Old 11-02-2014, 03:02 PM   #15
Dipstik-sportech
Dipstik-sportech's Avatar
Same engine design? Like another boxer or another fa20? 23psi on a gtx28 on pump gas!!?? Wow that turbo is going to be blowing nothing but hot air over 18-19psi. If I was going twin scroll I would've done a gtx3071 at a minimum, that's why u go twin scroll is so u can use a larger turbo but not lose spool. Having a lower compression engine allows for more air from a larger turbo. I think that the little 28 just doesn't have the lungs to feed the demands of a built lower compression fa20. Mine hit 360whp on 91 pump at 16psi
Old 11-02-2014, 04:19 PM   #16
Tiz
Drives: Subaru BRZ
@Dipstik Not another boxer but another FA20
@all It seems that a GTX2867R is simply not capable of reaching its hp rating on pump gas. A bigger turbo seems to be a better choice.
Tiz is offline   Reply With Quote
Old 11-02-2014, 04:48 PM   #17
Dipstik-sportech
If you factor in 17% drivetrain loss you're at 430ish whp so that's not bad considering.
Old 11-02-2014, 04:53 PM   #18
Tiz
Drives: Subaru BRZ
Unfortunately, I believe it's the other way round. The dyno numbers I got (350-370hp) have already factored in the drivetrain loss. This is what OEM car manufactures and European tuners do. In other words, the whp are lower...probably around 300 whp.
I am not sure whether the supposed drivetrain loss is 10, 15, 17 or 20 percent.
Old 11-02-2014, 05:08 PM   #19
Dipstik-sportech
So u only made 350 crank !!???? How is that even possible?
Old 11-02-2014, 05:08 PM   #20
DRACHENV6
Drives: tata nano
can you post the dyno sheets?
DRACHENV6 is offline   Reply With Quote
Old 11-02-2014, 05:17 PM   #21
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Sounds like @Synack s car
Old 11-02-2014, 05:28 PM   #22
Tiz
Drives: Subaru BRZ
I do not have dyno sheets right now. Tuning is still work in process and I got only preliminary results so far. But I will post follow-up info asap.
Old 11-02-2014, 08:45 PM   #23
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Something is not right, I'm making 303whp at 10.5psi with a ebcs, 2.5 exhaust. gt3076 front mount/FMIC el headers. stock internals, injectors and fuel pimp. I am AT as well
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 11-02-2014, 08:47 PM   #24
Reaper
Reaper's Avatar
Drives: violent
He's lower compression. That requires more airflow from an already undersized turbo (when twin scroll)
Old 11-03-2014, 12:24 PM   #25
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yep lowered compression needs more boost to make the same power. Now with lowered compression it's going to be a lot safer, a little more lag, and have higher potential (if you want it).
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 11-20-2014, 05:07 PM   #26
Tiz
Drives: Subaru BRZ
Update: My tuner found the missing power. Now the car makes approx. 410bhp and 500nm torque. More or less flat torque curve starting from 3300 rpm.
BUT: The OEM AT transmission cannot handle so much torque. Does anyone know about an upgrade? I understand that SSP is developing something?
Thanks.
Old 11-20-2014, 05:18 PM   #27
Koa
What was the problem?
Old 11-21-2014, 02:36 AM   #28
Tiz
Drives: Subaru BRZ
I believe the diameter of one of the pipes was too small -> resulting in back pressure and high intake temps.
Feeler: Twinscroll Turboed Battleship Grey Rocket Bunny FR-S deedz Cars for Sale/Trade 44 06-03-2016 10:31 PM
ACT 6 Pug Problems, anyone have it like me? kombatlion Engine, Exhaust, Transmission 12 08-06-2014 12:30 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
Turbo Problems VisionRx7 Forced Induction 27 04-07-2014 11:05 AM
Turbo Problems please help whitefrs Forced Induction 126 05-02-2013 08:29 PM
