Old 10-07-2014, 10:21 PM   #85
fretchh
Drives: WRB BRZ
When i purchased my BRZ it cams with nameless overpipe and axleback. I switched back to the stock muffler simply because it was too loud and I now feel the torque dip.
Can i safely assume that I will still be running the E85 stock brz tune? The overpipe is the only engine related mod that I have. If I choose to drop in a filter, will that still allow me to run the stock E85 map or will that put me to the STG 2 map?
fretchh is offline   Reply With Quote
Old 10-07-2014, 11:07 PM   #86
Turdinator
Señor Member
Turdinator's Avatar
Stage 2 is for cattless headers.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
fretchh (10-08-2014)
Old 10-08-2014, 03:37 AM   #87
Trettiosjuan
Drives: GT86
Stage 1 E85 map doesn't even exist. Stage 2 E85 also works on a stock car, unlike a stage2 gasoline there is no risk for knock on E85 and it will dial back automatically for the amount of oxygen that flows through the complete system (=AFR).
Trettiosjuan is offline   Reply With Quote
Old 10-09-2014, 12:33 AM   #88
mid_life_crisis
Drives: FR-S 10 #103 AT
I bit the bullet and went home the long way today so I could fill up with E85. I was on fumes when I pulled into the station. With the windows up, I started smelling something different within a couple of miles.
I haven't had the chance to get spirited with it yet, but my cruising trims look excellent.
I am worried about the smell though. Do I have an exhaust leak coming into the cabin?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-09-2014, 11:12 AM   #89
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
So I filled with E85 did all the stopped, loved it and filled again with a big grin on my face.
But now with the temperature getting colder here, I'm having troubles starting the car, since it takes as much as 8 cranks.... Anything that can be edited inthe tables to I dunno send more fuel or increase ignition ? Thanks
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 10-09-2014, 11:16 AM   #90
Trettiosjuan
Drives: GT86
Put in 5l of gasoline before you brim the tank with E85 (true 85%). This makes for E75 ish effectively. This will greatly improve cold starts, mine needs 1-2 cranks just above freezing...
Old 10-09-2014, 05:27 PM   #91
mid_life_crisis
This morning it was mid fifties. First time with E85 and the first time I needed to crank it twice. Not an auspicious sign for cold weather usage.
Old 10-09-2014, 05:50 PM   #92
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
It's less noticeable if you park in the sun. I park under a car cover, and leave for work at 1pm, even if it is ~80 out when I go to leave, if it dropped down to ~60 the night before I have to crank multiple times. Just tried 1 gallon of 93 yesterday, it started up better this morning. But either the ecu is learning the new blend, or I forgot how rough the engine feels when not running 100% E85.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-09-2014, 06:39 PM   #93
steve99
Drives: FT86
have a look in the oft tune tweaks thread you need to increase the Cranking IPW values, injector pulse width their is a link to thread on it you could also ask @Luckrider he did a bit of work on thiis with your e85
Trettiosjuan (10-10-2014)
Old 10-09-2014, 11:36 PM   #94
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
It has been a while since I played with that sort of thing, but I am back on e85 and my old changes still seem to be working well. The worst I have ever had it was 2 tries to fire. Usually it is vre-vre-vre-vroooommmmmmmm to start which is fast/easier than stock.
[ame="https://www.youtube.com/watch?v=mws6n7lW-8U"]Another cold start. Actual temp: 17° - YouTube[/ame]
The actual temp on this was 17.
Let me see if I can find some of my old tables.
Luckrider is offline   Reply With Quote
Old 10-11-2014, 12:38 PM   #95
Simon99
Simon99's Avatar
Filmed my cold start this morning (I know, I know, the real problem here is vertical filming). It actually wasn't that bad this morning, but listen a 00:26 and tell me how good that sounds **cries**
filmed my cold start this morning (I know, I know, the real problem here is vertical filming). It actually wasn't that bad this morning, but listen a 00:26 and tell me how good that sounds **cries** it was 51 degrees here which is considered still pretty hot ..
[ame]http://youtu.be/qLLwu371iqc[/ame]
The Following User Says Thank You to Simon99 For This Useful Post:
Target70 (10-12-2014)
Old 10-12-2014, 12:12 AM   #96
Target70
Target70's Avatar
mine was doing the same thing, at 80 degrees after a 50 degree night. I think that knock you hear is a backfire, but I could be wrong.
Old 10-13-2014, 11:07 PM   #97
Luckrider
Luckrider's Avatar
More of an intake burp than a backfire, but it has been determined to be normal on the stock ROM and safe.
Old 10-14-2014, 08:02 AM   #98
ZZT86
ZZT86's Avatar
Drives: BR86
Sounds like a mini backfire which I too have experienced in real cold temps with E85 only in tank. Mix to make E70 in those temps & you will be fine & dandy
ZZT86 is offline   Reply With Quote
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
