Old 10-24-2014, 10:45 PM   #1
mhughett
Drives: 2015 Crystal White BRZ Limited
1st trip to the track
I have a 2015 BRZ with about 600 miles. I've tried to keep it below 4k rpm (very difficult) and have not used the cruise as per the manual. Next month, I plan to take it to the track for the first time. By then, it will have > 1,000 miles so no worries about the engine break-in.
My question is about whether I should change out the factory oil before the track even or not. I'd like to remove any break-in metallic particles before track use but on the other hand, if break-in oil is used for the factory fill, should it remain in the engine longer than 1k miles before getting changed. I know this is a topic with a lot of different opinions but I'd love to see what people think.
One last thing--would it be a good idea to mix 0w20 Mobil with 0w40 European Mobil 1 when I go to the track to get better engine protection? This is the same Mobil1 used by Porsche in its cars. Just a thought.
mhughett is offline   Reply With Quote
Old 10-24-2014, 11:04 PM   #2
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Would this be your first time on a track?
If so, I'd go as is... You'll be overwhelmed with handling yourself before you have a chance to catch up to your car's needs.
If anything, keep check on your brake fluid and pads. If you're completely new, you may not even have to worry about them for the time being as well.
Just in case you were wondering, I plan on getting my first oil change done between 3-5k miles, and that's probably after a couple track events and daily driving.
Texas BRZ is offline   Reply With Quote
Old 10-24-2014, 11:12 PM   #3
gramicci101
Off Topic
This thread is also a great reference.
The Following User Says Thank You to gramicci101 For This Useful Post:
Texas BRZ (10-24-2014)
Old 10-24-2014, 11:40 PM   #4
mhughett
This is definitely not my first time to the track. I used to have a BMW Z4M Coupe and just recently an Audi TT-RS. I've had both of them at the track several times. Even if I leave in the factory oil, I may change to some ATE 200 brake fluid for a little more brake performance.
Old 10-24-2014, 11:52 PM   #5
Texas BRZ
Imperfect
Texas BRZ's Avatar
Okay, that helps me understand better. When I had my '13 FR-S and started tracking it after building up some good experience from the past, my brake fluid boiled and stock pads went out pretty quick... And I try to be as easy on them as possible but they still let me down as I was working my way up to the higher run groups.
After I upgraded the brake pads and fluid on my stock FR-S, I had no issues, except for the sliding around on the stock tires but I was okay with that fun! Fyi, I upgraded to Ferodo DS2500 pads and Motul RBF600 fluid... Worked out very well with the stock car and tires. I plan on doing the same with my incoming '15 BRZ as well.
Old 10-26-2014, 09:30 PM   #6
mhughett
Anyone got any input on this idea or is it not worthwhile trying this and staying with straight 0w20 or just leaving the original factory fill in?
Old 10-26-2014, 09:39 PM   #7
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I think factory fill should be fine, change your brake fluid.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Texas BRZ (10-26-2014)
Old 10-27-2014, 04:53 PM   #8
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
My first track event was with the factory fill, there's really nothing to worry about. Just check the oil during the event.
I did change the brake fluid before the event and recommend you do the same.
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
Texas BRZ (10-28-2014)
Trip to LA! 1086 Northern California 3 11-28-2013 07:57 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
road trip Tricky1980 Scion FR-S / Toyota 86 GT86 General Forum 8 05-14-2013 06:40 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
