Old 01-28-2013, 09:45 AM   #15
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
The 3 way junction is 1/8" NPT? Can you take a pic? :-D thanks!
Sent from my HTC One X using Tapatalk 2
Pure Automotive is offline   Reply With Quote
The Following User Says Thank You to Pure Automotive For This Useful Post:
Sportsguy83 (01-28-2013)
Old 01-28-2013, 11:31 PM   #16
xwd
Those brass tees are notorious for cracking at the threads and is exactly what I was talking about.
Old 01-28-2013, 11:43 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm going with the gallery plug. Thanks a lot for your help!!
Old 05-09-2014, 09:24 PM   #18
w3bhead
Drives: A Car
Hi guys, I'm planning to install an oil pressure/temp gauge and I was wondering where I could get a more accurate reading. Which is better to put into the galley plug, the oil pressure or temperature sensor? Or is it okay if I just run both on a sandwich plate?
w3bhead is offline   Reply With Quote
Old 10-29-2014, 12:24 AM   #19
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@Sportsguy83 did you ever get this finished? Thinking about getting the FastWRX gallery plug / sender relocation kit that was posted earlier for myself.
Old 10-31-2014, 12:10 AM   #20
cocoy_labuyo
Drives: WRB BRZ
I'd like to do this DIY as well. I'm deciding to install the sensor in the unused gallery plug. Anyone know where I can wire a defi gauge?
cocoy_labuyo is offline   Reply With Quote
Old 02-02-2015, 04:17 PM   #21
Xuningshen
Drives: Subaru BRZ
I was reading on NASIOC, and some WRX guys are were replacing the idiot light switch with their pressure senders, basically unplugging them, and they didn't have any CEL or issues? Has anybody tried that on our cars?
my plan at the moment is to use that relocator kit posted above, remove the idiot light switch, plug the SS line to where the idiot light switch was, run the SS line to a Tee, then plug in both switch and pressure sender into the T. any real problems with that setup?
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 02-04-2015, 08:07 PM   #22
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
So when I am ready to install Oil Temp gauge, which one should I Tee up?
Left or right? (I saw @getbent said you should tap to the one on the left, just want to confirm). Also, anyone know what size fitting is needed? Links? Pictures? Thanks!
Edit: @onemorelap where did you end up connecting and using what? (Longshot since he has not logged in since August.. but who knows!)
@PrimeMotoring @Rev Works may be able to help too.
So which one was it? I think it's the one on the right but the AEM fitting I have doesn't fit. Is there an adapter I should use from subaru? Thanks.
texasbound972 is offline   Reply With Quote
Old 02-05-2015, 12:01 AM   #23
Sportsguy83
Drives: Limited BRZ
I didn't use either. I used a plug on the top of the block.
I believe left is oil pressure and right is oil temperature.
Old 03-21-2015, 04:55 PM   #24
dustmann
Drives: '14 WRB BRZ Limited
Reviving this thread, so as to not start another one. I am about to install oil pressure and temperature gauges. I am planning to use the galley plug for temp, and the stock pressure sender location for oil pressure. My question is, can I just toss the stock sender and ground the stock sending wire? I don't want the oil pressure dummy light to be on all the time on my dash.
On the WRX the stock oil pressure dash light switch is a normally closed grounding switch that opens and breaks the ground when it senses 2.5 psi of oil pressure. Does anyone know if the FA uses the same type of switch?
This document is what gave me the idea
dustmann is offline   Reply With Quote
Old 03-21-2015, 08:12 PM   #25
Kirby64
Drives: Galaxy Blue BRZ
You can toss the stock oil pressure sensor and just tuck away the stock sender line. No need to ground it at all. I tossed mine and tucked the wire, installed a real pressure gauge in the same spot (off a tee, since it's also my turbo feed) with no problems and no nanny lights
Kirby64 is offline   Reply With Quote
The Following 3 Users Say Thank You to Kirby64 For This Useful Post:
Bykov (12-13-2016), fableluke (09-04-2021), NotSoJDM (07-22-2015)
Old 03-22-2015, 07:02 PM   #26
dustmann
I like the sound of that! Thanks for the info! Now just waiting on the galley plug in the mail and I'll be ready to install
Old 03-22-2015, 11:45 PM   #27
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Could you post a pic or two of your setup?
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Teclis (07-04-2015)
Old 03-23-2015, 10:27 AM   #28
Basket Case
Drives: 2013 Raven fr-s
where are people mounting their gauges? I see the a/c vent gauges, but honestly with as hot as it gets here in summertime I do NOT want to block any airflow to me...I feel like the a/c can't keep up as is...
Basket Case is offline   Reply With Quote
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 02:01 AM
Self-diagnostic busses? Specifically oil pressure? Nezz Electronics | Audio | NAV | Infotainment 6 08-13-2012 09:34 AM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 10:04 AM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
