Drives: Toyota 86
Wilwood parts combination similar to Sprint Kit
I've been searching for a budget brake upgrade with enough heat capacity and long pad life for track usage. I don't think big sized rotor is required to our applications, especially for my 16-inch wheel setup.
I've checked @diss7 's fitment checking thread and am sure that my SSR Type C 16x7.5 +35 will fit Sprint Kit. But after noticing AP 8350 caliper is almost same form factor as Wilwood SL4R/SL6R, I'm thinking about combining Wilwood parts to make a similar brake as Sprint Kit. What do you think? Disc rotor : 160-11837 (R/H), 160-11838 (L/H), 11.75x1.25, 129.59$ each, 259.18$ total (parts changed) Hat : 170-9206 (offset 1.1") 134.93$ each, 269.86$ total (offset is not fixed yet. have to calculate.) Caliper : 120-13231 (Forged Superlite 4R), 248.34$ each, 496.68$ total Pad : typical 7420 Bracket : 250-9208 (WRX BBK bracket), 147.32$ each, 294.64$ total (may require shortening 3mm) Last edited by makinen; 11-02-2014 at 12:32 PM. |
| The Following User Says Thank You to makinen For This Useful Post: | DAEMANO (11-01-2014) |
#2 |
#3 | |
Drives: Toyota 86
But 317mm rotors are too big to 16" wheels. |
#4 | |
If your brakes fail, you are NOT going to be happy. |
#5 |
Drives: 2015 Series.Blue
You're looking at rear use rotors that aren't made to take the abuse and heat of track use in front (at least on a grip car)
You should be looking at the GT rotors: http://www.wilwood.com/Rotors/RotorP...emno=160-11837 http://www.wilwood.com/Rotors/RotorP...emno=160-11838 |
#6 |
Time Traveller
There's almost always benefits to technical exploration, who knows, you might indeed find information of value. Dont be discouraged, and keep it up OP.
#7 |
Thanks
Do it right the first time saves momey too. Good luck op. Post pics and results of your finished product please
#8 | |
Drives: Toyota 86
I'm not familiar with Wilwood parts, so this kind of information is very useful. |
| The Following User Says Thank You to makinen For This Useful Post: | DAEMANO (11-02-2014) |
#9 | |
Drives: Toyota 86
I'll invoke the plan after checking almost everything I can think of. That's why I posted this thread and ask your opinion. |
#10 |
Drives: 2013 Ultramarine FR-S
I am going to follow this closely. I am currently running a half DIY wilwood kit for a WRX. I am running into issues with the Calipers flexing, and getting air in the calipers that I cannot account for. I have sealed all the lines and I am not leaking any fluid. I also want a lighter rotor than the STI rotors it currently uses.
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 06:53 PM |
| Any site with a diagram of parts? Similar to realoem.com for BMWs | tracerit | BRZ First-Gen (2012+) — General Topics | 6 | 03-15-2015 12:39 AM |
| Opinons on this combination | cjcoupe | Engine, Exhaust, Transmission | 6 | 02-04-2014 01:45 AM |
| CMS SEMA 2013 Coverage - AP Racing Sprint and Endurance Kits by Essex Parts | Circuit Motorsports | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-16-2013 05:08 AM |
| How similar are all the different carbon parts? | Norcalmav23 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-13-2013 04:51 AM |
