Old 10-30-2014, 07:51 AM   #225
ALB
I'm not the expert on this so I don't even know if this could cause your code, but is it possible you got the placement of the 2 sensors backwards?
ALB is offline   Reply With Quote
Old 10-30-2014, 09:07 AM   #226
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
The one cable isn't long enough to reach the proper plug if you do. You have to unbolt the plugs to get it to reach, you'd know if they were backwards. Ask me how I know
Jrdad is offline   Reply With Quote
The Following 3 Users Say Thank You to Jrdad For This Useful Post:
ALB (10-30-2014), Apoc (10-31-2014), flippy (12-16-2014)
Old 10-30-2014, 02:07 PM   #227
tomaszjanczak
Drives: Silver Subaru BRZ
its possible their is leak near 02 sensors.
- Exhaust leak near rear O2 sensor
- Faulty rear O2 sensor
- Fuel contamination
Check the connection to the rear o2 sensor the plug may not have been pushed all the way in.
I did check the connection, everything is clicked in place.
My data log is absolutely terrible. Even IAM is .76 when running 91 octane tune with 93 octane fuel! I have bad luck. Long term fuel trims 14-15. AFR and wideband AFR reading totally different.
Here it is: http://datazap.me/u/tomaszjanczak/ce...h?log=0&data=5
Apart from OpenFlash Tablet tune and OpenFlash header I am 100% stock down to the stock air filter.
tomaszjanczak is offline   Reply With Quote
Old 10-30-2014, 04:06 PM   #228
lucid215
i would say reflash and go from there
lucid215 is offline   Reply With Quote
Old 10-30-2014, 08:07 PM   #229
steve99
Drives: FT86
I think you have air leak exhaust leak near primary 02 sensor or before it at connection to engine _ The primary 02 is following commanded afr reasnobly well but its needing large fuel trims to do so . The second 02 sensor is reading very rich as it appears to be reading correctly and its also reading combined afr from all cylinders not just one like the rimary o2 sensor.
That or something weird like stuffed o2 sensor or you have pluged them in or installed then in incorrect positions.
tomaszjanczak (10-31-2014)
Old 10-30-2014, 10:15 PM   #230
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
- Have a look around the flanges....do you see any soot or black marks?
- Do a soap test to determine it there are leaks.
- Unplug both O2 sensors and re-install again....just to be sure.
I'm very curious to know what's causing these issues, so keep us updated on this.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Old 10-31-2014, 02:52 PM   #231
Foobar
SLO NO MO
Foobar's Avatar
Installed today on my Vortech/Perrin 2.5 catted/resonated Headerback and applied the OFT300 tune. Car sounds badass now when I put the gas on, still sounds tame when I'm just taking it easy.
Good stuff!
The Following 3 Users Say Thank You to Foobar For This Useful Post:
bee_are_zee (10-31-2014), lucid215 (11-03-2014), Pbrown (11-01-2014)
Old 11-01-2014, 03:56 PM   #232
tomaszjanczak
So I just got under the car, the bolts connecting header to engine needed a tiny bit of tightening to get to correct torque amount, which I did. Primary O2 sensor was already as tight as it could be. Secondary O2 sensor I couldn't get a good grip on it with any wrench because of the weird position so I couldn't see if that needed tightening.
I started the car and did the soapy water test and I found no leaks anywhere, neither at the gaskets or O2 sensors. Took a thin piece of paper and put it around everywhere to see if it blows from the leaks, absolutely nothing.
OpenFlash Tablet shows basically the same thing as last time (I only checked during idle). Secondary O2 sensor still reads high 11s AFR at idle and the other 2 are close but long term fuel trim is 13-14% at idle.
I couldn't smell any exhaust fumes while under the header either. O2 sensors are screwed in the right places and to the correct plugs. Don't see any black marks near any of the gaskets.
Old 11-01-2014, 10:53 PM   #233
s2d4
s2d4's Avatar
Which parameter are you reading the secondary AFR?
Old 11-02-2014, 04:35 AM   #234
steve99
Drives: FT86
wideband afr.
the cal might be a bit off but it follows the front o2 reading pretty well on my car, untill the primary 02 goes past its narrow range.
the second o2 is a bit more wideband than primary o2
you rearly need the bosh wideband sensor but its a usefull test
Old 11-02-2014, 04:40 AM   #235
steve99
Drives: FT86
Well its looking like something wrong with 02 sensor, unless the maf sensor has some problem but then you would think both 02 should be reading rich.
02 sensor probably not cheap so it may be worth taking to a shop to be sure, i dont trust my diagnosis that well from other side of the planet.
o2 sensors can be damaged if dropped or impacts or if deformed too much torque applied to tighten.
i ran a thread tap through the o2 fitting to clean up threads before fitting o2 sensors.
tomaszjanczak (11-02-2014)
Old 11-02-2014, 06:59 AM   #236
s2d4
s2d4's Avatar
wideband afr.
Yeah, thought so. Is it actually linear?
Initially the idea was just using the o2 sensor but pretty sure shiv said it needs a controller more recently?
Old 11-02-2014, 07:15 AM   #237
steve99
Drives: FT86
Yes pretty sure you need bosch sensor and controller. But stock sensor seems to have similar calibration to what they set up wideband afr for, reads fairly close to front sensor, good enough for comparision (would not tune off it) if you think you have crook sensor. next time you log with oft try logging afr, wideband and commanded afr they all follow fairly well.
Old 11-07-2014, 02:29 PM   #238
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
guys i had my headers installed yesterday and replaced my tranny & diff fluid with motul gear 300 it's so god damn awesome!!! it's not much louder than stock and more rumbly yet smoother. also flashed stage 2 oft v2.0x oh baby! pulls so hard after 3000rpm =]
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
The Following 4 Users Say Thank You to flippy For This Useful Post:
akahenry (11-08-2014), Apoc (11-07-2014), Kronos (11-07-2014), Lonewolf (11-09-2014)
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
