Old 10-05-2014, 04:24 AM   #1583
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Originally Posted by DC2R View Post
I have car home disabled so it starts clean unless I remember to run radio app before shutting out p off car.will try and see if it stays connected if properly sleeping. Thanks
I still don't know why you guys have this problem. I use the no-CarHome version as well, I never touch the radio app, and the suspend/quick-start function works flawlessly. o_0
SilverlightPony is offline   Reply With Quote
Old 10-05-2014, 04:34 AM   #1584
Halesyeah
Drives: 2013 BRZ Limited
He's probably not using the no-carhome version, just has it disabled in the normal ROM
Halesyeah is offline   Reply With Quote
Old 10-05-2014, 07:13 AM   #1585
boxan59
Drives: Subaru BRZ 2013 Limited
Connection with iPhone make's without problem. And can i use OBD Cafi with bluetooth, and parrallel using iphone.
boxan59 is offline   Reply With Quote
Old 10-05-2014, 12:06 PM   #1586
DC2R
Drives: 2014 Scion FR-S
There are two CarHomes. One is the one with screen with your source choices which is easy to disable with no adverse effects. The other is the android launcher called CarHome. In my opinion this launcher sucks and must be disabled to use another launcher. Disabling this breaks standby unless you remember to run radio before turning off car.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
The Following User Says Thank You to DC2R For This Useful Post:
lamune (10-19-2014)
Old 10-05-2014, 10:14 PM   #1587
Darikashi
Drives: 2002 Ford Escape
So essentially the navigation is going to be useless unless I have my phone set as a wifi tether? It can't just connect to my phone through bluetooth and use my data?
Basically my issue is that I have an iPhone 5. I use Google Maps a lot to get around town but I don't pay the extra $20 a month to Verizon to be able to use my phone as a hotspot. I don't really care about going over the data limit because my plan is old enough that it's not very expensive to go over but young enough that I don't have unlimited data.
I just want a head unit that will be able to do navigation, play my music off my phone, play spotify, and play the radio. I don't care about subs and amps, I don't care about Torque, and I don't really care about DashCommand. I do care about having IHeartRadio so I can listen to SportsTalk segments I missed while at work.
Help me with this, guys, you're my only hope.
Darikashi is offline   Reply With Quote
Old 10-05-2014, 10:56 PM   #1588
spyingwind
Drives: White '17 86
You should be able to get a usb 3g/4g/LTE dongle to enable internet access with out having to tether. Another monthly payment, but a choice.
spyingwind is offline   Reply With Quote
Old 10-06-2014, 01:15 AM   #1589
Naeblis
Drives: Subaru BRZ
I know Verizon is not allowed to tell you you can't tether with the data you already paid for. The latest ones have tethering built in, but I don't know if the iPhone 5 has that built in normally. I did have a friend who tethered with his, but I'm pretty sure he had it jail broken.
Naeblis is offline   Reply With Quote
Old 10-06-2014, 11:59 AM   #1590
SPT Legacy
Drives: 2014 Lightning Red BRZ
Originally Posted by Prog View Post
Protpibe covered it a bit above. Honestly, it's a pain to get music on the CaFi. So much so that I haven't updated it in a couple months. I get in my car on Monday morning and I have to wait for it download podcasts before I leave the garage, as opposed to having everything automatically sync with my phone when I plug it into my computer (which I do every day, multiple times), and then just plug my phone into my head unit and go.
It's a trade off. If you don't want to fool with your phone, the Ca-Fi is for you. If you want to use your phone, it's really not.
In case this hasn't been answered yet, there's a program for Windows called Cheetah sync, which if it's connected to your home wifi will automatically sync folders.
https://play.google.com/store/apps/d...io.SyncFolders
SPT Legacy is offline   Reply With Quote
Old 10-06-2014, 12:28 PM   #1591
Foobar
SLO NO MO
Foobar's Avatar
This unit doesn't support blue tooth tethering as far as I'm aware.
That said, you could just load a GPS app that doesn't require online connectivity for map loading. Something like Sygic or GoPilot perhaps.
Old 10-06-2014, 10:05 PM   #1592
DC2R
In my experience Bluetooth tethering is wonky. Many apps just aren't able to use the connection. I believe Google play is one of them. Maybe it's time to make the jump to a tethering plan
Old 10-07-2014, 11:17 PM   #1593
bwthor
Drives: gray
Who here has a rock solid Torque setup, and what hardware are you using?
I've been using the following bluetooth dongle from Amazon, and it works about 75% of the time...
[ame="http://www.amazon.com/gp/product/B008U1MOM8/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1"]Amazon.com: iSaddle Super Mini ELM327 V1.5 OBD2 OBD-II Bluetooth CAN-BUS Auto Diagnostic Tool for Windows & Android Torque (Blue Color): Automotive[/ame]
I also tried this USB OBDII dongle, but it didn't work at all, actually makes a bunch of warning lights come on my dash without being plugged in to the head unit. It may be bad...
[ame="http://www.amazon.com/gp/product/B005FEGP7I/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1"]Amazon.com: ELM327 V1.4 USB OBD2 OBDII CAN-BUS Diagnostic Scanner USB Cable: Automotive[/ame]
bwthor is offline   Reply With Quote
Old 10-08-2014, 01:15 AM   #1594
Darikashi
As if someone was reading my mind, look what just popped up on Uncrate today:
http://uncrate.com/stuff/karma-go/
So basically I could pay as I go no matter how much data I use (which wouldn't be much with just spotify and navigation while I'm in the car) and I could just leave it in the car all the time.
This is a new model they're coming out with, I actually ordered an older one and I'll upgrade when the new one comes out but this would be perfect for anyone looking for a tethering option without having to pay a monthly fee.
Old 10-08-2014, 02:07 AM   #1595
Orisai
Drives: Hyundai ix45
Why would someone use bluetooth tethering for Internet connectivity? It's way slower and less reliable than WiFi.
Orisai is offline   Reply With Quote
The Following User Says Thank You to Orisai For This Useful Post:
Simok (10-12-2014)
Old 10-08-2014, 02:37 AM   #1596
SilverlightPony
Nice!
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
