Old 11-01-2014, 07:30 AM   #1
makinen
makinen's Avatar
Drives: Toyota 86
Wilwood parts combination similar to Sprint Kit
I've been searching for a budget brake upgrade with enough heat capacity and long pad life for track usage. I don't think big sized rotor is required to our applications, especially for my 16-inch wheel setup.
I've checked @diss7 's fitment checking thread and am sure that my SSR Type C 16x7.5 +35 will fit Sprint Kit.
But after noticing AP 8350 caliper is almost same form factor as Wilwood SL4R/SL6R, I'm thinking about combining Wilwood parts to make a similar brake as Sprint Kit.
What do you think?
Disc rotor : 160-11837 (R/H), 160-11838 (L/H), 11.75x1.25, 129.59$ each, 259.18$ total (parts changed)
Hat : 170-9206 (offset 1.1") 134.93$ each, 269.86$ total (offset is not fixed yet. have to calculate.)
Caliper : 120-13231 (Forged Superlite 4R), 248.34$ each, 496.68$ total
Pad : typical 7420
Bracket : 250-9208 (WRX BBK bracket), 147.32$ each, 294.64$ total (may require shortening 3mm)
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
DAEMANO (11-01-2014)
Old 11-01-2014, 11:15 AM   #2
White64Goat
Have you read this thread through?
http://www.ft86club.com/forums/showthread.php?t=70194
Old 11-01-2014, 12:04 PM   #3
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by White64Goat View Post
Yes.
But 317mm rotors are too big to 16" wheels.
Old 11-01-2014, 03:10 PM   #4
CSG Mike
CSG Mike's Avatar
What do you think?
Disc rotor : 160-2898 (R/H), 160-2899 (L/H), 11.75x1.25, 40.98$ each, 81.96$ total
Pad : typical 7420
When the rotors are less than 1/3 the cost of the OEM rotors... it may make you second guess your purchase.
If your brakes fail, you are NOT going to be happy.
Old 11-01-2014, 03:48 PM   #5
Poodles
Drives: 2015 Series.Blue
You're looking at rear use rotors that aren't made to take the abuse and heat of track use in front (at least on a grip car)
You should be looking at the GT rotors:
http://www.wilwood.com/Rotors/RotorP...emno=160-11837
http://www.wilwood.com/Rotors/RotorP...emno=160-11838
The Following 2 Users Say Thank You to Poodles For This Useful Post:
DAEMANO (11-01-2014), makinen (11-02-2014)
Old 11-01-2014, 04:43 PM   #6
DAEMANO
Time Traveller
There's almost always benefits to technical exploration, who knows, you might indeed find information of value. Dont be discouraged, and keep it up OP.
Old 11-01-2014, 05:08 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
Do it right the first time saves momey too. Good luck op. Post pics and results of your finished product please
Old 11-02-2014, 08:02 AM   #8
makinen
makinen's Avatar
Drives: Toyota 86
Thanks.
I'm not familiar with Wilwood parts, so this kind of information is very useful.
DAEMANO (11-02-2014)
Old 11-02-2014, 08:09 AM   #9
makinen
makinen's Avatar
Drives: Toyota 86
I agree.
I'll invoke the plan after checking almost everything I can think of. That's why I posted this thread and ask your opinion.
Old 11-03-2014, 01:58 PM   #10
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I am going to follow this closely. I am currently running a half DIY wilwood kit for a WRX. I am running into issues with the Calipers flexing, and getting air in the calipers that I cannot account for. I have sealed all the lines and I am not leaking any fluid. I also want a lighter rotor than the STI rotors it currently uses.
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 06:53 PM
Any site with a diagram of parts? Similar to realoem.com for BMWs tracerit BRZ First-Gen (2012+) — General Topics 6 03-15-2015 12:39 AM
Opinons on this combination cjcoupe Engine, Exhaust, Transmission 6 02-04-2014 01:45 AM
CMS SEMA 2013 Coverage - AP Racing Sprint and Endurance Kits by Essex Parts Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 11-16-2013 05:08 AM
How similar are all the different carbon parts? Norcalmav23 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-13-2013 04:51 AM
