CANADA Canada
Old 10-05-2014, 02:45 PM   #43
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Crickets are a way of life. I only fill up at quiet stations that have Ultra 94 in rusty fuel bowsers. The crickets are steadily getting louder, to the point where they don't sound like crickets anymore. I'm trying to engage Tweet Mode.
pushrod is offline   Reply With Quote
Old 10-05-2014, 05:35 PM   #44
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Originally Posted by ripper View Post
invidia n1 exhaust will kill your crickets.
I have muffler delete. Probably louder than N1. Still hear crickets at idle all the time
Thanks again everyone for your input. I was rather upset when the sound first surfaced, thinking "great. got out of one problem car and into another."
But now, knowing that it is an extremely common issue that most are experiencing, it makes me feel at least a bit better.
I personally am one of those people who can't stand the sound. Yes, it's not extremely intrusive, but it's still annoying to me, and the bottom line is that it simply shouldn't sound like that to start with.
The sound is annoying to me, but I'm MORE bothered by the fact that, over 2 years since the release of this car, and with a vast majority of owners reporting the issue, Subaru/Toyota is basically willing to do nothing except replace your noisy part with the same noisy part. In my case, they're not even willing to do that! Although, as someone above mentioned, it may be an exercise in futility anyways.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 10-05-2014, 05:59 PM   #45
Originally Posted by krayzie View Post
This is because when you first start the car, the engine is running on port injection and not direct injection.
no. only when it's hot.
If you open the hood of a 2.0T VAG product, you will hear the crickets on startup because that engine only has direct injection. The Hitachi HPFP in the 2.0T is just better insulated than the Denso HPFP in the twins. VW/Audi also have much better sound deadening with their cabins.
you are confusing what you imagine to be crickets with normal hpfp clatter
I also hear rocks hitting the bottom side of my BRZ readily where I don't hear anything with other makes and models, yet nobody ever complains about that.
empathy fail.
Old 10-05-2014, 10:06 PM   #46
Originally Posted by ahquit View Post
I had my chirping fuel pump replaced recently because:
1. I find it very annoying to have to listen to
2. Add mine to the list of documented replacements in the hopes that if there's enough complaints Toyota will do something about it
This issue seems to be on a case by case basis, but for what it's worth I haven't had any chirping yet with the revised part # fuel pump.
Here's the list. Add away.
http://www.ft86club.com/forums/showthread.php?t=9836
Old 10-05-2014, 10:43 PM   #47
brzr
brzr's Avatar
Drives: 2013 frs
I embrace all the chirps squeaks and noises that my car makes
I'll get crickets if I fill up at petro....usually don't hear them with costco fuel....and they come out when it's really hot....but it doesn't change how I feel about the car
i bought my plates 7 years before i bought my car
http://www.ft86club.com/forums/album.php?albumid=1329
brzr is offline   Reply With Quote
The Following User Says Thank You to brzr For This Useful Post:
Tcoat (10-07-2014)
Old 10-06-2014, 07:18 AM   #48
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
empathy fail.
There are crickets with my old 2.0T BPY during cold starts, which goes away and get replaced by your so-called *normal HPFP clatter* only when then engine has been running for some time. Not confused at all when I've had the car for almost 7 years not sure what you are smoking.
I've had crickets on my BRZ when the weather wasn't hot. It's just more prone to crickets when the weather gets really hot but not a rule of thumb.
Maybe you come from a parallel universe.
krayzie is offline   Reply With Quote
Old 10-06-2014, 02:38 PM   #49
That's nice. So, in your universe does the engine bay only heat up when it's hot outside? That would be impressive.
Old 10-06-2014, 03:16 PM   #50
krayzie
Drive From Home
krayzie's Avatar
That's the best you can do to demonstrate your troll logic?
Old 10-06-2014, 03:34 PM   #51
yup. we done now?
Old 10-06-2014, 04:11 PM   #52
krayzie
Drive From Home
krayzie's Avatar
yup. we done now?
Looking forward to more on9 posts from you.
Old 12-18-2014, 12:32 AM   #53
Thrilled
Drives: FR-S Whiteout 2013
In our area, SE Pennsylvania, I've found that some brands of fuel yield fewer crickets than others. They all indicate up to 10% ethanol on the pumps and rumor has it all the fuel generally comes from the same refinery near Philly. Oddly enough, though, Hess and Lukoil give me less trouble. Shell was the worst in my experience. I tried an ethanol killer once with no success. I'm thinking it might help to try sea foam or Mechanic in a Bottle: both have been great with my small engines (mower, leaf blower, snow blower, trimmer). In fact the Seafoam helped restore some really old fuel (many years old).
Anyone found any of these ethanol blocking additives help?
Thrilled is offline   Reply With Quote
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
True Fix to Crickets and Pump CharlieChaos Issues | Warranty | Recalls / TSB 48 08-17-2013 02:17 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
