driving on the highway running from third into 6th and back down again a couple times. I am trying to learn how to tune this with the oft. Please tell me if I am interpreting this correctly. Am I correct in thinking the car pulled timing @ 1.38. This is the first time kc learned value changed and the ignition advance drops. I am a little confused though because i thought the iam would drop once the car has seen knock from what I read on this forum. Then at 45.92 the kc learned starts to rise and the knock correction numbers start going negative but the iam doesn't change. Are both of these events knock? I have read a bunch of the tuning threads on this forum I just want to make sure I am looking at things correctly. Any suggestions would be greatly appreciated. http://www.datazap.me/u/underpowered...0&data=0-1-4-6
underpowered is offline   Reply With Quote
Old 11-18-2014, 11:51 PM   #125
phrosty
tl;dr please format your text better!
What's in the log itself looks okay, but you need to add some things to it for a fuller picture. put knock correction, LTFT, AFR, and Commanded AFR on there.
Old 11-21-2014, 12:30 AM   #126
underpowered
Drives: brz
Thanks for taking a look at the first log Phrosty. This is the second log with the parameters you asked for. http://www.datazap.me/u/underpowered...o=2&zoom=3-167
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
