Old 10-26-2014, 10:45 PM   #239
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
that last fuel you had was rearly crappy iam 0.5 and still knocking , i think its just that crappy fuel still in the tank 1/4 tank is 15 litres or more , next fill should be better, try united 100 if its near you same price better fuel. At least the iam is now at 1.
i reckon that last fuel you had was 95 or 91
hi steve, if you have some time can you have a look at my log? did a couple of third gear pulls, this is on your a01g map with bpb changes added. i'm seeing knock but iam is at 1? Completely new to this, so any advice would be much appreciated. i have a track day this weekend and i'm not sure if this map is safe or not to run with.
http://datazap.me/u/ykpap1/3rd-gear-...4&zoom=691-836
blue cat is offline   Reply With Quote
Old 10-26-2014, 11:40 PM   #240
steve99
Drives: FT86
Those bpb changes just add more overall ignition advance, which looks like our fuel does not cope with too well.
was that the v2 ao1g map ?
looks like you will have to pull some timing where its knocking at the load/rpm points probably about 1.5 degrees. or run united 100 octane fuel if you not already doing so .
i dont have bpb but @Wayno does and he has been working on some maps think he is running into same issues see his posts at end of shivs bpb tutorial thread
Old 10-26-2014, 11:49 PM   #241
blue cat
blue cat's Avatar
thanks, yes it was your v2 ao1g map. i will try and make some changes to improve things and look through that bpb thread. In your opinion is this safe to run on track as it is now? i ask not because i'm too lazy to make the adjustments but because i have no knowledge in tuning and will be starting from scratch tonight on learning this stuff. i don't forsee myself being able to make any great strides before this weekend
edit: just realised my LTFT is showing negative??
Old 10-27-2014, 12:03 AM   #242
steve99
Drives: FT86
ltft positive or negitive does not matter its the value thats important if it less than about 5% all good, over 10% its time to scale maf.
no i would not go to track with tune pulling over 2 degrees unless your going to run much better fuel on the day. like Elf 102 race fuel or something.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
blue cat (10-27-2014), Wayno (10-27-2014)
Old 10-27-2014, 05:39 AM   #243
Wayno
Wayno's Avatar
You can start with these.
Regular:
https://www.dropbox.com/s/96ubc1fg48...10-27.zip?dl=0
Intake Runners:
https://www.dropbox.com/s/ub43qxqzqo...10-27.zip?dl=0
Total pain in the ass. Even the P100 maps are a work in progress.
The Following User Says Thank You to Wayno For This Useful Post:
Old 10-27-2014, 08:15 PM   #244
blue cat
blue cat's Avatar
thanks wayne i'll do that.
@steve99 generously did me a conservative quick fix to run the car safely at the track this weekend. i did a log after driving the car for about 60kms or so and it's night and day from before. link:
http://www.datazap.me/u/ykpap1/2nd-g...s?log=0&data=1
Old 10-27-2014, 08:30 PM   #245
Wayno
Wayno's Avatar
Cool, can you zip it and post it up?
Old 10-27-2014, 08:43 PM   #246
steve99
Drives: FT86
Use at own risk ect blah blah
https://drive.google.com/file/d/0B67...ew?usp=sharing
Old 10-30-2014, 12:58 PM   #247
Wayno
Wayno's Avatar
Honestly, I'm almost at the point of reducing the timing even less than without the intake spacers. Even if I went back to straight 91 map I'd have a shitload of knock at 5000rpm with spacers. And that's on P100.
http://datazap.me/u/wayne/206-stg2-u...og=0&data=1-14
Old 10-31-2014, 10:45 PM   #248
Wayno
Wayno's Avatar
Finally got rid of the knock with the intake runners, basically the same as P100 map but with less timing at 5000-6000rpm and put the per cylinder compensation back in.
P0420 removed on all maps.
Knock prevention for high intake air temp on all 98RON/P100 maps.
Knock prevention for high coolant temp on all 98RON/P100 maps.
Un-neutered cold starts to wake the dead.
Modified radiator activation temps for idle.
Soft rev limits.
Stg1 98 - Steve's map for 98RON.
Stg1 100 - 91AKI map for United P100.
Stg2 EL 98 - My map for 98RON.
Stg2 EL 100 - OTS 91AKI map for United P100.
Stg2 EL E85 - OTS E85 map for United P85.
Stg2 UEL 98 - My map for 98RON.
Stg2 UEL 100 - OTS 91AKI map for United P100.
Stg2 UEL E85 - OTS E85 map for United P85.
https://www.dropbox.com/s/zr1g82z5zg...11-01.zip?dl=0
The Following 3 Users Say Thank You to Wayno For This Useful Post:
blue cat (11-01-2014), Gums (11-02-2014), Turdinator (11-09-2014)
Old 11-01-2014, 10:43 PM   #249
Wayno
Wayno's Avatar
So,finally got intake runner tune dialed in...but wait, there's more.
Here's the difference between street and track.
Street - 0 knock
Track - > 2 deg knock
E85 is so much simpler
Old 11-02-2014, 07:13 AM   #250
Wayno
Wayno's Avatar
Intake runner maps for our shitty, shitty fuel.
I'd recommend "Stg2 UEL BPB 100 v7 track A01I.bin". You could run 98 on it as long as you switched to P100 for the track.
Only need to copy Base Timing B. They keep the PCC tables unmodified.
https://www.dropbox.com/s/b5avqtbhm3...11-02.zip?dl=0
Gums (11-02-2014)
Old 11-09-2014, 05:27 PM   #251
blue cat
blue cat's Avatar
Hey Wayne, noob question alert, your maps are for autos how much is transferrable to a manual map?
Old 11-09-2014, 05:48 PM   #252
Wayno
Wayno's Avatar
You can compare mine to of the shelf 2.0 A01I to find all the modified tables.
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
