Old 10-05-2014, 07:17 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Is there any reason I shouldn't jack up my car from the side in the middle of the car
I'd like to jack up the car in the middle (about where the door handle is) but understand that is not the correct jack point. If I were to use something like this would it be alright to do this?
Specifically, I'm looking for first-hand experiences. I know the owner's manual does not recommend it.
Old 10-05-2014, 07:26 PM   #2
Bigbadvoodooguru
Drives: 2014 asphalt FRS
But why... use the front center jack point or the rear...?
Bigbadvoodooguru is offline   Reply With Quote
Old 10-05-2014, 07:31 PM   #3
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Doing that will mess up your car. The jack up points are reinforced.
- AdrianG
AdrianG is offline   Reply With Quote
Old 10-05-2014, 08:48 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
It's easier.
Old 10-05-2014, 08:49 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
- AdrianG
You have first hand experience with this? How did it "mess up" the car?
Old 10-05-2014, 08:51 PM   #6
AdrianG
No, I don't have first hand experience because I am not stupid.
If you search the forums though I saw a post a while ago of someone who did a bad job placing their jack stands and the car bent a bit.
- AdrianG
The Following 3 Users Say Thank You to AdrianG For This Useful Post:
Bimble Bamble (04-17-2015), kodyo (10-05-2014), MrBlaze-65 (10-06-2014)
Old 10-06-2014, 01:41 AM   #7
Poodles
Drives: 2015 Series.Blue
The jack points are reinforced. If you jack someplace else, you're going to bend something.
Though I do use that tool from flyinmiata all the time for pinch weld cars, so it's good to have (but you STILL use the factory points!)
Old 10-06-2014, 02:04 AM   #8
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Not on a BRZ, but I've done it on other similar cars and seen it done where it bent the pinchweld and/or dented in the rocker. On most cars, jacking in the middle of a car on the pinchweld where it is not reinforced is just asking for damage to happen.
I have the Flyin Miata jack adapter linked to in the first post. Works great, when used at or near the factory pinchweld jack points. Just jack it at the front jack point, behind the front tire, and it will lift the whole side of the car and the rear tire off the ground too.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-06-2014, 12:02 PM   #9
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Try not to jack from the pinch welds - if you don't do both sides at same time, they tend to bend - some not-so-cool shop decided to do this to my car way back before I knew any better and it's ever so slightly bent now. I always use the diff and the spot right in front of header, as prescribed by manual.
1Cor10:23 is offline   Reply With Quote
Old 10-06-2014, 12:15 PM   #10
qoncept
qoncept's Avatar
+1
Doesn't get much easier than that.
qoncept is offline   Reply With Quote
Old 10-06-2014, 05:23 PM   #11
Rosticles
Drives: 1966 Mustang, 2013 FR-S
Rosticles is online now   Reply With Quote
The Following 3 Users Say Thank You to Rosticles For This Useful Post:
DAEMANO (04-20-2015), funwheeldrive (10-15-2014), Trap63 (04-19-2015)
Old 10-06-2014, 06:10 PM   #12
qoncept
qoncept's Avatar
Originally Posted by Rosticles View Post
I didn't read the OP.
The Following User Says Thank You to qoncept For This Useful Post:
Jrryjms07 (10-09-2014)
Old 10-06-2014, 07:10 PM   #13
Rosticles
I did read: "I know the owner's manual does not recommend it."
It does more than that. It tells you exactly what to use.
At a track we lifted up the side a friends FR-S and started to bend the tabs. The spare tire jack in the boot does not pivot as it lifts, the same as a shops swing arm lift. Any jack that does will put shear on the tabs and probably bend them if there is any friction on the wheels of the jack.
Old 10-08-2014, 08:02 PM   #14
nmastereal
Those pinch welds are okay-ish to jack the car up by...IF you use a jack adapter of some sort that acts in the same way the oem jack in the trunk does. The oem jack actually has a slot where the pinch weld goes into and then actually pushes up on the subframe of the car. Using anything other than that will put pressure on the pinch weld which actually doesnt hold weight. It WILL bend.
IMO: Use the jack points if you can. If you are going to be modding your car, invest in the low profile one from harbor freight. It pays itself back in no time with ease of use.
nmastereal is offline   Reply With Quote
The Following User Says Thank You to nmastereal For This Useful Post:
Frishkorn (10-09-2014)
found water where I shouldn't ed8756 Engine, Exhaust, Transmission 14 09-19-2014 11:06 PM
How to jack up one side of your car without damage Ralph Spoilsport DIY (Do-It-Yourself) Guides 9 04-08-2014 05:06 PM
From OPPO: Why you shouldn't modify your car for the track. rice_classic Tracking / Autocross / HPDE / Drifting 28 03-03-2014 10:42 AM
Maybe I just shouldn't own this car execoll BRZ First-Gen (2012+) — General Topics 26 12-06-2013 07:08 PM
shouldn't have called.. shiud Scion FR-S / Toyota 86 GT86 General Forum 26 07-06-2012 11:02 PM
